Need some help with water cooling .
Discussion in 'Overclocking & Cooling' started by trickson, Dec 14, 2008.
  1. trickson
    trickson OH, I have such a headache
    Dec 5, 2004
    6,494 (1.84/day)
    956
    Planet Earth.
    http://www.svc.com/water-cooling-kit.html
    I have been looking at the units on this site and really want to keep it under or at $200 bucks
    I would like a kit if possible but could use some real help putting together a liquid cooling setup for my CPU only and to keep it as cheap as possible and have it work better than the current offering I have now . It is good trust me ;) . Thank you all for your help in this . :respect:
  2. trickson
    Dec 5, 2004
    6,494 (1.84/day)
    956
    Planet Earth.
    So no one at all can help me out here ?
  3. p_o_s_pc
    p_o_s_pc F@H&WCG addict
    May 2, 2007
    13,008 (4.92/day)
    2,183
    Newark ohio
    trickson says thanks.
    Crunching for Team TPU
  4. trickson
    Dec 5, 2004
    6,494 (1.84/day)
    956
    Planet Earth.
    Thank YOU finally some one has a response for me !
    WOW that one looks sweet . How much of a performance gain should I expect over the current cooling I have ?
    p_o_s_pc says thanks.
  5. p_o_s_pc
    May 2, 2007
    13,008 (4.92/day)
    2,183
    Newark ohio
    I really don't know. I would say about what your idle is now maybe add 10c and that be your load temp?
  6. trickson
    Dec 5, 2004
    6,494 (1.84/day)
    956
    Planet Earth.
    Cool sounds like i am going to be on water cooling soon . :rockout:
  7. p_o_s_pc
    May 2, 2007
    13,008 (4.92/day)
    2,183
    Newark ohio
    what are your temps now?
  8. trickson
    Dec 5, 2004
    6,494 (1.84/day)
    956
    Planet Earth.
    I get idle from 39 - 40c and loaded I see 68 - 70c .
  9. p_o_s_pc
    May 2, 2007
    13,008 (4.92/day)
    2,183
    Newark ohio
    I am almost 100% sure that you will see lower load temps. if you can add alittle more money i would recommend adding another 120mm rad or a dual 120mm rad it would give you even better temps
    maybe this http://www.svc.com/dhwlp.html
    to go along with the kit
  10. Paulieg
    Paulieg The Mad Moderator Staff Member
    Feb 19, 2007
    11,912 (4.39/day)
    2,978
    Wherever I can find the iron.
  11. trickson
    Dec 5, 2004
    6,494 (1.84/day)
    956
    Planet Earth.
    That is good to hear . I will wait and see if any one els has any thing to say before I make up my mind it is a lot of cash to spend and well I am still wondering about the V8 cooler as well any thoughts on that one at all ?
  12. trickson
    Dec 5, 2004
    6,494 (1.84/day)
    956
    Planet Earth.
  13. p_o_s_pc
    May 2, 2007
    13,008 (4.92/day)
    2,183
    Newark ohio
    I have to agree with that :toast: i was just picking from the site that he linked
  14. trickson
    Dec 5, 2004
    6,494 (1.84/day)
    956
    Planet Earth.
    Well it don't matter were I get it from just so long as I can get the best one for the least amount of money ... :D
  15. Paulieg
    Feb 19, 2007
    11,912 (4.39/day)
    2,978
    Trust me, you don't get any better than that kit at that price. The Dtek block is awesome! I have it.
  16. p_o_s_pc
    May 2, 2007
    13,008 (4.92/day)
    2,183
    Newark ohio
    in that case i have to agree with Paulieg. both of them are great but the one that Paulieg linked would give lower temps because of the dual rad and the water block i think is also alittle better
  17. trickson
    Dec 5, 2004
    6,494 (1.84/day)
    956
    Planet Earth.
    OK then thank you so much I will get that one then ! Water cooling is soon going in !
  18. p_o_s_pc
    May 2, 2007
    13,008 (4.92/day)
    2,183
    Newark ohio
    no problem and good luck. most of all have fun! :toast:
  19. Paulieg
    Feb 19, 2007
    11,912 (4.39/day)
    2,978
    Make sure you do your homework on installing and testing. Here is my project log from my first water cooling setup a couple of months ago.
    http://forums.techpowerup.com/showthread.php?t=73434
  20. trickson
    Dec 5, 2004
    6,494 (1.84/day)
    956
    Planet Earth.
    I will have fun thank you so much .
    Thanks for the link it is bookmarked and I will be reviewing it fully as well .
    Thank you all so much ! This is going to be so fun to do !
  21. p_o_s_pc
    May 2, 2007
    13,008 (4.92/day)
    2,183
    Newark ohio
    +1
    but also don't let people scare the shiz out of you like they did me. I had water cooling for a short time but i decided i would rather have the money and i had a friend that wanted some water cooling parts so i was being nice :laugh:
    leak testing is important. water and electronics don't play well together.
  22. trickson
    Dec 5, 2004
    6,494 (1.84/day)
    956
    Planet Earth.
    Agreed I am a little scared but like you asy test it out before it goes into the system . :rockout:
Share This Page
