Deleted member 67555
Pics of how Jmcslob did it
I used the current AMD retainer in conjunction with the enzotech type-x
First I had to grind off the side screw tabs
http://www.overclock.net/picture.php?albumid=1667&pictureid=9376
Then I drilled 4 holes with a 1/16" drill bit into the AMD retention clip to match the Enzotech Type X bottom support post I wanted to keep these for more support, I used a Sharpie to mark each spot prior to drilling
http://www.overclock.net/picture.php?albumid=1667&pictureid=9377
I then used Aaron Alpha (like super glue but industrial strength) to permenately bond the 2 together
http://www.overclock.net/picture.php?albumid=1667&pictureid=9379
Following the steps above I grinded the tabs off the 775 mounting clips and placed them like this
http://www.overclock.net/picture.php?albumid=1667&pictureid=9382
http://www.overclock.net/picture.php?albumid=1667&pictureid=9383
I then attached the Modded Heatsink fan retention clip to the motherboard
http://www.overclock.net/picture.php?albumid=1667&pictureid=9384
Then I simply used 4 4-40 nuts to secure it to the mobo
http://www.overclock.net/picture.php?albumid=1667&pictureid=9385
http://www.overclock.net/picture.php?albumid=1667&pictureid=9386
You may have noticed that when I placed the Enzotech type-X onto the Heatsink fan retention clip, I off set it to the left, I did that to align The HSF with the rear Exhaust fan
http://www.overclock.net/picture.php?albumid=1667&pictureid=9387
I know it's not the best picture but look how exact the HSF and rea exhaust line up
I will update this post as soon as things are working right
Idle
under full load with Wprime
Idle
