Need Help! Power Inverter info Needed ASAP
Discussion in 'General Hardware' started by wes.aggie, Oct 30, 2009.
  1. wes.aggie New Member
    Oct 30, 2009
    2 (0.00/day)
    0
    Guys,
    I am in need of power and was notified that I cannot use a generator. I know I need batteries and a power inverter. I'll just cut the bs and get to the nuts and bolts.
    Going to be running:
    3 tvs (pretty sure all are 32 in)
    1 ps3
    1 xbox 360
    1 DVD player
    Looks like around 850-1000 watts. I will prolly be running them for about 3-4 hours and hopefully continuously.
    So, I've done some figuring but I'd rather have someone who knows what they are talking about enlighten me. How many batteries do I need, connect parallel?, how big of inverter, and should this last and work for what I need. Thanks, any response is appreciated and the sooner the better. Planning this as I type. Thanks again.
  2. Woody112
    Woody112 New Member
    Jan 18, 2008
    562 (0.18/day)
    75
    Florida
    The only batteries that will run those components for 3-4 hours are 8D batteries. They are rated at 250ah unlike car batteries which are only rated at 40-50ah. Be sure of the total power draw if it is 1000w then get a 1500w inverter. Remember Amps x volts=watts so watts / volts=amps. Do the math and you can determine how many amps you will draw per hour total. So figure your drawing a total of 100 amps an hour then a single 8D battery will only last you 2.5 hours with a full charge. OR 5 car batteries rated at 50ah connected in parallel Hopes this helps.
    Also the inverter it's self will be drawing amperage so this will have to be factored in.
  3. wes.aggie New Member
    Oct 30, 2009
    2 (0.00/day)
    0
    Woody, thanks a ton. That helps, I know see that I really don't have a choice other than a generator. Any tips about them?
  4. Woody112
    Woody112 New Member
    Jan 18, 2008
    562 (0.18/day)
    75
    Florida
    Ya a generator would be your best bet. You could get you an 2.5kw onan home site power generator for about 500 dollars I believe.
    Here's a link to help you understand how much power is going to be drawn from the battery.
    http://www.whistlergroup.com/faq-inverters-answers.asp
