Need Help, Only see top half of screen when using SLI
Discussion in 'Graphics Cards' started by IN4800, Mar 21, 2006.
  1. IN4800 New Member
    Mar 12, 2006
    8 (0.00/day)
    0
    I have two 68000gs overclocked nvidia cards in SLI. When i put them on multiple gpu rendering. I am only seeing the top half of the screen. The bottom half is black. I can see the load balancing green line. I do see under device manager that I have two cards. Drivers are8.1.9.8. Anyone, please help:banghead:
  2. D_o_S
    D_o_S Moderator
    Aug 27, 2005
    979 (0.30/day)
    38
    First, have you tried the cards non overclocked? Also, what mother board are you using? Are the jumpers/card/BIOS settings on the mobo correct for SLI?
  3. IN4800 New Member
    Mar 12, 2006
    8 (0.00/day)
    0
    It's the asus a8n32 sli deluxe. I will default all setting in the mother board and not overclock them. I did not touch any jumpers. Is there any specific setteing that need to be changed or jumper normaly.
Share This Page
