ok so which way should my side fan be blowing ?? UPDATED
217 (0.05/day)
System Name HP Pavilion - 15-cw1068wm
Processor AMD Ryzen 5 3500 U
Motherboard HP
Cooling standard laptop cooling
Memory 16 gb DDR4
Video Card(s) Radeon™ Vega 8 Graphics
Storage 125 gb internal M.2 SSD and 1 TB internal laptop drive.
Display(s) Built in
Case Laptop
Audio Device(s) built in B&O audio.
Power Supply Laptop 45w
Mouse track pad , and SteelSeries mouse.
Keyboard built in.
Software Windows 10 pro
So i just notice the guy who had the case before me has the fan blowing out i always thought they went in on the side fan. my heatsink it was the only way it would fit on my board but it works good and keeps me in the low 20s or 30s, i only have one other fan in this case its blowing out the back, and of course my GPU fan also blowing out. so which way should this other fan be blowing?? here is a pic.
rtwjunkie
PC Gaming Enthusiast
13,909 (2.42/day)
System Name Bayou Phantom
Power Supply Seasonic X-850
i always have the fan blowing in when i have a case with a side fan, but that is usually because the majority of the air blows toward the GPU.
Im sure you will have equal numbers tell you to have it blow out, but my reasoning it must be in, or the majority of casemakers wouldn't bother to put a filter there.
217 (0.05/day)
Motherboard HP
Memory 16 gb DDR4
Display(s) Built in
Case Laptop
Keyboard built in.
HMM so should i flip it and turn it towards the board ?
4,180 (1.15/day)
Texas
Mouse Logitech G5
Keyboard Logitech G19S
If its the only other fan I would have it as an intake as you need some air intake to help keeps temps down. Normally if people set the panel fan to exhaust they are running setups using multiple video cards that have fans designed to blow air out the sides to alleviate the bottom amount of air from entering the top card.
217 (0.05/day)
Motherboard HP
Memory 16 gb DDR4
Display(s) Built in
Case Laptop
Keyboard built in.
OK i will see about flipping it then if i do will it also not blow more dust down on my huge cpu heatsink ? just wondering how thats going to work.
2,417 (0.42/day)
Whitby, Ontario
Processor AMD Ryzen 5 2600
Motherboard MSI B450 Gaming Plus
Memory GSkill 8GB Dual Channel DDR4-2800
Video Card(s) MSI GamingX RX580 4GB
Storage Kingston V300 240GB SSD + WD Green 2TB
Display(s) ACER K212HL 27" + Haier 55" + Lenovo Explorer Mixed Reality Headset
Case Enermax Ostrog (Red)
Power Supply EVGA SuperNOVA B2 750W
Software Win10 64bit
217 (0.05/day)
Motherboard HP
Memory 16 gb DDR4
Display(s) Built in
Case Laptop
Keyboard built in.
hmm see i had no choice but to put my heatsink going up as it would not fit any other way its working though, and i dont have a front intake fan so should i make this a intake ?
217 (0.05/day)
Motherboard HP
Memory 16 gb DDR4
Display(s) Built in
Case Laptop
Keyboard built in.
Before i do this here is a straight on better picture of everything opinions please, i had no choice to put the cooler like this, and it was a non return item so i used it. SO just looked up cpu cooler it says it can be mounted both ways and airflow is the same so i guess i did not do a bad thing lol. now for the side fan in or out so far they say out waiting for more opinions.
1,050 (0.18/day)
Pikeville NC
System Name In the works
Processor 4670k
Motherboard ASUS Z87
Cooling 5x120mm
Memory 8GB Sniper Gskill 1833
Video Card(s) MSI 970 Gaming
Storage 2x 240gb SSD's + 1TB seagate
Display(s) 27" Acer 1920x1080
Case Corsair Carbide 200R
Power Supply OCZ Power 600W Modular
Keyboard Corsait K70 with red switches
Software Win10
check your temps.. flip the fan... check temps again.
Go with what ever has the lower temps, if difference is negligible then leave it alone.
217 (0.05/day)
Motherboard HP
Memory 16 gb DDR4
Display(s) Built in
Case Laptop
Keyboard built in.
I just opened it and it feels nice and cool in there i wanted to make sure my heatsink was still tight the first time i did anything like this, and its nice and snug and barely moves when i touch it and its nice and cool, to give a idea on my temps here is a screenshot What you think should i leave it.
6,441 (1.44/day)
Florida
System Name natr0n-PC
Processor Ryzen 5950x/5600x
Motherboard B450 AORUS M
Cooling EK AIO 360 - 6 fan action
Memory Patriot - Viper Steel DDR4 (B-Die)(4x8GB)
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) PIXIO IPS 240Hz 1080P
Case Thermaltake Level 20 VT
Power Supply Super Flower Leadex III ARGB 80+ Gold 650W
Software XP/7/8.1/10
Try it blowing inward... compare temps... then decide.
217 (0.05/day)
Motherboard HP
Memory 16 gb DDR4
Display(s) Built in
Case Laptop
Keyboard built in.
Ok will switch it around today when i get off work.
1,050 (0.18/day)
Pikeville NC
Processor 4670k
Cooling 5x120mm
Software Win10
did you do it? results?
217 (0.05/day)
Motherboard HP
Memory 16 gb DDR4
Display(s) Built in
Case Laptop
Keyboard built in.
yeah marginal results at best in fact i had decreased temps with it going out and raised with it in, so i flipped it back to out.
rtwjunkie
13,909 (2.42/day)
I think it all depends on the cfm that your exhaust fans have. If the top and rear are high volume, then a side intake would help lower.
217 (0.05/day)
Motherboard HP
Memory 16 gb DDR4
Display(s) Built in
Case Laptop
Keyboard built in.
not sure what the side fan is rated for it came with the case and is hooked to full power of the power supply.
217 (0.05/day)
Motherboard HP
Memory 16 gb DDR4
Display(s) Built in
Case Laptop
Keyboard built in.
ok so i got me a new 80 mm fan and i only have the side fan and the heatsink still could not change the direction of my heatsink, its still backwards with the fan pointing towards my psu, but here are my temps with the new 80 mm as a intake fan no front fan as my stupid case front don't come off. what do you think should i leave it in as a intake. also a pic of my heatsink and fan the way i had to do it, might be changing this heatsink to a better one for proper orientation. and you can see my rear fan as well.
6,441 (1.44/day)
Florida
Storage Various
Well looking at the outtake temp they look lower, so outtake might be better
217 (0.05/day)
Motherboard HP
Memory 16 gb DDR4
Display(s) Built in
Case Laptop
Keyboard built in.
are these to high ? if not i might give it a go for a while and see what they do.
6,441 (1.44/day)
Florida
Storage Various
They are normal temp nothing to worry about few degrees nothing crucial.
217 (0.05/day)
Motherboard HP
Memory 16 gb DDR4
Display(s) Built in
Case Laptop
Keyboard built in.
ok i'm going to give it a role this way and see what it does playing games and stuff :)
217 (0.05/day)
Motherboard HP
Memory 16 gb DDR4
Display(s) Built in
Case Laptop
Keyboard built in.
so do you think i need a front intake as well if so i can try and retrofit one.
6,441 (1.44/day)
Florida
Storage Various
217 (0.05/day)
Motherboard HP
Memory 16 gb DDR4
Display(s) Built in
Case Laptop
Keyboard built in.
Wish my case was like this but i did figure out how my front comes off :) and was going to ask if i add a front fan do you think it will disrupt the airflow on my heat sink fan beings i had no choice but to put it like it is.
13,210 (3.80/day)
Sunshine Coast
System Name Black Box
Memory G.Skill 16GB 3600 C18
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Mouse Yes
Keyboard Of course
Software W10 Pro 64 bit
It should improve the flow, from front to back.
