Nirvana 120mm Fan header 3-pin, but mobo cpu-fan header 4-pin, wat to do ?
Discussion in 'General Hardware' started by wolf2009, Apr 14, 2008.
  1. wolf2009 Guest
    Heatsink : Zerotherm Nirvana 120mm
    Mobo : GIGABYTE EX38-DS4
    mobo cpu-fan header is 4 pin , while heatsink fan header is 3 pin , how do i connect ?
    10 Year Member at TPU
  2. sneekypeet
    Apr 12, 2006
    22,807 (6.36/day)
    7,373
    it will still work, the clip should still fit the pins with the tab as well!
  3. DOM
    DOM
    May 30, 2006
    7,551 (2.13/day)
    828
    TX, USA
    it still works just make sure you align the 3-pin header to the tab from the 4-pin ;)
  4. panchoman
    panchoman Sold my stars!
    Jul 16, 2007
    9,595 (3.07/day)
    1,201
    aline the notch on the 3 pin header with the 4 pin header, like so:
    [​IMG]
  5. wolf2009 Guest
    thx , but will i be able to control the fan through bios ?
    will the fan spin at its lowest speed by doing this ?
  6. hat
    hat Enthusiast
    Nov 20, 2006
    17,679 (5.25/day)
    2,513
    Ohio
    It will work just like if the header was 3 pin. The last pin is for PWM support. Your fan will work just fine.
    Crunching for Team TPU
  7. panchoman
    Jul 16, 2007
    9,595 (3.07/day)
    1,201
    you should still be able to control the fan through software or the bios, and it should spin at full speed if you dont have fan speed configurations in the bios.
  8. t_ski
    t_ski Former Staff
    Apr 11, 2006
    11,634 (3.24/day)
    5,720
    Have you read the review here at TPU? Here's the link:
    http://www.techpowerup.com/reviews/Zerotherm/Nirvana120Premium
    Here are the pics from the review:
    I would recommend using the fan controller from the Nirvana, as it can make the fan ultra quiet when not needed.
