Need some help overclocking Phenom II 1055T
Discussion in 'Overclocking & Cooling' started by El_Mayo, Apr 26, 2012.
  1. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    Imagine my surprise to see that the automatic timings were at 7-7-7-19
    [​IMG]
    Manually changed them now (assuming those are good settings) gonna try them out at FSB 250
  2. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    Okay so I know NOTHING about timings and I'm still crashing...... (If that's the problem) normally I'd use default or lower ram speed but dammit my RAM is supposed to clock high! That's why I imported it!
  3. Kantastic
    Kantastic
    May 12, 2009
    5,167 (1.67/day)
    996
    Your RAM is supposed to clock high, but you're overlooking other hardware limitations. AMD is notorious for having weaker memory controllers.
    El_Mayo says thanks.
  4. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    Yeah, but I'm not aiming for 2600 tho, just 2200 ish or as high as it'll let me
  5. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    Gonna try AMD Overdrive tomorrow, can't get anything done in the BIOS properly :(
  6. Wrigleyvillain
    Wrigleyvillain PTFO or GTFO
    Oct 13, 2007
    7,693 (2.10/day)
    1,788
    Chicago
    Hey Mayo thnaks again...London is amazing. Partly thanks to you.
    Come in before Sunday and I'll buy you a fantastic dinner at St. Pancras.
    Yeah I coulda sent a pm but this was more fun.
    10 Year Member at TPU
  7. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    On the surface I'm having more luck with AMD Overdrive. It's passing it's built in test, but gonna start running prime95 on it eventually
  8. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    I'm stable now at 225 FSB
    however I had to underclock my RAM, which isn't ideal considering it overclocks well
    Anyone got any advice on overclocking that?
  9. eidairaman1
    eidairaman1 The Exiled Airman
    Jul 2, 2007
    18,553 (4.93/day)
    4,532
    lowering timings on the ram itself will allow it to clock further, even increasing voltage but you need to keep it cool of course
  10. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    I ran a memtest (booted off the disc) on the auto timings at 1800 and it passed
    So now I'm thinking it ISN'T the RAM, but something else...
  11. eidairaman1
    Jul 2, 2007
    18,553 (4.93/day)
    4,532
    autotimings is one thing but running manual is a must for overclocking because when they are auto adjusted you dont know what the value they are running at
  12. HossHuge
    HossHuge
    Jun 26, 2008
    2,300 (0.68/day)
    949
    EDM, AB, CAN
    Hey El_Mayo. Here is how I run my 1055t. If your 1055t is the 95w version, you should be able to do better.
    [​IMG]
  13. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    I'll try n copy your settings :)
    What CPU speed is that?
  14. HossHuge
    HossHuge
    Jun 26, 2008
    2,300 (0.68/day)
    949
    EDM, AB, CAN
    3780mhz. I disable cn'q and everything in my bios but for some reason it still downclocks. I was worried at first but it's stable so....
    Are you o/cing for gaming reasons?
  15. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    Yeah I am :)
    My PC runs pretty quick as it is, so I'm not overclocking out of necessity
    I figure at something like 3.6-4Ghz I'll be able to buy any card (I can afford) without a bottleneck
  16. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    Timings are 11-11-11-39 I think:
    [​IMG]
    Multiplier was 225
    FSB: 2025
    HTT: 2025
    CPU Voltage: 1.225V
  17. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    I've copied your settings and windows won't even boot. It comes up before the os sayilng I've experience hardware failure due to overclocking and that I should revert my settings. I'm getting that error even at 250FSB.
    Here's what I tried
    [​IMG]
    [​IMG]
    [​IMG]
  18. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,666 (5.08/day)
    4,805
    Youngstown, OH
    Try dropping ht link/cpu nb multipliers down to 9x(would be running 2025mhz), ram multiplier to 5.33(or 1066 @ 200bclk), and up bclk/fsb to 225. That will get you dram speed of ~1200, just tighten timings because amd chips like latency try for cl6.
  19. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    I wasn't aware memory speed had to be reduced, I thought they both increased proportionally. I'll try those settings ^
    But I've gotten up to 230FSB, 8 hours stable in prime before, and crashed in 10 seconds playing BF3
    hopefully your settings are stable
    Are these memory timings fine for your suggested settings?
    [​IMG]
  20. JrRacinFan
    Mar 17, 2007
    19,666 (5.08/day)
    4,805
    Youngstown, OH
    Rather loose but good enough to test settings. If you crash then it's cpu core & voltage related. What memory you got?
  21. Wrigleyvillain
    Oct 13, 2007
    7,693 (2.10/day)
    1,788
    Chicago
    Those low profile low voltage Samsugs that can do up to like 2400Mhz depending on platform/IMC.
  22. JrRacinFan
    Mar 17, 2007
    19,666 (5.08/day)
    4,805
    Youngstown, OH
    Keep em where they are at timing wise with settings above that I mentioned and just continue to up bclk/fsb adjusting volts along the way.
  23. Aquinus
    Aquinus Resident Wat-man
    Jan 28, 2012
    10,265 (4.90/day)
    5,342
    Concord, NH
    That sounds like HyperTransport is running too fast and is glitching out when the GPU is running under load, not memory stability. How high are you running the NB and HT?
  24. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    Pretty sure I was running it at 2300 back then
    I just came off 4 hours of GTA IV at my current settings
    [​IMG]
    [​IMG]
  25. JrRacinFan
    Mar 17, 2007
    19,666 (5.08/day)
    4,805
    Youngstown, OH
    Pull HT Link down one 2 multis and go further, same settings everything else. MIGHT need to up vcore & try to keep cpu nb @ your current setting.
    EDIT:
    Could push dram volts up to 1.6v just to help stability there if needed.
