Need recommendations for Cabinet Fans and CPU Cooler
Discussion in 'Cases, Modding & Electronics' started by Recca29, Apr 1, 2014.
  1. Recca29
    Mar 19, 2014
    152 (0.32/day)
    198
    Delhi India
    Hi Guys
    I need some recommendations for adding more cooling to my PC.
    Current System Config:
    Cabinet
    : Antec X1
    Motherboard: ASRock 990FX Extreme 4
    Processor: AMD Phenom II 960T (over clocked to 3.7 GHz)
    RAM: 16 GB Corsair 1600MHz
    HDD: 1 TB Seagate + 2 500 GB Seagate
    PSU: Corsair CX600
    GPU: Gigabyte AMD GV-R777OC-1GD
    CPU Cooler: Deepcool GAMMA ARCHER
    I replaced the Stock CPU Cooler a while back with Deepcool GAMMA ARCHER. It’s silent but very bad in keeping the processor cool, so I added a Cabinet Fan on the side panel, which helps keeps the temps below 75C.
    Now I am thinking of replacing my CPU Cooler, removing the side and front cabinet fans (both LED); and adding 2 Silent fans (No LED) in the Front. will also add a fan controller Deepcool Rockmaster V3.0 later this month.
    I am thinking of buying from the below list
    CPU Coolers:
    Deepcool Gammaxx 300 Cooler
    Cooler Master Hyper TX3 EVO Cooler
    Deepcool Gammaxx S40 Cooler
    Deepcool ICEEDGE 400XT
    Cabinet Fans:
    Corsair Sp120 Cooler
    Deepcool UF140 Cooler
    Feel free to suggest any other model as well.
    Thanks.
    Crunching for Team TPU
  2. micropage7
    micropage7
    Mar 26, 2010
    6,664 (3.46/day)
    1,602
    Jakarta, Indonesia
    Recca29 says thanks.
  3. thebluebumblebee
    thebluebumblebee
    Jul 2, 2008
    3,878 (1.52/day)
    2,805
    Portland, OR
    No wonder you're having problems. That cooler is only rated for 95 watts, and you've OC'd your CPU which comes in either a 95 watt or 125 watt version, IIRC. A TX3 would not be up to the task. You need a Cooler Master 212+ or better. With that case, you may want to consider an AIO water cooler so you can get the heat out of the case as quickly as possible. (install with the fan(s) forcing the air out)
    Corsair SP120 is designed for radiators, not cases. Their AF series would be better.
    http://www.madshrimps.be/articles/article/892/#axzz2xeRE7XDV is a good review of fans.
    Similar thread: http://www.techpowerup.com/forums/threads/need-help-choosing-a-cpu-cooler.197123/#post-3054579
    You're limited to 150MM CPU cooler height. That sucks.
    I'm not the "go buy an AIO" cooler guy, but I do think that it would be the best choice for you.
  4. Devon68
    Devon68
    Jan 25, 2014
    1,137 (2.16/day)
    589
  5. eidairaman1
    Jul 2, 2007
    14,184 (4.85/day)
    2,060
    Scythe Ashura, Bitfenix Spectre Pros
  6. FreedomEclipse
    FreedomEclipse ~Technological Technocrat~
    Apr 20, 2007
    14,629 (4.88/day)
    2,770
    Silverstone Air penetrators are pretty good too. I run 4 of them
  7. Recca29
    Mar 19, 2014
    152 (0.32/day)
    198
    Delhi India
    Not available at my location.
    i can only get Coolermaster, Deepcool, Corsair and Noctua.
  8. Recca29
    Mar 19, 2014
    152 (0.32/day)
    198
    Delhi India
    But they all have LED. i don't want LED Fans.
  9. Recca29
    Mar 19, 2014
    152 (0.32/day)
    198
    Delhi India
    I was thinking about buying AIO but they are expensive. Costs almost 2 to 3 times that of air coolers.
    got an offer for corsair H100 for about 5K(INR) that about 82$ but i think my case doesn't support it.
    Do you think Corsair H60 will do or should i get Corsair H70 or Corsair H75.
    Corsair AF series fans in stock all have LED in them non LED ones are not available currently.
    Thought of Deepcool UF140 Cooler as they are 140mm and fit in 120mm mount space.
  10. Norton
    Norton WCG-TPU Team Captain
    Dec 21, 2011
    10,017 (7.75/day)
    25,452
    If you can find a Noctua NH-U9B, I would go for that.... they're not cheap but they will last and the performance is very good- comparable to lower end water coolers
    thebluebumblebee says thanks.
  11. eidairaman1
    Jul 2, 2007
    14,184 (4.85/day)
    2,060
    they come in non led variants too
  12. Arjai
    Arjai
    Apr 3, 2012
    2,843 (2.39/day)
    5,525
    St. Paul, MN
  13. Recca29
    Mar 19, 2014
    152 (0.32/day)
    198
    Delhi India
  14. Recca29
    Mar 19, 2014
    152 (0.32/day)
    198
    Delhi India
    i don't like the color of these coolers + its too big for my case.
  15. Recca29
    Mar 19, 2014
    152 (0.32/day)
    198
    Delhi India
    Will check with the retailer on weekend. thanks.
  16. Devon68
    Devon68
    Jan 25, 2014
    1,137 (2.16/day)
    589
    Well if those are the choices then maybe (depends on your budget):
    this for the cpu cooler
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835181058
    or
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103179
    and this for the case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835181020
    I use these in my case:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835186033
  17. de.das.dude
    de.das.dude Pro Indian Modder
    Jun 13, 2010
    7,970 (4.31/day)
    2,145
    Mysore
    you sound like you are from india looking at the chocies . Get the corsair Hyper 212 EVO. the hyper TX3 does not work well in out hot climate. and go for corsair sp 120 for the cabinet fans.
  18. Devon68
    Devon68
    Jan 25, 2014
    1,137 (2.16/day)
    589
    He's case doesn't support it. Only coolers up to 150 mm. The hyper 212 is 160mm.
  19. Norton
    Dec 21, 2011
    10,017 (7.75/day)
    25,452
    125x95x120mm for the NH-U9B is pretty small imo.
    Fan colors take a little getting used to but you tend to ignore that when you see how nice their mounting solution is compared to most others and how well they perform.... I did ;)
    Review here:
    http://www.techpowerup.com/reviews/Noctua/NH-U9B_SE2/
    Option B- try a stock AMD heatpipe cooler- they are rated for 125w and should keep an overclocked 960T a lot cooler than the all aluminum AMD 95w cooler and most budget "small footprint" coolers. Ran one of them on a 1045T overclocked to 3.2Ghz and temps stayed around 52-54C at 100% load 24/7
  20. JunkBear
    JunkBear
    Sep 16, 2013
    918 (1.40/day)
    408
    Canada
    Xilence.
  21. de.das.dude
    Jun 13, 2010
    7,970 (4.31/day)
    2,145
    Mysore
    ahh shit. i changed my case to support a hyper 212 lol.
  22. Recca29
    Mar 19, 2014
    152 (0.32/day)
    198
    Delhi India
    Still They are expensive. i will rather go with Corsair H60. Its costs almost the same.
    Cant find the stock AMD heatpipe cooler near my location + i think they are very load.
    The Stock Cooler with the processor keeps the temps below 70c but it screams like a jet engine.
  23. Recca29
    Mar 19, 2014
    152 (0.32/day)
    198
    Delhi India
    Got the Deepcool ICEEDGE 400XT and Deepcool UF140 Cooler yesterday.
    Still waiting for the Corsair AF120 Cooler to arrive
    Will post the temps after installing it tomorrow.
    Currently CPU temps hitting 70c+ at 60% loads after down clocking my CPU back to 3GHz.
  24. Recca29
    Mar 19, 2014
    152 (0.32/day)
    198
    Delhi India
    Installed the CPU Cooler last night.
    The 140mm fan doesn't fit in the case, so could not install it.
    Had to remove the 120mm from side panel and install it in the front.
    Now the temps are as below leaving the System at 100% load all night.
Share This Page
