Need help to choose the right case for a water cooling system
Discussion in 'Cases, Modding & Electronics' started by Gainward, Apr 20, 2011.
  1. Gainward
    Nov 2, 2010
    43 (0.02/day)
    0
    Hi there :)
    I'm planning to buy a water cooling system (EK-KIT H3O - Supreme HF 360)
    And i think that my current case (Antec 902) isn't enough to contain a water cooling system so i decided to buy a new case but i don't know what should i choose
    so help me to choose :banghead:
    Thanks a lot
  2. random
    random
    Oct 19, 2008
    3,044 (1.23/day)
    686
  3. Gainward
    Nov 2, 2010
    43 (0.02/day)
    0
    What about the CM HAF X ?
    Actually the Corsair 800D is pretty expensive
  4. random
    random
    Oct 19, 2008
    3,044 (1.23/day)
    686
    HAF-X is more for air cooling, but I am not sure might be worth looking at people's experiences with the haf-x, the main problem with water cooling is the radiator mounts.
    This reason is why most people who use watercooling go with the 800D
    you should also provide us with your budget, it'll help.
  5. Gainward
    Nov 2, 2010
    43 (0.02/day)
    0
    But anyway the HAF x is enough for one 360 radiator right?
    Well my budget is about 240$, but the prices here in Sweden is different than in US, the 800D costs 340$ and the HAF x 240$
  6. random
    random
    Oct 19, 2008
    3,044 (1.23/day)
    686
    Yes it should, if you need triple radiator can always just buy longer tubing. Most people seem to have this lay out http://www.tech-forums.net/pc/attac...-price-limit-watercooling-system-dsc00714.jpg, but for single radiators, that'll be compatible with any case really as you'd presumably be mounting it on your exhaust fan
    Gainward says thanks.
  7. MT Alex
    MT Alex
    Aug 2, 2009
    3,894 (1.78/day)
    1,704
    If you are going the Coolermaster route, I would suggest the ATCS 840 over the HAF X. A tripple easily fits up top. It's a bigger case with many more options, even adding another dual in the drive bays, the inside just isn't painted black like the HAF.
    Here it is, with a tripple mount shown. The nice thing is it's all internal.
    http://www.coolermaster.com/product.php?product_id=5777
Share This Page
