Hey, I am new to these forums and I just signed up to see if you guys could help me out with a problem I've been having. You seem to be able to solve a lot of problems so lets see if anyone of you guys can help me with mine. I am not the brightest with computers though I know my way around them good enough to build them. So if its possible try not to use to many big words
About a month ago I swapped out my X1650 Pro for my Radon Sapphire X1900 GT. Ever since I did this, when I reboot my computer my monitor will get " No Signal ". The only way to get a signal again is to wait 3 or more hours.( Note it doesn't even show the bios ) Then it will work just fine again. This is what really confuses me. I have tried many things and so far nothing has worked. Hopefully you can give me some ideas to fix it other than buying something new because I am low on cash.
Somethings I tried to fix it that hasn't worked:
- First I thought it was drivers so I uninstalled all my drivers, used driver cleaners, and etc. With all my drivers gone I was still having the problem so I believe it wasn't drivers.
- Second I thought it might be something on the hard drive, so i completely unplugged the hard drive and i still can't get to the bios and no picture shows up.
- Third I thought it might be the monitor, so i tried my old CRT and I still didn't get a picture.
- Forth I thought maybe I don't have enough power (wattage wise), I tried unplugging everything except the ram, video card, processor, still no picture. *note the video card fan works, all the computer fans work, the LEDS, and everything seems to be getting power. I have a 500 WATT power supply.
- Fifth I thought the video card might be overheating, that would explain why I have to wait for 3+ hours before I can get a signal again. Though i checked the temp and it was about 50C warm but not burning, and I felt the video card to, to make sure there was no hot spots. None. *note I can use the computer for hours and hours of gaming with no problems or crashes. Just once i restart it won't turn back on for a couple hours.
-Sixth I thought there might be something wrong with the video card, I tried it with another computer and everything works fine on that computer. It even has a weaker power supply 450 WATT.
-Finally I thought it might not be compatible with my motherboard m2r32MVP. I looked around and saw other people using the video card with it just fine. Also, I thought i just try and update the bios and chipset though i am a noob and i am not positive how to do it. I heard you can really screw over your computer by messing with it though so i figured to leave it alone for now i don't want anymore problems.
I am really confused and sick of this problem. If anyone could give me some advice on what I should try next, or what I could do to fix my problem I would be very grateful.
Thanks
- I tried clearing CMOS, and tried to drain the capacitors and remove the battery. Still no luck.
- I also tried different RAM in my computer and still no luck.
- I am 100% sure it is not drivers related.
- My graphics card takes 25AMPS my power supply has 29 AMPS to give out. ( http://www.newegg.com/Product/Product.aspx?Item=N82E16817153052 )
Thanks
