New system advice on parts please.
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Processor FX-6300 @ 4.43GHz (1.35v)
Motherboard Gigabyte GA-970A-DS3 rev 1.0 (F6)
Cooling Cooler Master T2 + x2 case fans
Memory 2x4Gb Crucial Ballistix Sport DDR3-1600 (Stock)
Video Card(s) Gigabyte GTX650 Ti OC 2Gb @ 1110/1500
Storage Corsair 240Gb SSD / Seagate 500Gb HDD + old skool IDE HDD's x 3
Display(s) Acer 23'' LED
Case Billy Basic
Audio Device(s) Onboard 8.1 HD
Power Supply Corsair CX600
Benchmark Scores Smenchmarks
Hi all, back on TPU for some much needed advice which is needed badly please. Basically I need advice on building a system from scratch, everything needed barring the OS. Would mainly basically use it for FSX as thats my passion, maybe future proof within budget. Looking to try and keep it within 1k, probably not possible? Would want it to run it flawlessly with all the addons I have taking extra oomph. If any FSX gurus are about that would be even better. So answers on a postcard :)
PS I need a monitor also.
Thanks
682 (0.12/day)
Barcelona, Catalonia, Spain
System Name The Phoenix (rev. 3.0)
Processor Intel Core i9 9900K @ 4.9GHz (1.18V)
Motherboard ASUS TUF Z390 PRO-GAMING
Cooling Custom Full Loop w/EKWB & Swiftech components
Memory 32GB Corsair Vengeance RGB Pro 3200MHz (C15)
Video Card(s) MSI GTX 1080 SeaHawk X EK @ 2.15GHz/5.5GHz
Storage Samsung 970 EVO+ (2x500GB) + Toshiba X300 (4TB)
Display(s) LG 29UM65-P (2560x1080 @ 75 Hz)
Case Thermaltake Core V51
Audio Device(s) Razer Kraken 7.1 & Scarlett 2i4 w/M-AUDIO BX5-D2
Power Supply Corsair RM750 (ver. 2019)
Mouse Logitech G700s
Keyboard Razer Blackwidow Chroma V2
Software MacOS 10.13.6 "High Sierra" & Windows 10 Pro x64
Didn't see that you finally moved the thread, so forget my question there, i'm gonna redo it here.
Are you planning to keep using MacOS (as your current iMac) in any way besides that Windows for FSX?
:toast:
6,862 (1.17/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Benchmark Scores https://www.3dmark.com/spy/34962882
753 (0.18/day)
System Name Chaos
Processor Intel Core i5 4590K @ 4.0 GHz
Motherboard MSI Z97 MPower MAX AC
Cooling Arctic Cooling Freezer i30 + MX4
Memory 4x4 GB Kingston HyperX Beast 2400 GT/s CL11
Video Card(s) Palit GTX 1070 Dual @ stock
Storage 256GB Samsung 840 Pro SSD + 1 TB WD Green (Idle timer off) + 320 GB WD Blue
Display(s) Dell U2515H
Case Fractal Design Define R3
Power Supply Corsair HX750 Platinum
Mouse CM Storm Recon
Keyboard CM Storm Quickfire Pro (MX Red)
Here's a rough ballpark estimate.
You could go cheaper by going for a smaller/cheaper SSD or omitting it completely. However, load times will decrease significantly for a game such as FSX should you opt to keep it. Perhaps you don't need a terabyte of "traditional" HDD storage... Maybe you have an external HDD or something similar - in which case chuck the extra HDD out for some penny-pinching.
FSX is really CPU intensive, especially when you dial "traffic" up to high (or beyond, with addons), thus i5 3570K. You could very well do with a cheaper variant, or perhaps an AMD system, so there's that opportunity to save a few pounds.
GPU requirements are below what I suggest, but for maximum eyecandy, you probably don't want to go much lower (opting for, say, an HD7850 or a GTX660/650Ti). Chance to save some more money.
I'd say the motherboard is spot-on, since it gives the most for money spent. You could potentially pinch up to 20GBP there, but I'd recommend against it. A dedicated CPU heatsink is always welcome to keep noise and temps down. CM 212EVO is a classic, and does well for how cheap it is. I'd leave it, but it's not mandatory.
Case is a matter of taste, so I just suggested the one I like the most. Feel free to go cheaper, down to say Xigmatek Midgard or Antec 902 or Bitfenix Merc Alpha/Beta or something along those lines.
As for the monitor, the U2312HM is blazing-fast (for an IPS), has wide viewing angles, nice colors, and doesn't cost an arm and a leg. Perhaps you'd like a greater diagonal/resolution, but I believe 1080p is sufficient for now. You can always add some more to get a multi-display enjoyment, FSX sure knows how to make the best of it.
The PSU is a bit overkill as far as power requirements are concerned, but you can't go much lower in price without getting lesser quality, and much less power. You could go for a similarly priced Seasonic G 550 to gain a bit more efficiency, if you wanted.
Well, that's all from me, for now. Good luck with your build, and take your time choosing your components!
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
:toast:
The Mac is staying as is for the wife, I have a copy of win 7 so that will be going on the new system :)
That's a good price, I was expecting much more, I never thought about a AMD system as never had one. Will it clock well, not to the edge of it's life but something for me to fiddle with :)
Thanks for the indepth description. I would quite like a SSD so will definitely consider that, I have a few old skool HDD that are still chugging along for storage, 1 is 10 years old and is still kicking into life every time I stick it in my enclosure, it will probs die now haha. Does that i5 clock nicely? Again not to the edge of its life but a good bit more than stock. A nice nvidia will do nicely as I know they are a bit better for FSX. I will have a good look through what you suggest and thank you all, muchly appreciate the help :)
934 (0.16/day)
Texas
System Name Dell inspiron 5570
Processor Intel® Core™ i7-7500U Processor
Motherboard Dell Inc.
Memory SK Hynix 4GB DDR4 SDRAM PC4-19200
Video Card(s) Intel(R) HD Graphics 620
Storage Intel Optane+932GBHDD w/ External Crucial M500 240GB ssd
Display(s) 15.6" w/ Extended display Samsung 27"
Audio Device(s) Realtek Audio
Mouse ONN Wireless
Software Microsoft Windows 10 Home (x64)
Benchmark Scores HaHa yeah right :p
From what I have read Vishera processors do quite well. I have just ordered a 8320 myself based off the reading and from what I read a frequency of 4.5 to 4.7 has been pretty common. Here is a good thread to read up on as well. http://www.techpowerup.com/forums/showthread.php?t=153443
6,862 (1.17/day)
S.E. Virginia
AMD newest CPUs are very good performers. Not quite equal to Intel, but not far off either. Definently worth considering. Add a SSD to the build and it'll be one sweet gaming rig. Also cosider that my build has a 27" monitor as compared to McSteel's build with a 24" monitor. Personally, between the two builds, I'd go with the AMD build with the 27" monitor. I built a system for my newphew using the FX6100, and during the 3 days I had it running before turning it over to my nephew, it impressed me. In everyday use, and some gaming, I couldn't tell a difference between it and my 2600k system.
Oh, and about your comment about AMD/Nvidia video cards. The 7950 is an excellent performing video card capable of equaling any Nvidia card save maybe the GTX680. And even then, with a good OC'ing 7950, it is possible to match a stock GTX680.
12,062 (2.77/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
This. Everything this.
See my system specs for the speed of AMD chips and gpus, they clock to kingdom come, and without crossfire you can hit a 7950 on the head at 1.3ghz core. Max FPS of something stupid like 212... probably on Sleeping Dogs though.
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
If I was to run the OS on a run of the mill 1Tb SATA HDD and FSX off a 256Gb SSD would that work out ok or would I have problems and if I was to go the AMD route would a AMD/ATi GFX card be a better performer than nVidia? Probably a stupid question but I am very much out of the loop when it comes to hardware.
Cheers
377 (0.09/day)
Rizal, Philippines
System Name Poor Man's Build
Processor Intel i7 3960X 4.9Ghz Sandy Bridge E
Motherboard MSi X79A-GD65 8D
Cooling XSPC 240mm and 360MM (External) Rad
Memory 64Gb Corsair Dominator Platinum
Video Card(s) EVGA GTX770 SC ACX SLI (non water cooled yet)
Storage Intel 520 240GB SSD x2 /x2 WD Caviar Black 3TB 7200RPM 64MB Cache
Display(s) ASUS 27" 2560X1440 x3
Case Corsair 900D (upgraded from my lvl 10 gt and 600T)
Audio Device(s) Asus Xonar Essence STX
Power Supply Corsair AX1200i 80PLUS Platinum
Software Windows 7 Ultimate (FPP)
side note: just curious what is FSX?
1,039 (0.18/day)
Frankfurt/Main - Germany
System Name Shaman of Sexy
Processor AMD Phenom II X4 955 BE@4Ghz EK Supreme Block
Motherboard M3A79-T Deluxe Anfi-Tech Waterblocks
Cooling Magicool 360 + 120 + 120 Slim scythe slipped Laing DDC-1/T
Memory 4GB Corsair Dominator CM2X2048-8500C5D
Video Card(s) Sapphire ATI Radeon HD 4870 X2 EK 4870 X2 Block
Storage RAID 0 Seagate
Display(s) Samsung 226BW 22"
Case CoolerMaster Cosmos RC-1000 in mod progress
Power Supply Coba Nitrox 750W
Benchmark Scores http://service.futuremark.com/compare?3dmv=1056967
Cheers
depends on how much u wanna spend ,
a nice AMD setup could look like :
(newegg)
well u could save a few bucks on different hardware pieces....... but if u want 3 years+ of fun that´s a setup i would recommended.......
my old rig is build 2008 and i still run latest games in good modes, without being updated with Hardware
close to your 1k budget:
2,132 (0.39/day)
Chicago burbs
System Name Halloween Boo!
Processor Intel Core i7 3770K
Motherboard Gigabyte Z77-Up7
Cooling Custom Water/ Thermalchill TA 120.3/ Swiftech Apogeee XT/ MCP655/ Swiftech M icrores/ XSPC RX 240
Memory 16G G.Skill trident 2400MHz
Video Card(s) 3 x Radeon 7970
Storage OCZ Revo Drive 240G
Display(s) 24 inch Viewsonic
Case Phobia WayCoolIt Test Bench
Power Supply Nexus 1100 watt
What's the budget?
12,280 (2.37/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
FSX is MS Flight Sim. And no put your OS and FSX on the SSD
Aquinus
Resident Wat-man
13,147 (2.96/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
what's the budget?
Then read the OP again. He did say what his budget was. No need for caps either, we're not grilling the guy.
I suspect he means 1k in £ since he lives in the UK. Correct me if I'm wrong, Alcpone.
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
Yeah 1k = 1 thousand £.
I thought the best way to go with FSX was to have it on a separate HDD to the OS?
£1200 is probably abit much to justify it to the one in charge haha.
I just want a system that will run FSX and all my addons at full eye candy with headroom for the future and so I can clock the CPU and GFX but not have to change the GFX cooler so will be very moderate clocking on that.
Writing in CAPS is not needed as my eyesight is fairly good :)
JrRacinFan
Served 5k and counting ...
20,073 (3.23/day)
Youngstown, OH
System Name Dual Build Streamer
Processor Ryzen 7900x3d : Ryzen 4600G
Motherboard AsRock B650E Steel Legend : Giga B450i Aorus
Cooling Custom Water 1x420 : Stock
Memory 32GB T-Force Deltas : 16GB Dominator Platinums
Video Card(s) PowerColor 7900 XTX Liquid Devil: iGPU
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Custom White Painted Phanteks Enthoo Pro 2
Audio Device(s) Onboard : Onboard
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Hyperx Origins 65
377 (0.09/day)
Rizal, Philippines
868 (0.16/day)
London, UK
System Name The one under the desk / Media Centre
Processor Xeon X3730@3.6GHZ / Phenom II X4 805E
Motherboard Gigabyte P55M-UD4 / Asus Crosshair III
Cooling Corsair H70 + 2*PWM fan / Arctic Alpine 11
Memory 16GB DRR3-1333 9-9-9-27 / 4GB Crucial DDR3-1333
Video Card(s) Asus DirectCU GTX 680 / Gigabyte 560TI
Storage Kingston V200 128GB, WD6400AAKS, 1TB Seagate 7.2kRPM SSHD / Kingston V200 128GB
Display(s) Samsung 2343BW + Dell Ultrasharp 1600*1200 / 32" TV
Case C'M' Silencio 550 / Some ancient SilverStone brushed aluminium media centre
Audio Device(s) No.
Power Supply Thermaltake Toughpower XT 675W / EVGA 430W
Mouse Mionix Naos 3200 / Generic PS2
Keyboard Roccat Ryos TKL Pro / Evoluent Mouse Friendly Keyboard (Logitech OEM)
Software Windows 7 Ult x64
Benchmark Scores Nah.
It'd work, but I don't see why you wouldn't put both on the SSD. You can always relocate My Documents, My Music etc. to the HDD.
Cheers
That very much depends on the particular cards in question. What I will say is that current gen AMD cards are having some driver issues, which are not yet fully resolved in all games - see the last few articles at http://techreport.com/graphics/.
Anyway, he's my recommended build. It's a little overkill, as FSX is a fairly old game now, and your budget is £1000. You could play this game very comfortably for half that. I'm presuming here that you're into overclocking. I'm also presuming that you don't need an optical drive, what with it being 2013 and all.
http://uk.pcpartpicker.com/p/Bh17
1,039 (0.18/day)
hi,
i think you have been introduced to enough systems....
it´s up to you to pick one and make your choice
they all run FSX smooth..... take your gear
if u find some betta & cheaper let us know, we all gonna buy there then :p
:toast:
if u count all mail & send fees u are over 1k :p
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
Thanks for the replies. I will have to make a decision on what to get, most likely a AMD chip with a nVidia card. With FSX taking up a fair chunk of 200Gb on my current system I might need to get a chunk sized SSD : )
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
What do you guys think of this setup? Anything that won't work together?
Cheers
2,356 (0.50/day)
VT
Processor Intel i7-10700k
Motherboard Gigabyte Aurorus Ultra z490
Cooling Corsair H100i RGB
Memory 32GB (4x8GB) Corsair Vengeance DDR4-3200MHz
Video Card(s) MSI Gaming Trio X 3070 LHR
Display(s) ASUS MG278Q / AOC G2590FX
Case Corsair X4000 iCue
Power Supply Corsair RM650x 650W Fully Modular
Not bad, but I'd consider the FX-8320, since it shouldn't cost much more and you get a fantastic CPU for heavily threaded applications. Not sure how FSX is threaded, but I know most simulation-based games tend to go bananas when it comes to threading, so it may be in your best interest. It also buys you a tiny bit more future-proofing.
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
Do you think a faster 1gb gfx card will be a better buy than a slightly slower 2gb? Cheers
Aquinus
Resident Wat-man
13,147 (2.96/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
No, invest in a 2Gb card, you will be glad you did long term. A powerful 1Gb card will work better until you run out of VRAM which hits your performance a lot harder than a slightly slower card with more VRAM.
868 (0.16/day)
London, UK
Audio Device(s) No.
Cheers
Why that particular case and PSU?
And what put you off an SSD?
Also, what are you going to use the optical drive for?
