Note- 4850 CROSSFIRE AND CERTAIN SETUPS DO NOT WORK WITH 8.10 (HOTFIXED)/8.11
Wile E
Power User
24,318 (3.79/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
Well I have just the one in ATM, I am defeated for the time being, might have another go at the weekend, what surprises me though is how smooth COD World at war runs on just one of these cards at 1920 x 1200, albeit I know the card has 1GB of memory and I run the game for long bursts at 790mhz, I guess at that speed it's as fast (ish) as a 4870.
When Xfire was working, at just 735mhz my 2006 scores are only marginally less than Xfired 4870's.
I even tried the Cat 8.7 drivers that everyone says was the last problem free driver set with crossfire but same error messages and BSOD, maybe these drivers dont like cards with flashed BIOSes that raise the upper limits?....be nice to hear from someone else who has got theirs working if they can keep it working with a flash.
You never know, you might get a belated Christmas present!
Even with my single card, i had issues with a flashed BIOS Tatty. I gave up and just did the hard-vmod, and use Riva to clock now. I'm on 8.10's, atm.
Tatty_Two
Gone Fishing
25,801 (3.87/day)
Worcestershire, UK
Processor Rocket Lake Core i5 11600K @ 5 Ghz with PL tweaks
Cooling Thermalright Peerless Assassin 120SE + 4 Phanteks 140mm case fans
Memory 32GB (4 x 8GB SR) Patriot Viper Steel 4133Mhz DDR4 @ 3600Mhz CL14@1.45v Gear 1
Video Card(s) Asus Dual RTX 4070 OC
Mouse Coolermaster Storm Octane wired
Keyboard Element Gaming Carbon Mk2 Tournament Mech
Software Win 10 Home x64
Strange, I have had no issues at all on a single card, and strangely enough, on the single, without BIOS flash I could exceed the 735 upper limit with Rivatuner, as soon as 2 cards are in, without the flash, anything above 735 with rivatuner crashes, I think I will just end up eventually flashing back (again) and going with 2 cards at 735 24/7, thats gotta be faster than one card at 800 but I just really HATE not getting the most out of my hardware, there just has to be a fix somewhere :cry:
40,435 (6.59/day)
ask the devs of Rivatuner/Ati Traytools
James1991
267 (0.04/day)
Port Lincoln, South Australia
Processor i7 2600
Motherboard ASUS P8P67 EVO
Cooling lots and lots of fans
Memory 8GB DDR3
Video Card(s) 2 x ATI(yes, ATI) Radeon 4850
Storage lots of 500 gb drives
Display(s) Acer P221W, LG L1732S, Samsung 32 inch HDTV
Case big one
Audio Device(s) onboard stuff
Power Supply big one
Software Windows Vista Ultimate x64
Benchmark Scores boots into windows is that ok?
.....I even tried the Cat 8.7 drivers that everyone says was the last problem free driver set with crossfire.....
8.7 was the first one that started giving me problems, 8.6 worked fine though:)
643 (0.11/day)
System Name PIA
Processor Ryzen 5 3600
Motherboard ASRock B550M Steel Legend
Cooling Corsair H50
Memory 2x8GB Gskill DDR4 3600
Video Card(s) MSI GTX 1660 Super
Storage Samsung EVO 970 1TB
Display(s) 2xAOC Curved 24" 144hz
Case Cooler Master MasterBox Q300L
Power Supply CORSAIR RMX (White) RM750x
Mouse Logitech G305
Keyboard Logitech G915 TKL
I'm using 8.7 and it's been nothing but good since I started this thread.
Tatty, I heard from somewhere that someone couldn't flash past 735 with there crossfired 4850's, but could do past 800 with single cards. I have yet to pencil mod my other 4850, but i know my one 4850 was doing 800 for benching and 750 for daily usage. Maybe it is driver's now, they don't like the high clocked 4850's :/
Tatty_Two
Gone Fishing
25,801 (3.87/day)
Worcestershire, UK
The more I think about it the more I reckon your spot on, I have tried absolutely everything and conclude you cannot flash higher upper limits on cards in crossfire, on that rare occasion I have got it to work for a few seconds before BSOD even with upper limits flashed to 800, I get error messages in any bench above 735 so it has to be driver/software restriceted, ATi probably dont want 4850's in Xfire overclocked so much as they compete with the 4870x2 which in a way makes sense but is frustrating, even at 735 in XFire I can hit almost 24,000 points which is near to 4870x2 territory............ looks like a flash back is on the cards.
40,435 (6.59/day)
You Would have to Reverse Engineer ATI Drivers like Omega Does, along with what Team UniAn Used to do.
643 (0.11/day)
System Name PIA
Cooling Corsair H50
Mouse Logitech G305
You probably can hit higher the 735 with older drivers right? I know I've seen a few clocked higher then 735 back when I bought my first one and they were in crossfire.
"ATi probably dont want 4850's in Xfire overclocked so much as they compete with the 4870x2 which in a way makes sense but is frustrating"
They better not be purposely doing that. If I'm sacrificing my warranty for this I shouldn't have drivers designed to keep me low. They should spend more time working on getting the 4850 crossfire to work in the first place without all this hassle.
43,586 (6.72/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Speaking of which, has anyone tried using Omegas or nghq drivers?
Tatty_Two
Gone Fishing
25,801 (3.87/day)
Worcestershire, UK
Nope, even in 8.11 and 8.12 on the 2 occasions I actually got them to work (before restarts led to BSOD after they were working) even with the modded BIOS to 800 with overdrive disabled and clocking both cards in Rivatuner they errored all the way from 800 down to 740, as soon as I dropped to 735 they worked.
Tatty_Two
Gone Fishing
25,801 (3.87/day)
Worcestershire, UK
I took a look at their sites today, I could not see any recent modded drivers, the last i think i found were 8.9's.
643 (0.11/day)
System Name PIA
Cooling Corsair H50
Mouse Logitech G305
Thats what I mean, drop back down the 8.6-8.7 drivers
If you have the time, drop down to those drivers and test with 800 both flashed and OC'd in rivatuner. I have a feeling it will work.
Tatty_Two
Gone Fishing
25,801 (3.87/day)
Worcestershire, UK
No already tried it with 8.7.........could not enbale crossfire without BSOD with modded BIOS, the only time it has consistently worked for me was on 8.11 without modded BIOS.
643 (0.11/day)
System Name PIA
Cooling Corsair H50
Mouse Logitech G305
hmm, idk... I could of sworn I saw people with 800 core with 4850's in crossfire...
Wile E
Power User
24,318 (3.79/day)
Did you try modding the bios without updating the Overdrive profile? Just flash the clocks to 800, and leave all other settings alone.
Tatty_Two
Gone Fishing
25,801 (3.87/day)
Worcestershire, UK
Hmmmm never thought of that, so you reckon if i flash to, lets say to be safe....775 the card will still boot even though the upper limit is 735? I would have thought the driver would have gone....wtf? pfffft......dead??
Tatty_Two
Gone Fishing
25,801 (3.87/day)
Worcestershire, UK
Find em.....find.....em......then find them again!
Wile E
Power User
24,318 (3.79/day)
Not if you leave Overdrive disabled I think. At least that's the way it was with my 2900. Haven't tried with this 4850 yet.
James1991
267 (0.04/day)
Processor i7 2600
Memory 8GB DDR3
Case big one
Flashing above the overdrive limits does work. it just says on the overdrive part of catalyst that "overdrive something has not been initiated" or something like that.
I did it on my HD2600, so unless they have changed something then it should work.
Tatty_Two
Gone Fishing
25,801 (3.87/day)
Worcestershire, UK
I'll give it a try then! I will do it one at a time and boot up with the one card just to make sure all is well......I'll report back tomorrow!
643 (0.11/day)
System Name PIA
Cooling Corsair H50
Mouse Logitech G305
Is there an agreed upon method that will get 8.12 to work with 4850 crossfire?
Tatty_Two
Gone Fishing
25,801 (3.87/day)
Worcestershire, UK
Dont know, I have RMA'd one of the cards, should have a new one back in about 5 days, i'll let you know then as I will be trying the method above.
643 (0.11/day)
System Name PIA
Cooling Corsair H50
Mouse Logitech G305
bump?
43,586 (6.72/day)
Storage WD m.2
Keyboard Tester84
I know Asus just released a new bios for the Maximus, supposedly fixing 4850 crossfire. Isn't there also an 8.12 hotfix?
643 (0.11/day)
System Name PIA
Cooling Corsair H50
Mouse Logitech G305
NOTE- I LIED! lol
I found a way to get my 4850 crossfire working with 8.12!!
Easy Work Around: CrossfireX on Cat 8.12 is working great for me now.
1) Boot into the OS, make sure you completely remove all existing ATI drivers.
2) Install the complete Cat 8.10 Drivers which is known not to have any issues then restart.
3) Boot into Windows, then make sure CrossfireX is enabled in the Control Centre. Now install the Cat 8.12 drivers without removing the 8.10 then once again restart.
4) Boot into the OS with "Safe Mode" w/ networking. Go to Admin Tools (In Control Panel), then Services, then "Disable" ATI Extermal Event (Utility or Service). Should be somewhere in the top.
5) After that, restart your PC and boot into your OS normaly.
6) Get into the Control Centre and go into the CrossfireX section, make sure the CrossfireX is checked off. If not, check it then restart your PC.
AMD/ATI should know that this "ATI Extermal Eventa" is causing all the problems.
I need to add to this though!!
While installing the 8.12's over the 8.10 you will experience a brief blueness on your screen that might cause you to die. This is called a BSOD. IGNORE IT! and then proceed to disable the ATI EXTERMAL EVENTA.
This works for me and I have crossfire enabled!!! I did it on a fresh install of windows pissta.
