Need help with finding a good USB Wlan adapter
Discussion in 'General Hardware' started by mudkip, Sep 26, 2010.
  1. mudkip
    mudkip
    Dec 14, 2008
    1,226 (0.51/day)
    148
    The Netherlands
  2. mudkip
    mudkip
    Dec 14, 2008
    1,226 (0.51/day)
    148
    The Netherlands
    I was thinking about buying this wlan adapter + a 20dbi antenna.
    Would this combination work? Do you guys have any experiences with this?
  3. 95Viper
    95Viper
    Oct 12, 2008
    4,696 (1.91/day)
    1,805
    στο άλφα έως ωμέγα
    I end up killing them, too; but, you may need to just tweak the adapter.
    I use cheap ones and the best I have found were Rosewill's RNX-N250UB & RNX-N1, I have not had any problems with them, and the RNX-N1 has been going for over a year.
    And they are channel capable for the US, Canada, EU, and Japan
    The RNX-250UB has been on the with netbook with good results. I stream video and audio over them with no problem, even outside on the porch and\or deck.
    The RNX-N250UB uses a newer Ralink RT3072 chipset than the RNX-N1's Ralink 2870+ Ralink 2820 chipset.
    I don't know if you have tried, but...
    1. Turn off power savings for you device in device manager (USB & the device itself)
    2. Make sure you are using the same set of channels(frequencies) as you router.
    3. Set the power(transmission) output on the device and router to maximum.
    4. Under your power options(advanced settings) look for your wireless adapter and set it to maximum performance and under USB settings dis-able selective suspend.
    5. Try not having your body in between the devices; odd, but I had a adapter that was sensitive to this and would dropped the signal a couple of bars.(iPhone syndrome, I guess).
    mudkip says thanks.
  4. mudkip
    mudkip
    Dec 14, 2008
    1,226 (0.51/day)
    148
    The Netherlands
    Thanks but those adapters are not available in the netherlands.
    do you think that the ebay combi is good?
  5. Completely Bonkers New Member
    Feb 6, 2007
    2,580 (0.84/day)
    516
    Dont think that a massive antenna on a regular USB wifi stick is going to help. Unless there is a commensurate increase in output power to match the antenna, it might end up being worse. I tried that trick... buying big antennas for my PCI wifi card... only to find it made diddlysquat difference.
    I have found that a regular USB dongle "n" wifi to be as good as any antenna based PCI or USB.
    Also reach is only as good as your wifi MATCHED with the Access Point wifi. What is your AP?
    95Viper says thanks.
  6. 95Viper
    95Viper
    Oct 12, 2008
    4,696 (1.91/day)
    1,805
    στο άλφα έως ωμέγα
    I'd have to agree with Completely Bonkers on this, as, I also, have tried a couple of different antennas with no real increase in signal; on the wireless card, router and both.
    Go with a known company, not some rip-off no-name brand. Cheap price is good, but cheap price + unknown = Trouble.
    I, also, am fond of the devices that come with the USB extension cable, because you can move the device to a better location, without moving the computer.
    Me, I like Rosewill(as already stated), Trendnet(these you should be able to get in the nederlands), and some Belkins( F7D4101ed or F7D2101ed ).
    Good luck with the adventure.:)
Share This Page
