need help with finding a guide.
Discussion in 'General Hardware' started by echo75, May 1, 2008.
  1. echo75 New Member
    Apr 11, 2008
    456 (0.18/day)
    46
    Denmark
    I discovered my heatsink gave better temps (2-3 C ) lower when i manually apply pressure to it with my hand pushing it against the mobo. Sadly it comes the standard socket 775 intel clips like mechanism, i have decided that i will be finding a way to replace those clips over the weekend to some solid screwiing mechanism .
    i have though of cutting off the plastic clip thingy and putting a screw and washer from behind the mobo ( with a rubber insulator to prevent contact ofc) , then bolting it down from above with a nut.
    Anyone know a guide that shows how i can convert it to a better screw-on mechanism than applies more pressure? just to make things easier for me.
  2. sneekypeet
    Apr 12, 2006
    21,778 (6.78/day)
    6,293
    echo75 says thanks.
  3. echo75 New Member
    Apr 11, 2008
    456 (0.18/day)
    46
    Denmark
    thanks mate youve just given me an idea, i have an old thermaltake and an old gigabyte watercooling system in my basement, between them i should find something i can use.
  4. echo75 New Member
    Apr 11, 2008
    456 (0.18/day)
    46
    Denmark
    woowhoo, just removed the clips and used a srew set from the old thermaltake CPU block and WOW ! i shave of a further 4-5 C from my temps.
    Guys, the heatsink contact to you CPU does matter alot.
    PS- i hope i did not overtighten it :roll:
  5. tkpenalty New Member
    Sep 26, 2006
    6,958 (2.29/day)
    345
    Australia, Sydney
    Yep indeed it does. (Tkpenalty rips off the TRUE's bolt thru screws)
Share This Page
