Odd cooling problems
Nemesis881
690 (0.11/day)
Dawsonville, GA
System Name Nemy's comp
Processor AMD Athlon x2 4200+ @ 2.61ghz
Motherboard ASUS A8M2N-LA
Cooling 1x250mm (side), 2x120mm (one front and back), 6000+ stock cooler
Memory 3Gb Corsair value select PC2-4200 (2x512mb and 2x1gb))
Video Card(s) XFX HD7770
Storage 320gb Seagate Baracuda / 160gb western digital
Display(s) ASUS 19" widescreen LCD. 1440x900
Case Apevia Jupiter-JR S-Type
Audio Device(s) on-board. Audigy died D;
Power Supply Ultra 600W X-pro
Software Vista Home Premium
So I put an 80mm fan on the side of my case to push air in. I have no other intake fans. But when I checked my temps after, my cpu went up a few degrees! I figured it would lower it, but i'm at a loss. Am I missing something?
hat
Enthusiast
21,731 (3.41/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
How many exhaust fans do you have?? Just 1?? If so, you would be better moving that 80mm to the back for exhaust and getting another 80mm to push air in. Negative pressure is better than equal pressure.
Nemesis881
690 (0.11/day)
Dawsonville, GA
I have a very small case and only room for one fan in the back. What if i had the side fan pushing air out? I'm guessing that would take away needed air for the cpu though.
kwchang007
3,962 (0.63/day)
Severn, MD, USA.
Processor C2D T7200@2 ghz vcore: .9875
Motherboard generic laptop board
Cooling fan control and antec notebook cooler
Memory 2 GBs@ 533 mhz ddr2
Video Card(s) x1400 mobile, overclocked: 526mhz core/ 882mhz ddr
Storage 120 GB@ 5400 rpm fujitsu
Display(s) 15.4" 1440x900
Audio Device(s) integrated
Software vista 32 bit home premium
you sure about negative pressure being better? i thought equal was best...
freaksavior
To infinity ... and beyond!
8,095 (1.28/day)
System Name ZeroUptime | M.A.S.S / MM1
Processor Xeon 2659 v3 / Xeon 2683 v4 / ARM A14
Motherboard Asus X99-E-10G WS / ASRock x99 usb 3.1 / Apple
Cooling NZXT Kraken / Noctua NH-L12 / Apple
Memory 16Gb DDR4 / 32Gb DDR4 / 16GB HBLM
Video Card(s) Powercooler ATI vega 64 / GT 7300 / ARM
Storage Samsung 970 512 Evo NVMe / A lot. / 256 + 512 External TB3
Display(s) Acer Predator X34 / Headless / Acer X34 Non predator
Case NZXT H630 |Rosewill 8bay 4u server chasiss / MMM1
Audio Device(s) Onboard / Onboard / Onboard
Power Supply Corais HX850 | Corsair TX750 / Internal 250w
Mouse g502 proteus core / Headless / g502 proteus core
Keyboard Corsair K95 Cherry Blue / Headless / K65 Cherry Red
Software Windows 10 / ESXI / Big Sur 11.2.2
my case has positive pressure! the whole positive - negative thing confuses me!
Nemesis881
690 (0.11/day)
Dawsonville, GA
positive pressure = more fans blowing in, negative pressure = more fans blowing out.
I'm still confused to why my temps went up though..
PrudentPrincess
669 (0.11/day)
Eugene
System Name Foobox3000
Processor Core 2 Duo 36750@3.46ghz
Motherboard Gigabyte GA-G33M-DS2R
Memory 2gb (2x1gb) Crucial Ballistix Tracer
Video Card(s) EVGA 9800gtx
Storage 500gb 7200prm IDE
Display(s) Sceptre 19"
Case Apevia X-Qpack 2 Red
Power Supply 500w Apevia generic
The intake fan was probably circulating warm air. I would go for an 80mm exhaust in the back (2 or more) and very few intake fans. The cpu will always have air, unless your case is in space. :laugh:
freaksavior
8,095 (1.28/day)
oh, hmm, well what is ideal then? more positive than negative? or equal?
i would think equal would be since it can circulate the same about of air continually
kwchang007
3,962 (0.63/day)
Severn, MD, USA.
i think equal is best because it can bring in the same amount of fresh air as it can exhaust hot air. the point im trying to make is, negative pressure, not enough fresh air, positive pressure is not enough air being exhausted. the problem pressure is that it's hard to balance because of the psu fan....well that's my opinion anyways.
5,197 (0.76/day)
Kansas City, KS
System Name Dell XPS 15 9560
Processor I7-7700HQ
Memory 32GB DDR4
Video Card(s) GTX 1050/1080 Ti
Storage 1TB SSD
Display(s) 2x Dell P2715Q/4k Internal
Case Razer Core
Audio Device(s) Creative E5/Objective 2 Amp/Senn HD650
Mouse Logitech Proteus Core
Keyboard Logitech G910
Adding a fan does not always mean better temperatures.
If you saw an increase, you probably are only disrupting an old hot spot and recycling some of the old warm air.
2 well places fans > 4 poorly places fans.
Just adding a fan means nothing. You have to take into account the objects in the way, and what air the fan will be moving in correlation to the other fans.
Post a picture with fan ratings and I bet I could find the problem :p
freaksavior
8,095 (1.28/day)
sry Nemesis881 don't mean to take over your thread here
but, i have an xclio a380 with 2 x 25cm in and 1 x 120 out the 25 blow about 110cfm in and the 120 sucks about 79cfm out. I also have a 120 on my cooler blowing in the same direction as the out 120.
kwchang007
3,962 (0.63/day)
Severn, MD, USA.
how about the psu? you're pressure might be about 2:1 (intake:exhaust). have you tried reversing one 25 cm, and putting the 120 mm as an intake.
freaksavior
8,095 (1.28/day)
the psu has a 120 sucking out, idk what cfm it has.
and yes, i have it done what you said, it didn't really do anything.......i am trying to get optimal cooling
Nemesis881
690 (0.11/day)
Dawsonville, GA
Hmm I turned the side fan around so it blows air out and the temps went down..Never would have guessed that would work better but w/e. :rockout:
