DocJay35
Thanks for helping me all the info you gave me relly helped me. i have hope now that it will work.
System Name | Super Budget Gamer Thing lol |
Processor | AMD 5600+ Windsor @3.0ghz |
Motherboard | ASUS M3N78-VM AM2/AM2+ Micro ATX |
Cooling | Thermaltake TR2-R1 Ultra Silence CPU heatsink+fan / 3 exhaust case fans |
Memory | 3 Gigs Kingston DDR2@800mhz |
Video Card(s) | PNY 8800GT 512mb OC'd 710/1740/950 - 178.24 |
Storage | 2X 320 gig Seagate Barracuda's @7200rpm - SATA |
Display(s) | 22in Dell LCD 1680X1050 / 21.6in AOC LCD / Hauppauge TV Tuner |
Case | Antec Three Hundred |
Audio Device(s) | Sound Blaster X-Fi Xtreme Audio |
Power Supply | Antec Earthwatts EA500D 500w |
Software | Vista, bby <3 |
Benchmark Scores | yay it works! =] |
Processor | AMD 3900X \ AMD 7700X |
Motherboard | ASRock AM4 X570 Pro 4 \ ASUS X670Xe TUF |
Cooling | D15 |
Memory | Patriot 2x16GB PVS432G320C6K \ G.Skill Flare X5 F5-6000J3238F 2x16GB |
Video Card(s) | eVga GTX1060 SSC \ XFX RX 6950XT RX-695XATBD9 |
Storage | Sammy 860, MX500, Sabrent Rocket 4 Sammy Evo 980 \ 1xSabrent Rocket 4+, Sammy 2x990 Pro |
Display(s) | Samsung 1080P \ LG 43UN700 |
Case | Fractal Design Pop Air 2x140mm fans from Torrent \ Fractal Design Torrent 2 SilverStone FHP141x2 |
Audio Device(s) | Yamaha RX-V677 \ Yamaha CX-830+Yamaha MX-630 Infinity RS4000\Paradigm P Studio 20, Blue Yeti |
Power Supply | Seasonic Prime TX-750 \ Corsair RM1000X Shift |
Mouse | Steelseries Sensei wireless \ Steelseries Sensei wireless |
Keyboard | Logitech K120 \ Wooting Two HE |
Benchmark Scores | Meh benchmarks. |
before i go to bed i would also like to point out this:
if you see that or someone mentions it elsewhere, think nothing of it. its just marketing for nubs. its the EXACT SAME unit as the one you ordered. exact same tech specs, connectors, and power ratings. if their is a difference its in the size by a very small margin. and that is why some Dell owners have said its "too small" or "doesn't fit right" in some cases. so it fits right in some other oddball Dell cases
Dell used to use "proprietary" stuff in its builds. not so much now. the power supply coming out of your 531 is nothing special. its a 300w OEM you can find in any pile for $30. the fact PC Power and Cooling sells a specific "Dell" model otherwise like the one you are getting is mostly hype to make sales. and if in fact its a little smaller to fit some Dell set ups better
but its nearly $40 more and the exact same thing. your mobo was made by Asus. nothing special about it. its a non descript generic OEM mobo. regular connections and power needs, power management, etc. this is the power supply Dell puts in your computer (made by Bestec)
http://www.censuspc.com/Bestec-300W-ATX-Power-Supply-Bulk-SKU-ATX-300D5WB-pr-7482.html
nothing special about it. nothing at all. and the one you're getting is much better. so go forward with your upgrade with confidence
also, since we're talking power, the cheapo way of doing this would be to use these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812263002
you can read the reviews and see how people are using them with Dell's. i can't recommend that to you, but it does work. the problem is you lose the ability to add an additional dvd and hard drive. or lose the use of two if you already have two of each . so your unit can only ever use one dvd drive and one hard drive. + if you want to upgrade again, forget it. 8800GT kind of cards are the psu's limit. you'd be putting yourself in another upgrade situation, basically. so its a definite case of "sooner or later." and its usually sooner
but more so the unit i upgraded had the same set up. it ran fine apparently, but when i checked it out the psu was very warm at idle and under load it made the outer top edge of the case hot. and i mean HOT. which means the psu was hot
now they do get warm. and some things inside them will get hot. but they shouldn't be able to make any part of your case feel like a warm clothes iron. they are supposed to help keep things cool with their fan
so yeah it works, but i could never say 'hey just do this!'
Cooling | D15 |
oh i'm well sure. the Dell Ispiron i upgraded last year has a regular 'ol 24 pin connector. no adapter needed. it was the 530 but i checked at the time and the Ispiron 531 (which is thread starters unit) is the same. just a regular 24 pin connector. i plopped an Antec EA650 in just fine
and the PSU you linked is fine. high quality to be sure. but its EXACTLY the same as the regular unit. it might have slightly smaller physical dimensions, however. which means it wouldn't fit quite right in the Ispiron case, which uses regular ATX
i think its funny PC Power And Cooling should sell "Dell Specific" PSU's that are apparently comaptible with every known Dell ever made, although those Dells all use different mobo's and platforms. they make it sound as if they have cornered the market on Dell PSU's or something. which they haven't. may have been a little true before, but the newer Dell's, and Ispirons for sure, just use regular spec PSU's. the "DELL" 500w PC Power And Cooling Silencer is spec'd EXACTLY as the "regular model." older Dells used to use different voltages, etc. not true any more. they realized people want to upgrade. so its the same thing and is priced about $20 more under normal pricing. with the regular model being on sale it was $40 more. which is just a waste of money
lol most likely yup, dead as door nails....Well thats good o hear there just using standard 20\24 pin connectors now . And in that case sure you can use just about any as you have said. Just best to make sure before you plug it in. Just don't use a cheap one.
I was on the understanding with them that they do them with the custom connectors to as i was after one for my own but yeah if he just need a standard 24 pin one and DELL have not swapped a few of the wires around just any good one will do.
I've known 2 other people with the same model(4550) i used, and all 3 of them were pretty different in side. Topically cheaper the later you got one.
well dude i was inspired by you to keep my computer quiet so i picked up this:Thanks for the info i just orderd a case fan. and it this one SILVERSTONE RL-FM91 92mm Case Fan http://www.newegg.com/Product/Produc...82E16835220001
