Need help unlocking i7 950 to a quad |(
Status
Not open for further replies.
496 (0.09/day)
System Name The Venerable One
Processor Intel Core i7 980x 3.33GHz
Motherboard EVGA X58 FTW3
Cooling Big Ass fan pointed at the motherboard with the side panel off FTW
Memory 12GB DDR3 1333
Video Card(s) EVGA GeForce GTX 680 Superclocked X2 in SLI
Storage Samsung 840 Pro 256MB SSD/1.5TB HDD internal
Display(s) Samsung SyncMaster 2443BWX 24" 1920X1200
Case SK-503 Super Case
Audio Device(s) X-Fi Xtreme Music
Power Supply SeaSonic 1000W Platinum Rated
Software Windows 7 Home SP1 64-bit
Benchmark Scores epic
wait a minut device manager shows 8 cores?? check your windows start up options m8. this happened to me. if you have it set to anything but all on your windows startup options this will happen
You are saying to enable every program to startup in msconfig? I'm not sure what else you are referring to.
de.das.dude
Pro Indian Modder
8,785 (1.73/day)
Stuck in a PC. halp.
System Name Monke | Work Thinkpad| Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
It sure will, because most systems work better after a reinstall (unless they are brand new, then there will be no advantage at all). Otherwise, there is no change. There is also no reason why there would be one.
during install, windows automatically optimises according to hardware. i took my hdd to a friends place once and it didnt work. so you theory is cloudy.
2,665 (0.47/day)
System Name Dire Wolf IV
Processor Intel Core i9 14900K
Motherboard Asus ROG STRIX Z790-I GAMING WIFI
Cooling Arctic Liquid Freezer II 280
Memory 2x24GB Corsair DDR5 6667
Video Card(s) NVIDIA RTX4080 FE
Storage AORUS Gen4 7300 1TB + Western Digital SN750 500GB
Display(s) Alienware AW3423DWF (QD-OLED, 3440x1440, 165hz)
Case Corsair Airflow 2000D
Power Supply Corsair SF1000L
Keyboard Chuangquan CQ84
I have no theory. You have one, and no proof of it, either. Taking a HDD to another system and getting a BSOD is completely normal due to Windows trying to access hardware which is not present. Do you have proof of that "optimization" which is done at install, rather than reconfigured every time new/different hardware is detected?
Mussels
Freshwater Moderator
58,413 (8.18/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
MSconfig, boot, advanced.
496 (0.09/day)
Reason I didn't go there is because Windows only shows 2 cores there as well. That was one of the first places I looked. thx 4 the heads up though
Bo$$
Lab Extraordinaire
5,656 (1.03/day)
London, UK
System Name Desktop | Server
Processor Intel i7 2700k @ 4.6GHZ | AMD 5350 @ 2500MHZ
Motherboard Asus P7Z77-V Pro | Asus AM1I-A
Cooling Corsair H60v2 | Stock Air
Memory Crucial Ballistix 2x8GB CL8 1600MHZ | Corsair Vengence 2x4GB CL9 1600MHZ
Video Card(s) EVGA GTX 1060 6GB | PNY GTX 750Ti
Storage Samsung 840 EVO 250GB + 4TB WD Red | 2x Seagate Barracuda 2TB
Display(s) Samsung S27D390H + Asus VE276Q | Headless
Case Fractal Design R5 | CM Elite 110
Audio Device(s) Asus Xonar D1 w/Otone Stilo 5.1 and Creative Fatal1ty headset
Power Supply EVGA Supernova 850 G2| Corsair CX430M
Mouse Razer Imperator 2012
Keyboard Corsair K90
Software Windows 7 SP1 X64 | Ubuntu 16.04LTS
Mussels
58,413 (8.18/day)
Oystralia
496 (0.09/day)
no he should set it to 0, and let it auto detect.
My options on that screen are 1 and 2 not 0. I just spent 4 hours reinstalling Windows 7. It is the install where it writes over the old install and doesn't format the disc. If it doesn't work then it's format time.
wolf
Performance Enthusiast
7,753 (1.25/day)
System Name MightyX
Processor Ryzen 5800X3D
Motherboard Gigabyte X570 I Aorus Pro WiFi
Cooling Scythe Fuma 2
Memory 32GB DDR4 3600 CL16
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
I still think the CPU itself may be defective. I've never ever seen or heard of this before, and windows 7 is an absolute champ about any hardware, drivers or not.
theonedub
habe fidem
8,025 (1.47/day)
Northern CA, USA
System Name Erakith || AsRock NUCS
Processor AMD ThreadRipper 2990WX ES (32c/64t 3.5ghz@1.02v) || Intel i7 1360P Raptor Lake-P
Motherboard MSI X399 MEG Creation || AsRock OE
Cooling EK Supremacy TR4 Full Nickel, D5 w/ EK Top, 2X EK-CoolStream XTX 360 & Photon 270 Res || OE
Memory 32GB (4x8GB) Corsair Vengeance PRO RGB DDR4 3000|| 2x16GB Corsair DDR4
Video Card(s) Vega 64 EK FC|| Intel Iris Xe
Storage 250gb WD Black NVMe & (2) 2TB Intel 660p NVMe || 2TB Corsair MP600 Pro
Display(s) 34" Dell Ultrasharp U3415W
Power Supply Corsair HX1000
Software Windows 10 Pro x64 || WIndows 11 Pro x64
ditto reinstall OS everytime you change any major hardware. like mobo or CPU or VGA.
If you love to waste your time follow this advice.
My current OS install has been through 7 GPUs, 2 different CPUs and 2 different MBs. Runs perfect. My old WCG machine went through 4 GPUs, 4 different CPUs (AMD and Intel) and 2 different motherboards and had the OS installed a single time. According to my WCG and F@H numbers both rigs performed to their fullest after each change.
3volvedcombat
1,514 (0.28/day)
South California, The desert.
System Name My Computer
Processor Core 2 Q9550 4Ghz 1.23volts
Cooling Corsair
Memory OCZ
Video Card(s) Galaxy
Storage Western Digital
Display(s) Acer
Case Lian li
Power Supply Corsiar
Software Microsoft
Benchmark Scores 25,000 3dmark06 at 4.35Ghz processor, 835core card!
yes??
i know your system will still work, but it will work even better after a reinstall.
i experienced it myself.
after changing my mobo and CPU to the current, i didnt reinstall, but later i reinstalled and was amazed at the true power of the Phenom II!!
Um, you changed your mobo, that was the reason why it performed like crap.
Lets say you had the same mobo way before you got the phenom II
you plug in your Phenom II but never change the mobo, you would have gotten the same performance increase.
I belive, if im right, windows puts registry keys, and everything involving that specific motherboard during install, so when you change a motherboard, that has a different type of chipset, the slots are diffrent, and the actual cpu is different.
it isnt going to use the motherboard right, because the OS will have diffrent signatures for different slots on the motherboard.
Most of the time you cant even boot your computer if you try using a different motherboard.
you got lucky, but it performed like crap.
I had a a e5200 on this same ep45-ud3p, it performed decent, alright for the price. I never REINSTALLED the operating at all, it was the same OS, and i pluged in a q9550, I noticed the difference IMMEDIATELY i bench marked, and without reinstall the OS but just changing the cpu, i got a 5,000 piont increase in 3dmark06.
thats good shit. :toast:
***anyways***
On this predicament with the i7, hmm ive never heard of Intel putting out chips that just arnt working properly or have any cores.
Hmm i think you should just reinstall OS, re-seat the processor.
Basically, Rebuild the computer, and make sure everythings perfect, grab a checklist, have fun! :toast:
CDdude55
Crazy 4 TPU!!!
8,178 (1.33/day)
Virginia
System Name CDdude's Rig!
Processor AMD Athlon II X4 620
Motherboard Gigabyte GA-990FXA-UD3
Cooling Corsair H70
Memory 8GB Corsair Vengence @1600mhz
Video Card(s) XFX HD 6970 2GB
Storage OCZ Agility 3 60GB SSD/WD Velociraptor 300GB
Display(s) ASUS VH232H 23" 1920x1080
Case Cooler Master CM690 (w/ side window)
Audio Device(s) Onboard (It sounds fine)
Power Supply Corsair 850TX
Software Windows 7 Home Premium 64bit SP1
I assume you have tried everything including, resetting CMOS, updating BIOS and making sure all cores and HT are enabled in BIOS.
As stated above, try reseating the CPU and of course reinstalling the OS, especially when swapping motherboard, you want to have the OS freshly see the new hardware installed.
And if all that doesn't work, then it could as well be a screwed up chip.
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
I used this Windows 7 install with my old CPU which was a Phenom II X2 550 dual core. I installed the new mobo/CPU without reinstalling Windows 7 and reactivated by phone. You think Windows is configured to recognize 2 cores max somewhere? How do I access that without having to reinstall?
Re-Install your OS, that is the only option.
You can get away with doing this going from similar hardware to similar hardware, but going from a totally different setup on an AMD platform to an Intel Platform is never going to work properly.
Just bite the bullet and re-install.
You can listen to all the people saying they've done it before without problem, but obviously you are having problems, so just re-install the OS. And as a rule of thumb, I always re-install the OS when chaning motherboards, most other hardware is fine, but the motherboard just has so much hardware on it, it is best to just get rid of all that extra drivers gunk and start with a fresh OS.
496 (0.09/day)
I don't think it is the chip because Windows sees 8 cores and I can switch from 1 physical & 1 virtual core active to 2 physical. If the chip was dead in the other cores, most likely I couldn't swap cores like that. 3volovedcombat's explanation of the signatures being different for the motherboards must be true or else I couldn't see the 8 cores in device manager.
Anyone know if Windows puts your old install files into a folder like Windows.old so I don't have to go through my entire hard drive backing up files before the reformat? thanks
theonedub
habe fidem
8,025 (1.47/day)
Northern CA, USA
I do not think that Windows.Old keeps your installs intact. The folders will be there, but you can't just copy and paste them back to the ProFiles directory. Documents, sure. Programs will need a reinstall.
You can get away with doing this going from similar hardware to similar hardware, but going from a totally different setup on an AMD platform to an Intel Platform is never going to work.
With the magic that is Windows7 I (and other people on the forum) have done the AMD to Intel switch without a hiccup. I went from an E5200 to a Phenom II 965 it booted, installed drivers, rebooted, and was good to go.
lisburnni
179 (0.03/day)
System Name gaming PC
Processor i7 950 @4326MHZ 21x206 HT on, Cool Labs TIM
Motherboard Gigabyte X58A UD5
Cooling Thermalright HR02 Scythe S-FLEX 1600rpm fan
Memory Corsair Dominator 6GB 7-8-7-20 1T at 1648MHZ
Video Card(s) EVGA GTX570, BFG GTX260 216sp Maxcore Physx
Storage Crucial realssd 128gb ( win 7 Ult.)Seagate 500GBx2 Raid 0(Games, Sharing etc)WD Caviar green 2TB
Display(s) Dell U2410 IPS panel
Case Corsair 800D
Audio Device(s) X-FI Extreme
Power Supply Corsair AX750
Software OS- Win7 Ult 64 itunes/firefox/cod(4+5)/Endwar/world In Conflict
during my last switch over from a Q6600 on a P35 board to an I7 on x58 i didnt do a reinstall and everything went fine , in fact my OS drive even went from sata3 to sata6 without a hiccup and have switched many GPUs without a new OS install
this is something simple such as the heatsink being too tight or a bois setting etc IMO
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
Yes, I'm not saying that it isn't possible that it works fine, I've seen it done before plenty of time. However, my point is that it can not work also.
Open you minds and realize that just because something worked for you, or a few others, that doesn't mean it is going to work every single time.
496 (0.09/day)
I can live with reinstallation but having to reacquire all the accumulated programs I don't have space to back up doesn't interest me.
The magic passed me by, going to have to make my own magic with Window reinstall.
Heatsink looked good to me before I screwed down the mobo. In fact, there appeared to be a small gap between the heatsink and the CPU which concerned me. I checked every BIOS setting I could with no joy.
CDdude55
Crazy 4 TPU!!!
8,178 (1.33/day)
Virginia
Cooling Corsair H70
I prefer to reinstall the OS, as i said, it's best to refresh the OS to the new hardware then to take chances of an unstable system or a drop in performance just because of being to lazy to reinstall.
2,573 (0.40/day)
N.Ireland
Processor Core I5 4440 / 4430
Motherboard Asus z87-k / Gigabyte ga h97- d3h
Cooling Arctic freezer / Generic
Memory 8 gb Mushkin / Various
Video Card(s) Radeon 7850 cf / Gtx 690
Storage Samsung 850 EVO 250 gb / 2x1 terabyte hdds Wd 256 gb nvme
Display(s) Technika 32" / Asus 24` ips
Case Corsair
Audio Device(s) X-fi Titanium
Power Supply Corsair 850 w
If you only see 2 cores in the bios , then it`s more likely to be the chip or the mobo.
theonedub
habe fidem
8,025 (1.47/day)
Northern CA, USA
Don't come at me with that open your mind bullshit, NT1. The definition of never is pretty clear. Its not as if the word 'sometimes' doesn't exist.
496 (0.09/day)
I read on another forum that the All,1,&2 options don't mean all,1 core, or 2 cores. It means All 4 cores, 1 pair of cores, or the other pair of cores. This goes back to the Core 2 Quad configuration of pairing two dual cores.
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
I reworded it to make my point more clear. It is never goint to work properly. It might work, and it might work acceptably for you, but it is always slowed down due to the extra junk in the HAL and registry.
496 (0.09/day)
I am in 8 core paradise now. This thing is hella fast so far but I haven't bogged down Windows with a ton of installations yet. I had to reinstall Windows 7 from scratch for it to think I wasn't still using my old AMD dual core. BIOS still has the same options for the core pairings despite all 8 threads being used. Reinstallation of the OS wasn't an option for me. The technological leap was too great in my case. I advise getting a Core i7 if you can afford it. ^^
CDdude55
Crazy 4 TPU!!!
8,178 (1.33/day)
Virginia
Cooling Corsair H70
Glad you got it worked out.:)
And yes the i7's are monstrous CPU's they pack a hell of a lot of processing power, i love my i7 920.:D
Status
