Need Overclocking help on Radeon 9600
Discussion in 'Overclocking & Cooling' started by Azure Hydra, Jun 29, 2006.
  1. Azure Hydra New Member
    Jun 29, 2006
    18 (0.01/day)
    0
    I want to overclock my Radeon 9600 (just 9600, NOT pro or anything).
    1.I've herd of flashing the card's BIOS, would that be necesary for a 9600? If it is, how do you do that?
    2.Any good fans I could buy for Radeon 9600?
    3.ATI Tool doesn't let me do Fan Control & Temp Mon. How can I activate that? (and PLEASE don't say you can't with a 9600, last year I had ATI TOOL,old version, and it let me do both of those features). ANYONE got the old versions of ATI Tool? I would GREATLY appreaciate having them.
    4. Anything I need to know about overclocking 9600? Tips and tricks with it (if any)?
    ----Also, what is the fastest, cheapest AGP 8x card I could buy? So far a Radeon 9600XT seems good to me. (looking to buy a card under 80bucks :p only 9600XT fits the criteria so far ^_^ )
    NOTE: I'll be checking this psot often, and replying often to ^_^ New questions always pop up to my mind that need answering!
  2. Aevum
    Oct 26, 2005
    642 (0.18/day)
    11
    Madrid, Spain
    dont bother overclocking that, you aint going to get any worth while results
  3. «BladE|==| New Member
    Jun 26, 2006
    97 (0.03/day)
    0
    Brisbane
    Not trying to be rude or anything, *cough* *looks at previous post* but the guy does have a valid point...go buy an X600 or something...they're cheap right...? Anyway, they have better features...meh, it's up to you. 9600...what? Like, asus, gigabyte...what? And does it already have a fan and heatsink on it?
  4. KennyT772
    KennyT772 New Member
    Dec 21, 2005
    3,585 (1.04/day)
    103
    ok dude listen to me.
    1 your card will overclock to about 460/250
    2 you dont flash these cards
    3 you dont need a better fan
    4 the rv350 has no temp chip the rv360 does but thats the xt core
    5 there are no tricks its just a old sucky card.
    6 dont be stupid and just save up for a x1600 or somthing.
  5. Azure Hydra New Member
    Jun 29, 2006
    18 (0.01/day)
    0
    It has the stock fan and heatsink....I bought it from NovaTech...
    It's incredibly unknown company....but something about ther cards err...don't know stands out a bit :p
  6. Azure Hydra New Member
    Jun 29, 2006
    18 (0.01/day)
    0
    I have an x800 card on my bro's comp....sadly I can't take it back for myself so I stuck with my old 9600.....I get it to 400GPU clock and INCREDIBLE diff when I play Doom 3...
    I wanna if it's save to just turn on the computer set my card to 430Mhz and play for a few hours (card has stock fan on it,very small fan too)
  7. KennyT772
    Dec 21, 2005
    3,585 (1.04/day)
    103
    they dont kick out much heat.
    just let the max core scanner run for about 20 minutes after u set it to the speed u want it to be.
  8. Azure Hydra New Member
    Jun 29, 2006
    18 (0.01/day)
    0
    oh really...so if i put it to like 460/250 like u said, i dont have to worry abot it getting hot?
    I'll probably have it at 435/210. ^_^
    I seriously wanna buy a ball bearing mega size fan heatsink cooling ^_^
  9. KennyT772
    Dec 21, 2005
    3,585 (1.04/day)
    103
    wont do any good. you might get to 500-600ish with voltmodding but thats more work then the cards worth. im gonna be upgrading my 9600xt soon when i build me new system.
  10. Azure Hydra New Member
    Jun 29, 2006
    18 (0.01/day)
    0
    wat's volt modding?
  11. «BladE|==| New Member
    Jun 26, 2006
    97 (0.03/day)
    0
    Brisbane
    Modifing the amount of voltage that is being sent to the card?
    Right? lol.
  12. KennyT772
    Dec 21, 2005
    3,585 (1.04/day)
    103
    yeah thats right.
    azure i can garentee you cannot temp monitor or control fan speed. temp monitoring was only available on the xt's in the 9x00 range so ati could use the overdrive to safley overclock without frying cards. temp monitoring chips became very important on the x800 cards due to the high heat output. also from this heat came the need to control fan speed as people hate loud fans almost as much as dead hardware so they used temp to control speeds to find a happy middleground. none of this was needed on the 9x00 cards so it isnt there.
  13. nick_1992
    Jan 3, 2006
    580 (0.17/day)
    19
    Manitoba, Canada
    very dangerous don't do it if u don't know what ur doing
  14. Azure Hydra New Member
    Jun 29, 2006
    18 (0.01/day)
    0
    huh....yeah, I'm not gonna try Volt Modding LOL
    I'll just stick to ATI Tool and buying better fan and heatsink.
    Umm...is there any other good program like ATI Tool you can use?
Share This Page
