Need help with components
2,147 (0.35/day)
Metro Manila, Philippines
System Name Zangief (Reborn)
Processor AMD Ryzen R7 1700X @ 3.825ghz , 1.35v
Motherboard Gigabyte GA-AX370 Gaming K7 Rev 1.0 BIOS F51e
Cooling Noctua NH-D15 Push / Push Config | 2x ML120 | 2x Phanteks 120 mm
Memory 2x8GB G.Skill Trident Z @ 3200mhz cl 16 @ 1.45v
Video Card(s) Gigabyte Aorus GTX 1080 +100 core / +550 mem
Storage 250 GB Samsung Evo 850 / 1tb WD Black / 4tb WD Blue / 512GB Adata XPG Pro SX8200
Display(s) Acer Predator XB271HU |Asus VX239H 23" AH-IPS Led
Case Phanteks Enthoo Pro M TG
Audio Device(s) On Board Realtek HD / Logitech G633/G933 Gaming Headset / Corsair H70 Pro Wireless
Power Supply Corsair HX750i
Mouse Logitech G903 and G602 Wireless Gaming | Logitech Proteus Core G502
Keyboard Corsair K70 Cherry Red | Corsair K70 RGB MK.2 Cherry Browns | Akko 3908N TTC Flame Reds
Hey all, it's been a while since I've visited here... Hehe well sort of outdated with things since sandy bridge.
Well me and my buddy decided to venture on a LAN/Net shop business. Well as far as choosing components for the client machine and server machine I'm outdated...
So our requirements are:
Client (10 PCs in total)
Dual-core (decent cpu power) - intel/amd with good board (you suggest again)
GPU (medium range - can handle modern games) - nvidia/amd (depends on the price)
PSU (your call)
RAM (pref 1gb-2gb)
Server:
A good Dual-Tri-Quad (mostly running CS/TF2 server, whilst multi tasking, pic editing,printing scanning and sorts).
PSU (your call)
RAM (pref 1gb-2gb or more if needed)
NOTE: We'll be getting parts from our local store here. So I will attach the price/parts list so that you can help me out in choosing parts. Or suggest better parts/set ups for me.
Thanks in advance!
Psy~
  • pricelist.pdf
2,356 (0.49/day)
VT
Processor Intel i7-10700k
Motherboard Gigabyte Aurorus Ultra z490
Cooling Corsair H100i RGB
Memory 32GB (4x8GB) Corsair Vengeance DDR4-3200MHz
Video Card(s) MSI Gaming Trio X 3070 LHR
Display(s) ASUS MG278Q / AOC G2590FX
Case Corsair X4000 iCue
Power Supply Corsair RM650x 650W Fully Modular
Your best bet is probably waiting for the new Bulldozer lineup and seeing how they pair with most of those tasks, otherwise I reccomend a series of systems like this;
AMD Phenom II 965\955 BE
2x2GB DDR3-1333mhz
Nvidia 460GTX , AMD 6950 1GB , or Nvidia 560Ti depending on price.
For a PSU, I reccomend something relatively good quality like a Corsair 650TX or something. It will save you money and trouble in the long run.
5,061 (0.91/day)
Processor AMD Ryzen 5 7600
Memory Kingston Fury Beast DDR5-5600 16GBx2
Video Card(s) Gigabyte Gaming OC AMD Radeon RX 7800 XT 16GB
Storage TEAMGROUP T-Force Z440 2TB, SPower A60 2TB, SPower A55 2TB, Seagate 4TBx2, Samsung 870 2TB
Display(s) AOC 24G2 + Xitrix WFP-2415
Case Montech Air X
Audio Device(s) Realtek onboard
Power Supply Be Quiet! Pure Power 11 FM 750W 80+ Gold
Mouse Logitech G304
Keyboard Redragon K557 KAIA RGB Mechanical Keyboard
PCExpress is very expensive. You're better off checking prices in tipidpc.com. Actually it's better to ask there too.
You can PM me here in TPU or there in tipidpc if you need help, although I'm about to leave the house so better post in the Help Me Build my Rig thread in tipidpc for now. No mentions of sellers in that particular thread though. But there's an item search function in the site anyway. Most sellers are located in Gilmore, some in Makati, Cubao, Kalookan, Las Piñas, Manila, etc.
2,147 (0.35/day)
Thanks for the feedback yeah, they're expensive. Although we do have other PC parts store nearly accessible to us. Quest Logic in BF homes and PC madness @ festival mall.. YGPM so we can discuss further.
@ALL:
Keep those suggestions coming. Thanks.
Fourstaff
10,024 (1.91/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
Starting a internet cafe needs a lot more considerations than that. Is electricity going to cost a lot? How about initial budget? Budget per machine?
In my mind, you will want to keep overhead as low as possible, so my recommendation is to get a lower powered computer.
Rough sketch: i3 2100 (or if electricity is expensive/budget allows 2100T), 4gb ram, 6870/6950, reliable power supply, about 500gb HDD. Reason why you would want a 2100 is because its an absolute beast in gaming (reliably equalling or beating the Phenom II x4), and consumes quite a bit less power, saving on electricity bill and (presumably) air conditioning.
2,147 (0.35/day)
No worries about air conditioning and power, the shop won't run 24/7 tho, but it'll be open morning til late evening =]
Thanks will consider the processor suggestions.
5,061 (0.91/day)
Case Montech Air X
Mouse Logitech G304
PM sent.
2,356 (0.49/day)
VT
While I agree, I was hesitant to suggest the i3-2100 since I think it suffers a little in multi-tasking compared to the 965. Either option will get the job done to be honest.
I am really unsure how pricing\shipping works in the Phillipines, so definitely find someone that is from that region or does business out there to get the most cost-effective solution.
2,147 (0.35/day)
Well thanks to entropy I've found the store and it's also nearer.
So far:
Client/Server
Intel Core i3 2100
HEC Rapter II 500W PSU
Gigabyte GA-H61M-D2-B3
Western Digital Caviar Blue 500GB SATA3
Gigabyte Luxo M1004 casing
Elixir 2GB DDR3-1333 RAM
GTS 450 (Can consider lowering gpu since mostly clients do only warcraft and other low spec games maybe GTS240 or AMD counterpart)
Fourstaff
10,024 (1.91/day)
Home
I say the GTS450 is a tad too weak, maybe 6850 instead?
2,147 (0.35/day)
We'll take that suggestion, seems doable =) and the price diff ain't that bad! :toast:
5,061 (0.91/day)
Case Montech Air X
Mouse Logitech G304
At 1366x768 it's good enough. Why go with a more expensive card? Just to reach 130+ fps?
EDIT: The closest resolution in the TPU tests would be 1280x1024. The performance/price ratio of the GTS 450 at that resolution is 0.152. The 6850's would be 0.0137.
The GTS 450 is 5000php, the 6850 is 8100php. In raw performance at that resolution the 6850 is ahead by 35%. But you pay 62% of the GTS 450's price to get that 35%.
Fourstaff
10,024 (1.91/day)
Home
Ah, I didnt account for the 1280x1024 resolution and the 35% price increase, because in UK the price difference is not as large (about 20% or less) and I assumed that the scaling will carry (to some extent). If GTS450 is the sweet spot, go for it, but if the sweet spot is a bit higher, I think its wise to go slightly higher, just in case a "crysis game" appears in a year's time.
2,147 (0.35/day)
Thanks for the enlightenment and yeah the prices here are bad enough hahah... As always I love this site and the members as they provide me with valid arguments and informations =]
Thankyou guys you've been all helpful =]
@OT:
I'm planning to "upgrade" my 5850 into something newer any suggestions or would it do for now xD
5,061 (0.91/day)
Case Montech Air X
Mouse Logitech G304
@OT:
That would do, it's still a quite capable card.
If you want to "level-up" from the GTS 450, the HD 6790 is actually looking to be a good deal. A 20% boost in performance with just a 30% increase in price (from 5000php to 6500php). Way better than the 6850's 35% performance boost with a 62% increase in price (from 5000php to 8100php).
