need help with HTPC build
Discussion in 'System Builder's Advice' started by Fitseries3, Nov 25, 2009.
  1. Fitseries3
    Fitseries3 Eleet Hardware Junkie
    Oct 6, 2007
    15,509 (5.61/day)
    3,107
    Republic of Texas
    im building an HTPC setup cause im getting a HDTV friday.
    i want something decent but low in price. i want something modern like a p55 setup. gaming is probably not going to take place on this machine. it will be for net browsing, HD video and recording video only.
    i have a case and tuner cards already but i need
    mobo
    cpu
    ram
    video card (MUST BE LOW PROFILE)
    hdd
    odd (blueray if price is right)
    psu
    im looking to spend as little as possible within reason. lower is better.
    newegg lists would be great... post away.
  2. King Wookie
    King Wookie New Member
    Jan 1, 2008
    1,197 (0.45/day)
    277
    Johannesburg, South Africa
    I'm no expert, but based on my research, a C2D should be more than ample, but I gather you want something more futureproof.
    AM3 seems good value at the mo. Unless you are waiting for i3.
    And ATI cards seem a better option.
    Just my ramblings.
    Fitseries3 says thanks.
  3. Fitseries3
    Oct 6, 2007
    15,509 (5.61/day)
    3,107
    Republic of Texas
    im an intel and nvidia person but i'll keep an open mind. im more open on the video card than i am cpu.
  4. newtekie1
    newtekie1 Semi-Retired Folder
    Nov 22, 2005
    20,867 (6.05/day)
    6,811
    I would assume the case is mATX, but just want to be sure?
  5. Fitseries3
    Oct 6, 2007
    15,509 (5.61/day)
    3,107
    Republic of Texas
    yes. MATX
  6. gonzominium
    gonzominium New Member
    Nov 11, 2009
    57 (0.03/day)
    5
    Indiana
  7. Fitseries3
    Oct 6, 2007
    15,509 (5.61/day)
    3,107
    Republic of Texas
    dont need silence. has to be matx. no m-itx. sorry.
  8. erocker
    Jul 19, 2006
    40,408 (12.59/day)
    15,057
  9. Fitseries3
    Oct 6, 2007
    15,509 (5.61/day)
    3,107
    Republic of Texas
  10. newtekie1
    Nov 22, 2005
    20,867 (6.05/day)
    6,811
    Soylent Joe and Fitseries3 say thanks.
  11. Fitseries3
    Oct 6, 2007
    15,509 (5.61/day)
    3,107
    Republic of Texas
    BR drives are damn expensive still. i may have to hold off on that idea for a while.
    i can get i5 750 at microcenter for $150 so that helps keep the cost down.
    i like that video card.
    is 1tb needed? would 500gb suffice? i wont be recording alot and most of my stuff is already on my main rig's 1tb drive.
  12. erocker
    Jul 19, 2006
    40,408 (12.59/day)
    15,057
    That AMD dual core is half that price and is more than what is needed for a HTPC build. Any of the 785G boards are fine, but the Asus Evo is the best of the bunch. Asus + AMD have always gone good together. :) I just wouldn't bother to use a Nvidia card with a HTPC. ATi's audio over HDMI works perfectly and image quality in video is superior.
    You don't need much for a HTPC, mine consists of:
    s939 3800+ X2, X1950Pro AGP, 2gb ddr 400. It will playback any video file at any resolution without a problem and has performance to spare. Spending $150 on a processor for a HTPC is not a wise investment.
  13. Fitseries3
    Oct 6, 2007
    15,509 (5.61/day)
    3,107
    Republic of Texas
    so the integrated video on the amd board doesnt cause the NB to overheat or anything does it?
  14. erocker
    Jul 19, 2006
    40,408 (12.59/day)
    15,057
    Nope. Well, maybe if it's a DFI, but the Asus Evo 785g I used in my brothers rig idles along at 34c with the onboard graphics enabled. :)
  15. Fitseries3
    Oct 6, 2007
    15,509 (5.61/day)
    3,107
    Republic of Texas
    how about when playing 1080p content though? just curious
  16. erocker
    Jul 19, 2006
    40,408 (12.59/day)
    15,057
    Oh yeah, works great. Though I have an extrememly slow 1st gen. Blue Ray drive that is tempermental, once it's playing not a problem at all.
  17. Fitseries3
    Oct 6, 2007
    15,509 (5.61/day)
    3,107
    Republic of Texas
  18. sneekypeet
    Apr 12, 2006
    22,015 (6.65/day)
    6,560
    Your mATX with a scalding NB wasnt a DFI:confused:
  19. brandonwh64
    brandonwh64 Addicted to Bacon and StarCrunches!!!
    Sep 6, 2009
    18,941 (9.17/day)
    6,413
    Chatsworth, GA
    I have a M3A78-CM with ATI HD 3200 Onboard and its a AM2+/AM3 mATX that i might be letting go soon
    Crunching for Team TPU
  20. newtekie1
    Nov 22, 2005
    20,867 (6.05/day)
    6,811
    If you don't care about burning from the machine, and you probably don't, a standard Blu-Ray Reader Only goes for $60 on newegg: http://www.newegg.com/Product/Product.aspx?Item=N82E16827106325
    You can find them cheaper if you look, I think fry's just had a sale on one for $40.
  21. Fitseries3
    Oct 6, 2007
    15,509 (5.61/day)
    3,107
    Republic of Texas
    no burning but i would like 1 drive that can read all disks. not just BDroms and it seems some of the BR drives are BDrom only
  22. newtekie1
    Nov 22, 2005
    20,867 (6.05/day)
    6,811
    The one I linked reads everything. Most sold now should read everything.
  23. Fitseries3
    Oct 6, 2007
    15,509 (5.61/day)
    3,107
    Republic of Texas
    id like to go cheaper if i can find one...
  24. Delta6326
    Delta6326
    May 21, 2008
    3,870 (1.52/day)
    682
    Iowa, USA
    This is a good htpc
    $360.95
    Mobo: GIGABYTE GA-MA785GMT-UD2H AM3
    Proc: AMD Phenom II X2 545 Callisto 3.0GHz And if you want to save more money AMD Athlon II X2 240 Regor 2.8GHz either one is good
    Ram: G.SKILL Ripjaws Series 4GB (2 x 2GB) you can of course go with a little slower one to save money
    HDD: SAMSUNG Spinpoint F3 500GB
    Drive: Sony Optiarc Black Or switch that for a BD, only difference in these is that the second one is faster but for a price
    LITE-ON Black
    EDIT forgot to say for a psu if you need one OCZ Fatal1ty 550W its a good deal right now save $20 and its easily enough power i did some calculations and all you need is a 300w PSU and up if you can list your case, im not for sure what size stuff would fit
  25. Fitseries3
    Oct 6, 2007
    15,509 (5.61/day)
    3,107
    Republic of Texas
    i can get cheap ddr3 for like $40 so i dont need anything expensive.
    i like the board but im puzled at the difference between it and the ma785gpmt-ud2h thats a few $ more.
Share This Page
