nVidia 8800 GTS video card But plug into PC Power cuts do not work
surin26
16 (0.00/day)
I have bought nVidia 8800 GTS video card from a friend.
But plug into PC Power cuts do not work Re-open the Tai'an addictive
Must disconnect the power cable Then plug it in again But the same
I took a look at the card There is a 2-point fixing
I have a picture see
We would ask that repairing it.
thank you
9,795 (1.90/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
you bought repaired second card, have you asked your friend bout the card condition before?
8,408 (1.92/day)
Ovronnaz, Wallis, Switzerland
Keyboard Endorfy Thock 75% <3/none/touch/virtual
VR HMD Medion Erazer
^that
and also... i hope you are not trying to run that card as it is on the pics (aka: without the heatsink on it)
40,435 (6.58/day)
Missing heatsink. No wonder it fails to run. Please post system specs
surin26
16 (0.00/day)
heatsink have I removed for photography view Roy Repair C, C and cured I know it affects Yes For a video card does.
Its symptoms are Insert the card into the Power Cut. Please help
thank you
2,388 (0.67/day)
Shenandoah Valley, Virginia USA
System Name Home Brewed
Processor i9-7900X and i7-8700K
Motherboard ASUS ROG Rampage VI Extreme & ASUS Prime Z-370 A
Cooling Corsair 280mm AIO & Thermaltake Water 3.0
Memory 64GB DDR4-3000 GSKill RipJaws-V & 32GB DDR4-3466 GEIL Potenza
Video Card(s) 2X-GTX-1080 SLI & 2 GTX-1070Ti 8GB G1 Gaming in SLI
Storage Both have 2TB HDDs for storage, 480GB SSDs for OS, and 240GB SSDs for Steam Games
Display(s) ACER 28" B286HK 4K & Samsung 32" 1080P
Case NZXT Source 540 & Rosewill Rise Chassis
Power Supply Corsair RM1000 & Corsair RM850
Mouse Generic
Keyboard Razer Blackwidow Tournament & Corsair K90
Software Win-10 Professional
Benchmark Scores yes
The GPU is not worth the time and effort to repair it.
OneMoar
There is Always Moar
8,746 (1.70/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Cooling Enermax ETX-T50RGB
Storage ADATA SX8200PRO NVME 512GB, Intel 545s 500GBSSD, ADATA SU800 SSD, 3TB Spinner
Mouse Kone burst Pro
Keyboard EVGA Z15
I see slight bubbling of the PCB and several components look burt you are also missing a 110 Ohm resistor on the pci-e connector ( the one circled in red near the edge)
Card is damaged beyond repair looks like the entire power regulation circuit is damaged no chance of repairing such damage
*Friend* sold you a known damaged card there is no chance he missed such damage
INSTG8R
Vanguard Beta Tester
7,966 (1.12/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 2
Software Win 10 Pro x64
Dead card is dead...
929 (0.17/day)
System Name Desktop | Laptop
Processor AMD Ryzen 7 5800X3D | Intel Core i7 7700HQ
Motherboard MAG X570S Torpedo Max| Neptune KLS HM175
Cooling Corsair H100x | Twin fan, fin stack & heat pipes
Memory 32GB G.Skill F4-3600C16-8GVK @ 3600MHz / 16-16-16-36-1T | 16GB DDR4 @ 2400MHz / 17-17-17-39-2T
Video Card(s) EVGA RTX 3080 Ti FTW3 Ultra | GTX 1050 Ti 4GB
Storage Kingston KC3000 1TB + Kingston KC3000 2TB + Samsung 860 EVO 1TB | 970 Evo 500GB
Display(s) 32" Dell G3223Q (2160p @ 144Hz) | 17" IPS 1920x1080P
Case Fractal Meshify 2 Compact | Aspire V Nitro BE
Audio Device(s) ifi Audio ZEN DAC V2 + Focal Radiance / HyperX Solocast
Power Supply Super Flower Leadex V Platinum Pro 1000W | 150W
Mouse Razer Viper Ultimate | Logitech MX Anywhere 2
Keyboard Razer Huntsman V2 Optical (Linear Red)
Software Windows 11 Pro x64
That is actually where a capacitor should be. :ohwell:
Card is most likely dead. Time to move on.
OneMoar
8,746 (1.70/day)
Rochester area
Keyboard EVGA Z15
huh its a resister on all reference boards that I have seen
looks like its on pin 4 or 5 witch would either make it a ground or a SMCLK/SMDAT there would be no reason for a resistor on any of those
40,435 (6.58/day)
Repair it or not, desperate
Please help.
Cough up the cash and get a new updated card, that one is dead, there is no repairing it unless you have a fabrication plant to send the card to that handle surface mount devices.
929 (0.17/day)
The component is labeled 'C1180'. From my experience making PCBs and utilizing surface-mount devices, 'C' normally always denotes a capacitor. In this case it is a surface-mount ceramic (most likely) capacitor.
I'm not a professional Electronics Engineer, but from the formal education on the subject that I have had, says that it could be a decoupling capacitor (if that's the correct terminology for this use) which is used to filter noise and prevent it from affecting the rest of the system. Essentially gives a cleaner clock (if that's what those PCIe lines are for).
EDIT: Actually having a look at the PCIe port, it appears to be on the opposite side of the key as to the pins you mentions, meaning it could in fact have been a bypass capacitor from supply to ground, which also is used to filter out noise/ripple from the circuit. This is more plausible as decoupling capacitors are normally closer to ICs.
This leads me to believe this card may have been in a system with a dodgy PSU or motherboard and/or was mistreated and suffered from terrible supply causing the caps to heat and fall off.
EDIT2: The repair? to those two caps (C59 and C62) circled towards the rear of the card is less than desirable.
Aquinus
Resident Wat-man
13,147 (2.94/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
Please help.
Buy a cheap new one. A 50 dollars card will outpower a 8800 GTS... I don't know what the heck you were thinking when you bought this. I hope you didn't spend more than 10 dollars.
Frick
Fishfaced Nincompoop
18,934 (2.85/day)
Piteå
System Name Black MC in Tokyo
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Or look for a used one that is newer. Here the GTX 550 ti can usually be found for pretty cheap.
surin26
16 (0.00/day)
Yes, I bought a 10 dollar only.
Thanks for all your comments, I am happy to be a member of this community.
Thank you
2,388 (0.67/day)
Mouse Generic
