Northbridge cooling for AW9D-Max
Discussion in 'Overclocking & Cooling' started by JrRacinFan, Apr 11, 2008.
  1. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,419 (6.56/day)
    4,495
    Youngstown, OH
    Yup, starting to have overheating on my northbridge. Guys think this or a Thermalright HR-05 would fit with my Scythe Ninja?
    Does anyone have a Thermalright HR-05 that they are not using and wouldnt mind selling it?
    [​IMG]
    EDIT: Added Pic
  2. HTC
    HTC
    Apr 1, 2008
    2,259 (0.88/day)
    308
    I've got the Noctua NC-U6. It's passive but, although it doesn't have fan support, that doesn't mean you can't add one to it. If only my P5K-SE supported NB temp monitoring, i could tell you the difference between the original and the new one.
  3. JrRacinFan
    Mar 17, 2007
    19,419 (6.56/day)
    4,495
    Youngstown, OH
    Hmmmm, think it would fit HTC?
  4. HTC
    HTC
    Apr 1, 2008
    2,259 (0.88/day)
    308
  5. JrRacinFan
    Mar 17, 2007
    19,419 (6.56/day)
    4,495
    Youngstown, OH
    I wonder if I get one if I could fit a slim 120mm in between it and the scythe. Hmmmm ...
    PM me with your locale and maybe some heatware or ebay feedback. I may just go ahead and buy it off you depending on condition.
  6. HTC
    HTC
    Apr 1, 2008
    2,259 (0.88/day)
    308
    Don't think so: the fin's height is only 66.1 mm.
  7. intel igent
    intel igent New Member
    Jun 5, 2005
    4,641 (1.29/day)
    434
    Toronto, Canada
    JrRacinFan says thanks.
  8. JrRacinFan
    Mar 17, 2007
    19,419 (6.56/day)
    4,495
    Youngstown, OH
    I can look around for something but probably nothing that small to be worth it. I wonder .....
  9. intel igent
    Jun 5, 2005
    4,641 (1.29/day)
    434
    Toronto, Canada
    fonsan (delta) makes a great little 40mm x 20mm fan heres the part #DFB0412H
    i picked up a couple of them for $3.99 at a local surplus store ;)
    :toast:
  10. HTC
    HTC
    Apr 1, 2008
    2,259 (0.88/day)
    308
  11. JrRacinFan
    Mar 17, 2007
    19,419 (6.56/day)
    4,495
    Youngstown, OH
    @htc
    According to those pics that from what I can see it will be tight but will fit.
    @intel
    If I do go just the fan route, should I mount the fan on the top or the bottom side closes to the video card blowing the "fins"?
  12. sneekypeet
    Apr 12, 2006
    21,990 (6.67/day)
    6,531
    you do realize you will have to "cut" the pipe to remove the NB cooler?
    Ketxx says he chopped his and put a fan type cooler on his. Personally it never really overheated on me, but I have really good case ventilation.
  13. HTC
    HTC
    Apr 1, 2008
    2,259 (0.88/day)
    308
    It can be rotated up to 120ยบ in order to evade compatibility issues.
  14. JrRacinFan
    Mar 17, 2007
    19,419 (6.56/day)
    4,495
    Youngstown, OH
    @sneeky
    Or replace all thats included with the pipes. Which I am willing to do.
    would you consider 45-48C idle too hot?
    @htc
    thanks again
  15. HTC
    HTC
    Apr 1, 2008
    2,259 (0.88/day)
    308
    You're welcome.
    Here's a pic of the "manual":
    http://i87.photobucket.com/albums/k145/HTC1325/img002.jpg
    Btw: won't replacing all that's included with the pipes, or even some of it, void the warranty? I ask because i'm thinking of getting a rampage formula, when i have the cash for it later on, and it has lots of pipes too.
  16. sneekypeet
    Apr 12, 2006
    21,990 (6.67/day)
    6,531
    PWM is the temp of the 4 phase chips that power the CPU IIRC.
    @HTC...it will most certainly void the warranty!
  17. JrRacinFan
    Mar 17, 2007
    19,419 (6.56/day)
    4,495
    Youngstown, OH
    @htc
    Bought it from sneekypeet. Warranty is a non-issue at this point.
    @peet
    So what would it mean then, I can touch the northbridge it feels very warm to me. Like little warmer than a hot cup of coffee so to speak.
    EDIT: Warranty? You mean its still good on it? Its transferrable?
  18. HTC
    HTC
    Apr 1, 2008
    2,259 (0.88/day)
    308
    I see, hehe. And if it were a new one, would warranty be voided?
    EDIT
    Nvm.
  19. sneekypeet
    Apr 12, 2006
    21,990 (6.67/day)
    6,531
    I agree the NB is hot on that mobo, but if anything it would be a system temp or mobo temp.
    Warranty...i never registered it...take that how you want to!!!!!!
  20. JrRacinFan
    Mar 17, 2007
    19,419 (6.56/day)
    4,495
    Youngstown, OH
    So really, it's normal then? Hmmm ...
  21. sneekypeet
    Apr 12, 2006
    21,990 (6.67/day)
    6,531
    well the TIM could have degraded and its getting hotter than I had it here!!!!
    May want to start off just replacing the TIM as suggested and see where that leaves ya!
  22. intel igent
    Jun 5, 2005
    4,641 (1.29/day)
    434
    Toronto, Canada
    doesnt really matter as long as its getting air
    ive got that little fan screwed into the top of my N/B
    :toast:
  23. HTC
    HTC
    Apr 1, 2008
    2,259 (0.88/day)
    308
    Once, i had an Asus motherboard and, when i bought a 56 external modem (yeah: that long ago ...), i found out it wasn't detected. After a while, i found out the problem: the COM 2 port was damaged which meant that i could either use the mouse or the modem, but not both.
    I was lucky because i found this problem 1 week before the end of the warranty so i took it to the store i bought it from right away and it was fix @ no charge.
    A few years back, i had a 9700 PowerColor video board and i had the distinct bad luck of it getting corrupt memory 1 month after the warranty was over ...
    Back then, the warranty was of 1 year only.
    Warranty has it's perks, i believe.
  24. JrRacinFan
    Mar 17, 2007
    19,419 (6.56/day)
    4,495
    Youngstown, OH
    Gotcha, I got some ceramique and cheap Dynex silver (BestBuy), which should I use?
    @htc
    Really not worried about any warranty, if I need a new board I will just buy a new one.
  25. intel igent
    Jun 5, 2005
    4,641 (1.29/day)
    434
    Toronto, Canada
    ceramique FTW!
Share This Page
