Need Help Overclocking XFX radeon HD 6570
12 (0.00/day)
Hello Folks,
I want to overclock my xfx hd 6570. The problem I am facing is in the AMD's Catalyst Control Center i can overclock the memory clock settings from 500mhz(stock) to 1000mhz but i can only overclock my GPU clock settings by 25mhz. Thats from 650 mhz (stock) to 675 mhz.
I have seen other models of the same card's (powercolor hd 6570) gpu speed overclocked upto 850mhz on the net.
Please do help me.
Here is the pic-
1,980 (0.42/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Hi
General Rule of Thumb
Use MSI Afterburner Software for overclocking graphic card
Find out the max OC
Increase 5~10Mhz on core in stages test at each stage, if the system freezes you have gone to far, lower the OC by 40Mhz and then start the same process with the MEM increase 5~10Mhz once you get artifacts back the OC down by 40Mhz;
Important
Use GPU-Z Software to keep an eye on VRM Temps these can rise quickly when OC's are applied Keep these between 70~80c : 85c Max]
-Adjust vga card fan speed manualy set it between 80 ~ 100% [*if required to keep temprature under control]
-Be aware that some games do not like overclocks due to differences in the GPU wafer quality and testing with each game as well as benchmarks is nessesary
-Coolers differ [while one card may cope well with heat the other may not]
-Make the drivers are up to date and that they are stable; if they are unstable they will crash the OC
-Check that the motherboard is setup and chipset drivers are up to date [Run CPU and MEM at default speeds while testing vga card OC]
Note: an OC of 25Mhz is acceptable for that model
If get a chance go here and fill in system specs; manufacturer names, model numbers & opperating system
atb
Law-II
12 (0.00/day)
Hi
Find out the max OC
Important
-Be aware that some games do not like overclocks due to differences in the GPU wafer quality and testing with each game as well as benchmarks is nessasary
atb
Law-II
Well I did come to know that through Internet. What I need to know is how should I overclock it above that 25mhz. Can flash bios of another gpu of same kind (like of hd 6570 by powercolor) and then will it make a difference?
519 (0.14/day)
UK
System Name Daedalus
Processor AMD FX 6300
Motherboard ASUS M5A97 EVO R2.0
Cooling Coolermaster Hyper 212 EVO
Memory 8GB Kingston HyperX Genesis (2x4GB)
Video Card(s) MSI R9 270X Gaming 2GB
Storage 1TB Seagate Barracuda
Display(s) LG Flatron E2442 (main - 24in 1080p)
Case NZXT Phantom 410 (Gunmetal Edition)
Power Supply XFX Pro 650W
Mouse Steelseries Siberia [RAW]
The problem with flashing a non-reference card with the BIOS of another non-reference card is that they often have different PCBs, therefore this can cause problems with the BIOS (as it cannot find certain components, or the PCB is arranged differently) and thus problems with using the card. So I don't think that would be an option. Maybe you just have a bad card for overclocking?
Layton
1,980 (0.42/day)
Mainland Britain
System Name H2o Box
Case Corsair O-800D
Mouse Zelotes T-90
Hi
What need to know and have understanding of: GPU wafers differ they are binned for quality by the manufacturer [same as CPU's] some overclock well and others not at all.
Cooling the card adequatly allso allows for some headroom
Note: I do not recommend flashing this vga card with a vbios image from another manufacturer; most likely it will brick the card
Recommend selling the card if not happy with performance and buying one that will give better performance out of the box; even with an 850Mhz overclock it will only equate to 5~10fps more and kill the card quicker
atb
Law-II
12 (0.00/day)
Hi
Note: I do not reccomend flashing this vga card with a vbios image from another manufacturer; most likely it will brick the card
atb
Law-II
Okay so is there anyway I can overclock my damn card?
519 (0.14/day)
UK
It would seem not, unless you bought another card. But the improvement in FPS and gaming won't be that much with overclocking as @Law-II stated, and will reduce the usage life of your GPU, so perhaps its not really worth it in the end. Sorry about that.
Layton
OneMoar
There is Always Moar
8,744 (1.71/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Cooling Enermax ETX-T50RGB
Storage ADATA SX8200PRO NVME 512GB, Intel 545s 500GBSSD, ADATA SU800 SSD, 3TB Spinner
Mouse Kone burst Pro
Keyboard EVGA Z15
ddr3 card no point in overclocking replace it
you aren't gonna see much of a improvement even if you could clock it to 1000Mhz the video-memory is just to slow and there is no fixing that even if you push the gddr3 to 600Mhz it won't matter
the 850Mhz card you read about is probably the slightly less crappy GDDR5 variant the clock limit is their because those cheap GDDR3 can't take it
