Need help rotating Xigmatek 90 degrees on AM2+
Discussion in 'Overclocking & Cooling' started by MT Alex, Aug 2, 2009.
  1. Nick89
    Nick89
    Jun 1, 2006
    1,742 (0.56/day)
    176
    The Nevada Wasteland
    I'm now using the Thor's Hammer and this is impossible now.
  2. jmcslob
    Mar 14, 2009
    2,933 (1.41/day)
    475
    Internet Heaven
    well actually no pins to pull with the Xigmatek's
  3. jmcslob
    Mar 14, 2009
    2,933 (1.41/day)
    475
    Internet Heaven
    did it come with 775 mounts?
    WHY not explain
    maybe someone can help
  4. MT Alex
    MT Alex
    Aug 2, 2009
    3,806 (1.96/day)
    1,640
    Geez
    Okay, I went to the xigmatek website again, and downloaded the Thor's Hammer manual. This cooler should be even easier than my 983 or the s1283 because the 775 brackets are already made to mount on top of the cooler. And like jmcslob says there aren't the push pins to remove on that model like there are with my 983.
    I have included both frames in case you have lost your manual. The bolts on the Type X bracket line up with the corrisponding 775 holes on the hardware provided. You may not even need to use nuts and washers from the hardware store because of the provided stuff in frame two.
    One thing to note, I moved my 775 brackets to the top of the cooler to resolve the issue of differing heights between the AMD and Intel chips. You may need to go to the hardware store and get longer 3mm bolts, remove the shorter bolts from the Type X (they screw in from the back) and replace them with the longer ones. This will give you enought threads to use nuts or the included jazz. You may just need to clip some length off the springs with the included hardware.
    Hopefully this clears things up. It really will work, I have done it, so have a bunch of people who reviewed the bracket on Newegg.
  5. Wile E
    Wile E Power User
    Oct 1, 2006
    24,324 (8.17/day)
    3,778
    And note, if you use longer bolts, you don't have to grind the Xigmatech mounts. All you should have to do is flip them upside down and bolt them on.
  6. Darknova
    Darknova
    Nov 8, 2006
    5,037 (1.71/day)
    535
    Manchester, United Kingdom
    Wile E bought me one then shipped it to me :)
    The Type-S mount has bolts that are twice as long, not sure if they'd reach the mounts if you did that though...
  7. Nick89
    Nick89
    Jun 1, 2006
    1,742 (0.56/day)
    176
    Yea it looks like it in the manual but I have the actual thing sitting here with me. At best you could get a loose fit with the type-X, there are numerous issues that I don't feel like describing.
  8. Fatal
    Fatal
    Jan 21, 2009
    732 (0.34/day)
    120
    Golden, Colorado
    I bought the Enzotech Type-X AM2 Retention should have it this week some time. I also picked up some G-skills since my Dominators are too tall. They dont gel with my board - Not compatible so I hope I can get higher clocks soon! :cool:
  9. Kantastic
    Kantastic
    May 12, 2009
    5,156 (2.55/day)
    993
    Nick I hope you get my PM soon! Don't buy the Thor's Hammer again after the RMA!
  10. MT Alex
    MT Alex
    Aug 2, 2009
    3,806 (1.96/day)
    1,640
    All warm and fuzzy
    It's nice to see people are finding this thread helpful, or at least interesting enough to comment on. This was my first thread, and my first time ever posting on any forum. I was genuinely surprised when Fatal answered back so quickly, and everyone else who helped out. Now I check the "New Posts" link in the morning before work and periodically during the evening.
    You guys are cool.
  11. Fatal
    Fatal
    Jan 21, 2009
    732 (0.34/day)
    120
    Golden, Colorado
    Good people here and many with a lot of knowledge :toast: I have had many help me out the forum is great. I do hope having it 90 degrees helps me out. Even if its 2c will be worth it to me I think my memory has been my problem. 3.8 GHz is my goal stable so I am keeping my fingers crossed. I hope I just don't have a bad apple :p
  12. Darknova
    Darknova
    Nov 8, 2006
    5,037 (1.71/day)
    535
    7'C idle temp drops for me :)
    Fatal says thanks.
  13. MT Alex
    MT Alex
    Aug 2, 2009
    3,806 (1.96/day)
    1,640
    Is this the G-Skills you bought?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
    I think I will order those as well, currently using kingston valuram 800, not impressed.
  14. jmcslob
    Mar 14, 2009
    2,933 (1.41/day)
    475
    Internet Heaven
  15. WSP
    WSP New Member
    Aug 26, 2009
    101 (0.05/day)
    6
    Indonesia
    any info on how to rotate 90° on another cooler than Xiggy? TRUeX perhaps?
  16. pantherx12
    pantherx12 New Member
    Jan 2, 2009
    9,714 (4.51/day)
    1,699
    ENGLAND-LAND-LAND
    It would work in the same way.
  17. burrito New Member
    Sep 6, 2009
    3 (0.00/day)
    0
    If I get this type-S mount (instead of a type-X) will I still need to mod the clips to attach a XIGMATEK HDT-S1283 to my AM2+ mobo? I don't have any tools for modding the clips but I still want to do the 90 degree rotation.
    Also will I need to remove my mobo from the case to remove the old mount and add this one on? Or can I just screw them from the top?
  18. Kantastic
    Kantastic
    May 12, 2009
    5,156 (2.55/day)
    993
    The True Rev. C comes with a new mounting kit that allows you to mount AM3 processors in any direction!
    WSP says thanks.
  19. MT Alex
    MT Alex
    Aug 2, 2009
    3,806 (1.96/day)
    1,640
    Okay. First, looking at the pics of the S Type on Newegg, the screws may be long enought that you will have enough threads above the brackets by putting them on top upside down. It is also very possible that you may not need the washers and nuts, you could just put the brackets on your Ziggy and use the screws from the top: through the top of the 775 mounting bracket down into the S mount, rather than installing the screws through the bottom of the S Type bracket and then using washers and screws on top of the cooler.
    Second, it depends on the amount of reinforcement that your motherboard has behind the processor slot as to whether or not you have to remove your motherboard. The S and X Type brackets come with reinforcement that goes behind the board. I have a Gigabyte MB and the stock reinforcement was fine, I could have done it all without removing the board. Refer to my pics and explanation on page 1.
    Good Luck and Good Hunting
    Alex
  20. burrito New Member
    Sep 6, 2009
    3 (0.00/day)
    0
    I have this motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128014
    I didn't see any screws on it though so I don't know what I would have to do.
    [​IMG]
  21. pantherx12
    Jan 2, 2009
    9,714 (4.51/day)
    1,699
    ENGLAND-LAND-LAND
    Does it still have a bracket on the back?
    If it doesn't you'll need to buy a new set of mounts in order to do the things these guys are suggesting.
    If it does have a bracket and it has threaded holes then you just have to take the push pins out.
  22. burrito New Member
    Sep 6, 2009
    3 (0.00/day)
    0
    Yes it does have a bracket on the back, I opened up the other side of the case and there was a hole in the case that let me see the bracket there. I just wanted to make sure I could rip those things off before I broke something lol
  23. pantherx12
    Jan 2, 2009
    9,714 (4.51/day)
    1,699
    ENGLAND-LAND-LAND
    I'd still do it carefully if I were you, I've managed to crack a PCB pulling out those types of push pins!
  24. Fatal
    Fatal
    Jan 21, 2009
    732 (0.34/day)
    120
    Golden, Colorado
    Yeah those are the ones should do well I hope. :rockout: good reviews on them to and they are not as tall plus to me.
  25. WSP
    WSP New Member
    Aug 26, 2009
    101 (0.05/day)
    6
    Indonesia
Share This Page
