Need Help With Bad Flash
Discussion in 'AMD / ATI' started by samir151174, Jan 10, 2011.
  1. samir151174 New Member
    Jan 7, 2011
    20 (0.01/day)
    1
    i used atiflash 3.84 but it not worked
  2. Tatty_One
    Tatty_One Senior Moderator Staff Member
    Jan 18, 2006
    17,573 (5.05/day)
    3,330
    Worcestershire, UK
    I will say it again.... your command line is incorrect, should be -f -p 0
  3. Solaris17
    Solaris17 Creator Solaris Utility DVD
    Aug 16, 2005
    17,772 (4.89/day)
    4,030
    Florida
    thnx tatty im not well versed in ATI flashing methodes anymore. would he want to change it to "1" since he is using another card to boot up?
  4. Tatty_One
    Jan 18, 2006
    17,573 (5.05/day)
    3,330
    Worcestershire, UK
    possibly, I am not sure if the "0" or "1" are tied to the PCI-E slots or simply to the boot card, could be that the card that the system boots with automatically is designated as "0"..... I am sure he will eventually work it out! :laugh:
  5. Solaris17
    Aug 16, 2005
    17,772 (4.89/day)
    4,030
    Florida
    I think that part is the same as nvidia. 0 being boot card and 1 2 3 etc being other cards in the next availible graphics slot. so to stop him from bricking his nvidia card it would be
    -f -p 1
    right?
  6. Tatty_One
    Jan 18, 2006
    17,573 (5.05/day)
    3,330
    Worcestershire, UK
    Sounds good!
  7. samir151174 New Member
    Jan 7, 2011
    20 (0.01/day)
    1
    sorry i have installed old pci in slot pci and amy 6870 in pcie but always give a message
    adapter not found
    i have original bios barts.bin then i use last atiflash 3.84
    atiflash -p 0 -f barts.bin
    adapter not found
    atiflash -p 1 -f barts.bin
    adapter not found
    atiflash -i
    adapter not found
    atiflash -ai
    adapter not found
    please where is the problem
  8. Solaris17
    Aug 16, 2005
    17,772 (4.89/day)
    4,030
    Florida
    atiflash -f -p 1 barts.bin
  9. samir151174 New Member
    Jan 7, 2011
    20 (0.01/day)
    1
    adapter not found
  10. Solaris17
    Aug 16, 2005
    17,772 (4.89/day)
    4,030
    Florida
    atiflash -p -f 1 barts.bin
  11. buggalugs
    buggalugs
    Jul 19, 2008
    1,015 (0.40/day)
    180
    Australia
    I learnt some Fronche in school but all i can remember is counting from 1-10. And a few random words.
    Murjuk says thanks.
  12. samir151174 New Member
    Jan 7, 2011
    20 (0.01/day)
    1
    atiflash -f -p 0 barts.bin
    atiflash -f -p 2 barts.bin
    adapter not found
  13. samir151174 New Member
    Jan 7, 2011
    20 (0.01/day)
    1
    atiflash -i
    adapter not found
    atiflash -ai
    adapter not found
  14. Tatty_One
    Jan 18, 2006
    17,573 (5.05/day)
    3,330
    Worcestershire, UK
    It's dead then, however lets first try a different route, download and install Winflash onto your "C" drive, put your "barts.bin" file into the winflash main directory, this procedure probably won't work in winflash in the normal way so we will go a slightly different route.............
    Go into windows,
    - Click Start Button
    - Type "cmd"
    - Right click the entry and select "Run as Administrator"
    - Black command prompt windows opens
    - Type "cd c:\winflash"
    - Type "atiwinflash -unlockrom 0" <-- the 0 means first adapter, try 1 if you have booted to the PCI card
    - Type "atiwinflash -f -p 0 barts.bin" OR again 1 as the case may be
    - It should complete the flashing process with a message saying something with "verified".
    This is a good method because the bios backup file you have may be locked so it covers that angle as well.
  15. sliderider
    Sep 20, 2010
    272 (0.15/day)
    39
    My guess is he thought HD5800 and HD6800 were more closely related than they really are and thought the BIOS of the 5850 might unlock something that wasn't there.
    For the OP, HD6800 is not just an overclocked HD5800 with locked shaders. It's a completely different card. It actually has fewer shaders than HD5800 does, they aren't just locked out by the BIOS. All you can do with HD6800 is overclock it.
    I only hope he doesn't try flashing a BIOS from some other card because that won't work, either. He'll be very lucky if he didn't give his card a fatal voltage jolt from the settings in the 5850 BIOS as it is.
  16. etdavenport
    Jan 23, 2011
    6 (0.00/day)
    0
    Adapter not found
    No offense, I understand that there is a language barrier, but I think your missing entirely what he is saying. I too have this same problem and would love to have an answer.
    For me this is not a problem that happens AFTER you brick a card. Its a problem with atiflash not recognizing the adapter at all in the BEGINNING.
    I am trying to flash a Sapphire HD6970 with the bios form a Asus HD 6970 so i can use the ASUS tweak utilities.[they are what i know already and MSI afterburner will not work]
    The HD6970 has a bios switch that offers a #1 or #2 option, # 2 supposedly being the bios that is protected and #1 the flashable bios. Someone correct me if I am wrong, but even so, I have tried the command atiflash -i on both settings and had the same response "ADAPTER NOT FOUND"
    Again I would like to reiterate, my card is not bricked. It works perfectly fine on both settings. I cannot even get ATIFLASH to admit the fact that I have a card at all, hence the ADAPTER NOT FOUND.
    Some of you have done a wonderful job of harassing our Arabic friend and made this post entirely to long while presenting absolutely no worth while information on the problem let alone any semblance of a solution other than sending the card back for RMA. I personally have a card that works just fine and do not want to RMA it, I just want atiflash to acknowledge the fact I have a card so I can force a bios on it:)
    If anyone Has a solution to my problem I would love any help you may provide. Please I would ask also that you refrain from all the trolling the last gentleman received for asking the same question.
    Also, I am using ATIFLASH 3.84 which has been updated for the 6XXX series.
    SYSTEM:
    Intel I7950 @ 4.025ghz 1.34 vcore
    Asus Sabertooth X58 Motherboard
    6gb G.Skill PI PCS 12800, 1600mhz @ 6-8-6-20 1T
    Western Digital Caviar Black 1tb SATA III
    Sapphire ATI HD6970
  17. Tatty_One
    Jan 18, 2006
    17,573 (5.05/day)
    3,330
    Worcestershire, UK
    2 answers (or questions), I assume you have unlocked the Bios first before you are trying to flash it? And second, are you using the -f force command?
  18. etdavenport
    Jan 23, 2011
    6 (0.00/day)
    0
    I had the wrong atiflash after all
    the version of atiflash i had downloaded as 3.84 was apparently, really 3.79 once I retrieved the correct 3.84 from this site, I had no problem identifying the adapter. and then yes, -unlockrom was what i was forgetting...
    Flash worked just fine, passed with same WEI score and passed Furmark at the same settings It was at previously [900, 1400]
    Unfortunately even with the asus bios, the sapphire card will not let you adjust the voltage. This card was one of the first to come out and is supposed to be a reference version. Sam problem that I am experiencing with MSI afterburner. It will adjust the voltage, just not actually apply it? Typically in my experience if a video card cannot have its voltage adjusted, these programs will tell you that.
  19. Tatty_One
    Jan 18, 2006
    17,573 (5.05/day)
    3,330
    Worcestershire, UK
    Use RBE for voltage if it's for 24/7 volts you need, obviously not the answer if you just want to use it for benching.
  20. etdavenport
    Jan 23, 2011
    6 (0.00/day)
    0
    24/7 is what i need. Problem is, RBE is a pain in the ass to overclock with unless you have a setting that you know already works....I would have to flash the bios each time just to test the vcore setting and see if it was stable...
  21. Tatty_One
    Jan 18, 2006
    17,573 (5.05/day)
    3,330
    Worcestershire, UK
    Well..... when i flashed my 6950 Bios, I used just the modded unlock shaders only XFX Bios, she would not run stable on the stock 1.1V @ 8800mhz, so I increased voltage from 1.1 to 1.15 (a litle less than 6970 stock) and she will now do 910mhz without any noticeable increase in temps (maybe a degree or two). I don't like using 3rd party apps for voltage unless I have no other choice, works for me, I don't bench anymore so a 6970 effectively at 910 is more than I need..... could this not work for you? I didnt even need to do a custom fan curve.
  22. samir151174 New Member
    Jan 7, 2011
    20 (0.01/day)
    1
    what about my problem for 6870 (adapter not found)
  23. Tatty_One
    Jan 18, 2006
    17,573 (5.05/day)
    3,330
    Worcestershire, UK
    Have you read post 75?
  24. Red_Machine
    Red_Machine
    Oct 1, 2010
    1,805 (1.02/day)
    409
    Marlow, ENGLAND
    WE KNOW WHAT YOUR PROBLEM IS ALREADY!
    You have to read our responses and answer our questions. If you must, use Google Translate for god's sake!
    www.google.com/translate
  25. samir151174 New Member
    Jan 7, 2011
    20 (0.01/day)
    1
    [​IMG]
Share This Page
