Need some help overclocking Phenom II 1055T
Discussion in 'Overclocking & Cooling' started by El_Mayo, Apr 26, 2012.
  1. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,666 (5.08/day)
    4,805
    Youngstown, OH
    Surely not. Maybe the software doesnt read your rpm sensor right. Go into bios and disable smart fan control to the cpu.
    10 Year Member at TPU
  2. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    Alright, but will that do anything as far as reducing temps?
  3. JrRacinFan
    Mar 17, 2007
    19,666 (5.08/day)
    4,805
    Youngstown, OH
    Might give you a few C drop.
  4. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    Will do now then
    2 hours, 59 minutes w/ 0 errors at 250FSB so far, gonna go for 255 after changing that smart fan setting now
  5. Aquinus
    Aquinus Resident Wat-man
    Jan 28, 2012
    10,264 (4.90/day)
    5,342
    Concord, NH
    Be careful, you don't want you temps to exceed 60*C.
    El_Mayo says thanks.
  6. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    Well it's being a shit. I passed prime for 3 hours, but crashed playing bf3
    gone back to my settings I had at 240FSB (7-7-7-21 timing, 1.2V CPU voltage and stock voltages)
    Edit: crashed IMMEDIATELY at 240fsb now :( what kind of overclock deterioration is this?!
    235FSB is working just fine, I just came off 2 hours of Battlefield
  7. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    It's been plain sailing at 235FSB so far. almost two days gaming and normal use.
    Not sure if I'm ready for the next step though, seeing as something's clearly going wrong somewhere D:
  8. rectifryer New Member
    May 25, 2012
    44 (0.02/day)
    7
    Mine is set at 270 fsb with a multiplier of 14.
    So thats about 3.8ghz and it never goes above 55 celsius at 1.445v for the cpu I believe.
    This is on air, I don't know if this helps or not. I don't use prime95 though as every computer I have tested with it overheats. I am sure its just operator error. I just use 3dmark11.
  9. eidairaman1
    eidairaman1 The Exiled Airman
    Jul 2, 2007
    18,552 (4.93/day)
    4,530
  10. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    What the hell mine's way hot then! I disabled cool and quiet, but still!
  11. rectifryer New Member
    May 25, 2012
    44 (0.02/day)
    7
    I'd agree. I think you have case flow issues possibly as my setup seems to be par for the course with the 1055t.
  12. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    I've got the two fans on and a side fan... do you think the side fan's fucking up my flow?
  13. rectifryer New Member
    May 25, 2012
    44 (0.02/day)
    7
    As a point of full disclosure, most of my knowledge of oc'ing comes from lurking this forum and others, so I am not an expert. However, flow is something I know about.
    Having flow perpindicular to another stream of flow is about the best way to disrupt both of them.
    I do not see any point what so ever in side ventilation if you can support a proper intake and exhaust setup. There are exceptions though, but those exceptions normally require a fan too loud for a normal pc environment.
  14. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    okay, I'll turn off my side fan later and check temps then :)
  15. rectifryer New Member
    May 25, 2012
    44 (0.02/day)
    7
    Make sure you seal that hole and that your case is relatively air tight. I doesn't have to be perfect,, but you want to force the air in then out a specific path making sure appropriate components are cooled.
    If you find you have nothing to seal that holw with effectively, then run all your front and rear case fans in intake mode and your side in exhaust or vice versa. That way atleast they will have a congruent flow.
  16. eidairaman1
    Jul 2, 2007
    18,552 (4.93/day)
    4,530
    proper case flow, front fans intake, rear fans exhaust.
    thats how you keep dust collection down too
  17. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    side w/ EXHAUST? never heard of that one before... any good?
    Yeah I've gone done 8-9 degrees in cpu temps :) (at 245 fsb)
  18. eidairaman1
    Jul 2, 2007
    18,552 (4.93/day)
    4,530
    i was just pointing out that having fans blowing in and none exhausting will cause dust issues
  19. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    ohhhh I got one exhaust and two intakes now :)
  20. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,895 (0.93/day)
    258
    Reviving this thread cos I'm overclocking again
    Just ran 17h 40m of Small FFT, can I safely call that stable or should I run some blends too?
    this is at FSB 222
