Need to keep mineral oil cooled. Again
1,113 (0.23/day)
System Name Desktop
Processor Intel Core i5 6600k
Motherboard Asus Z170-E
Cooling Cooler Master 212 Evo
Memory 16 GB Ballistix DDR4 2400
Video Card(s) NVIDIA Geforce GTX 1060
Storage 120GB OCZ Vector SSD & 1TB Western Digital Black
Case Rosewill
Audio Device(s) N/A
Power Supply 630w Raidmax Hybrid 2 RX-630SS
Mouse Logitech G402
Keyboard Rosewill Mechanical
I am aware that i have asked about this before but i didn't want to bring back a thread that was months old so i have made a new one. My question once again is how can i keep mineral oil cooled? Keep in mind i need to keep this somewhat cheap. Not a $10 budget but also not a $300 budget ;)
I have heard of fans and pumps and other things but i need a good solid, effective, easy, cost friendly way to do this.
A science teacher was saying that one of the best ways to keep liquids cool is surface temp. True?
Anyway, thanks for the future help!!!
~Satin
9,899 (1.77/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
Most people have an in/out somewhere in their tank/case and use a pump to push the oil into a radiator.
Like normal watercooling.
brandonwh64
19,542 (3.66/day)
Hmmm as panther said, some type of pump with a radiator but it will not cool but up to so much cause if you are trying to cool gallons of mineral oil then you would need a larger scale cooling loop.
panchoman
Sold my stars!
9,595 (1.57/day)
Processor Amd Athlon X2 4600+ Windsor(90nm) EE(65W) @2.9-3.0 @1.45
Motherboard Biostar Tforce [Nvidia] 550
Cooling Thermaltake Blue Orb-- bunch of other fans here and there....
Memory 2 gigs (2x1gb) of patriot ddr2 800 @ 4-4-4-12-2t
Video Card(s) Sapphire X1950pro Pci-E x16 @stock@stock on stock
Storage Seagate 7200.11 250gb Drive, WD raptors (30/40) in Raid 0
Display(s) ANCIENT 15" sony lcd, bought it when it was like 500 bucks
Case Apevia X-plorer blue/black
Audio Device(s) Onboard- Why get an sound card when you can hum??
Power Supply Antec NeoHe 550-manufactured by seasonic -replacement to the discontinued smart power series
Software Windows XP pro SP2 -- vista is still crap
maybe using a low power tec with cold part in contact with oil, and hot part in contact with a heatsink.. might still need to create a loop to circulate the oil though..
1,113 (0.23/day)
System Name Desktop
Case Rosewill
Audio Device(s) N/A
Mouse Logitech G402
This may seem pretty redneck but....
Is it possible to pump the oil out through a tube, around a rod or piece of metal or something that is filled with nitrogen (no idea where i can get that) and then back into the tank?
Or even fill the pipe with water (freeze it) and run the tube around that to cool the oil.
Possible?
brandonwh64
19,542 (3.66/day)
Possible?
That would cost ALOT to run that 24/7
1,113 (0.23/day)
System Name Desktop
Case Rosewill
Audio Device(s) N/A
Mouse Logitech G402
Wouldnt be running it 24/7. Simply while the computer is on. Plus like i said, i could use ice instead of nitrogen
xbonez
1,182 (0.24/day)
Philly, PA (US)
System Name Winter
Processor AMD Phenom II x4 965 BE @ 4.0Ghz
Motherboard MSI 790FX-GD70
Cooling Corsair H50 Liquid Cooling
Memory 2 x 2Gb Gskill Ripjaws 1600Mhz (7-7-7-24@1.6V)
Video Card(s) Asus GTX 470 @ Stock (Zalman VF3000 cooler)
Storage 2 x Samsung Spinpoint F3 500GB (RAID 0)
Display(s) Hanns G 28" @ 1920x1200
Case Antec 1200
Audio Device(s) Onboard -- TosLink --> Z5500
Power Supply Corsair 850TX 850W PSU
Software Win 7 64-bit Ultimate
The ice wouldn't remain ice for long, and everytime the ice melts, you'd have to fill it up with water and push it into the freezer until it freezes. Using ice-cubes won't work because of the many air-pockets you'd get.
Bo$$
Lab Extraordinaire
5,656 (1.04/day)
London, UK
System Name Desktop | Server
Processor Intel i7 2700k @ 4.6GHZ | AMD 5350 @ 2500MHZ
Motherboard Asus P7Z77-V Pro | Asus AM1I-A
Cooling Corsair H60v2 | Stock Air
Memory Crucial Ballistix 2x8GB CL8 1600MHZ | Corsair Vengence 2x4GB CL9 1600MHZ
Video Card(s) EVGA GTX 1060 6GB | PNY GTX 750Ti
Storage Samsung 840 EVO 250GB + 4TB WD Red | 2x Seagate Barracuda 2TB
Display(s) Samsung S27D390H + Asus VE276Q | Headless
Case Fractal Design R5 | CM Elite 110
Audio Device(s) Asus Xonar D1 w/Otone Stilo 5.1 and Creative Fatal1ty headset
Power Supply EVGA Supernova 850 G2| Corsair CX430M
Mouse Razer Imperator 2012
Keyboard Corsair K90
Software Windows 7 SP1 X64 | Ubuntu 16.04LTS
~Satin
pump through a couple radiators
1,113 (0.23/day)
System Name Desktop
Case Rosewill
Audio Device(s) N/A
Mouse Logitech G402
Hmmm good point. Anyone think there is a way i can use that idea? Without so much hassle?
newtekie1
Semi-Retired Folder
28,472 (4.24/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Use a pump to send the mineral oil to a radiator, the radiator can be found at a junk yard from an old car for extremely cheap if you wish and the pump can be from the local Home Depot if you want something cheap, otherwise use parts designed for computers. Buy the smallest refrigerator you can find that will fit your radiator, usually $50-60 at walmart. Drill two small holes in the side of the refrigerator, and run the tubing into it. Put the radiator inside the refrig. and then seal the holes in the side of the refrig. with "Great Stuff" foam in a can(usually a couple bucks at the hardware store).
There you go, set the refrig on the coldest temperature and enjoy.
MohawkAngel
1,864 (0.33/day)
Car air conditioner radiators are small enough to fit in a case something and fitting after being cut leave small metallic lines perfect to fit ribber hoses with collards on it.
If you see this then its cool enough!
not allowed
1,113 (0.23/day)
System Name Desktop
Case Rosewill
Audio Device(s) N/A
Mouse Logitech G402
not allowed
Really man? Im at school haha. And that didnt get blocked. LOL!
Anyway, i wanted the radiator idea to be a last resort. Any other redneck ideas out there?
jimmyz
95 (0.02/day)
Indiana
System Name Black ice
Processor QX 9650 @ 5ghz @ 1.55v
Motherboard DFI X-38 T2R
Cooling jinu ss in v-2000b+2
Memory crucial ballistix tracer ddr2 1066 asynch 4-4-4-5
Video Card(s) 2 x Radeon 4850 voltmodded watercooled
Storage 4x seagate 250gb in RAID 0
Display(s) 24" SOYO LCD 1920x1200
Case vapoli v2000b+2 (lian-li)
Audio Device(s) onboard karjan audio
Power Supply pc power & cooling silencer 750 Quad
Software windows mce 2005 (xp pro basically) dual boot w/ Vista Home premium.
A refrigerator cannot cool a PC. Even a fairly weak one. All you would accomplish is killing the fridge after a short while of running. The idea is as old as computers and so far it has never worked.
1,113 (0.23/day)
System Name Desktop
Case Rosewill
Audio Device(s) N/A
Mouse Logitech G402
I figured that. Condensation and having to run at such a high power...etc.
4,113 (0.71/day)
Iowa, USA
System Name THE CUBE 2.0
Processor Intel i5 13600k
Motherboard MSI MPG Z690 EDGE DDR4
Cooling Phanteks PH-TC14PE BK 2x T30-120 Fan mod mount
Memory G.Skill TridentZ 3200 MT/s C15 32GB 2x16GB
Video Card(s) Gigabyte Aorus 1080 Ti 11GB OC: Core 2GHz, Mem 5.7GHz
Storage WD SN770 250GB / 3x WD SN850X 2TB / Toshiba X300 4TB / 2x RAID1 Toshiba P300 3TB
Display(s) Samsung 49" Odyssey OLED G95SC 240Hz 5120 x 1440
Audio Device(s) Beyerdynamic DT 880
Power Supply Corsair RM1000X
Mouse Logitech G700
Keyboard Logitech G910
1,113 (0.23/day)
System Name Desktop
Case Rosewill
Audio Device(s) N/A
Mouse Logitech G402
4,113 (0.71/day)
Iowa, USA
Mouse Logitech G700
well around those lines. it tells you what parts you would need can probably get them cheaper at newegg, but that would be what you need.
1,113 (0.23/day)
System Name Desktop
Case Rosewill
Audio Device(s) N/A
Mouse Logitech G402
haha. So any other ideas from anyone?
panchoman
Sold my stars!
9,595 (1.57/day)
getting old rads + a pump is the best idea... refrig is a bit much... and will run your electricity bill quite a lot, and keep your room very hot in the summer..
i wonder if bong cooling works with mineral oil? anybody remember bong cooling? lol
Bo$$
Lab Extraordinaire
5,656 (1.04/day)
London, UK
No the fridge cant, but it's compressor can :toast:
panchoman
Sold my stars!
9,595 (1.57/day)
1,113 (0.23/day)
System Name Desktop
Case Rosewill
Audio Device(s) N/A
Mouse Logitech G402
Might just do the ice thing to simply see if it will work. I know the ice will quickly melt but ehhh. Or what if i were to run tubing through the walls of a mini fridge and out? Would that work? >: )
