Need small case for ATX
Discussion in 'System Builder's Advice' started by RCoon, Feb 15, 2013.
  1. RCoon
    Apr 19, 2012
    10,793 (7.21/day)
    8,487
    Gypsyland, UK
    As you can see in my system specs, trying to make a small PC build with the spare parts I've got, and i need a case to fit it all in. Looking for the smallest possible ATX case for my Asus Sabertooth 990fx.
    I'd also like it to be dirt cheap.
  2. the54thvoid
    the54thvoid
    Dec 14, 2009
    4,832 (2.05/day)
    3,428
    The cooler for that 275 is the biggest hurdle.... How long is the entire card?
  3. RCoon
    Apr 19, 2012
    10,793 (7.21/day)
    8,487
    Gypsyland, UK
    290mm long cooler, card essentially the same diameters, double slot width with another half a slot
    EDIT: I do have the original stock cooler, which is a reference tunnel cooler however, if that made things easier.
    Also if it has to be a midi tower case, I want one i can remove all the 3.5" bays on.
  4. the54thvoid
    the54thvoid
    Dec 14, 2009
    4,832 (2.05/day)
    3,428
  5. RCoon
    Apr 19, 2012
    10,793 (7.21/day)
    8,487
    Gypsyland, UK
  6. the54thvoid
    the54thvoid
    Dec 14, 2009
    4,832 (2.05/day)
    3,428
  7. RCoon
    Apr 19, 2012
    10,793 (7.21/day)
    8,487
    Gypsyland, UK
    Seems legit enough. Thanks for the assistance!
  8. the54thvoid
    the54thvoid
    Dec 14, 2009
    4,832 (2.05/day)
    3,428
    A lot of my W/C kit come from Special Tech. It's based in Wales and are very good at communication if you get in touch.
