Overclocking advice (voltages and speed)
Discussion in 'Overclocking & Cooling' started by El_Mayo, Mar 21, 2010.
  1. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,862 (1.15/day)
    244
    I've got an Athlon x3 425 at 2.7ghz
    how far do you think i can overclock safely?
    my motherboard overvolts only 150mv
    can i reach 3.5ghz for example?
    stock cooling atm so might stop at about 3.2ghz
  2. pantherx12
    pantherx12 New Member
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    Only indeed, 350 will take your voltage up to 1.55 if your stock volts are 1.2 :p
    that's a massive amount of voltage!
    With decent cooling you could probably do 4 ghz.
    You could do 3.2 on stock volts I imagine.
  3. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,862 (1.15/day)
    244
    it only goes up 150mv :)
    i'll go for 3ghz now :D
  4. p_o_s_pc
    p_o_s_pc F@H&WCG addict
    May 2, 2007
    13,009 (4.05/day)
    2,183
    Newark ohio
    you should get 3.4-3.6ghz off of stock voltage easy...just start clocking and testing till it becomes unstable... That is how you find your limits ;)...Trial and error is a big part of overclocking
    Crunching for Team TPU
  5. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,482 (5.98/day)
    4,522
    Youngstown, OH
    I was told just as long as you keep all voltages under 1.55(excluding ram) and temps under 60C(excluding video card) you will be fine for 24.7 usage.
    Agree with you pos, but 3.4Ghz is the norm for a 425. I heard anything past 3.7ghz on an Athlon II things go wonky.
    p_o_s_pc says thanks.
  6. p_o_s_pc
    May 2, 2007
    13,009 (4.05/day)
    2,183
    Newark ohio
    thats the reason i said 3.4-3.6ghz :)
    but i don't think that the 3.7ghz rule applies to the AII X2's well atleast not the one that i had or a few others i have seen. 4ghz was fairly easy on my AII X2 even under a 64bit OS and 3.9ghz was stable 24/7...
    i need another AMD system to play around with. I'm tired of the i7 3.9ghz 24/7 on it was easy once i got it underwater
    sorry to kind of get off topic here :eek:
  7. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,862 (1.15/day)
    244
    I got core errors on core 1 and 2 on OCCT at 3.0ghz at stock volts
  8. JrRacinFan
    Mar 17, 2007
    19,482 (5.98/day)
    4,522
    Youngstown, OH
    Small or medium fft?
  9. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,862 (1.15/day)
    244
    Erm.. i think that's prime95 (which i'm running now)
    i picked LARGE DATA SET or something like that
  10. JrRacinFan
    Mar 17, 2007
    19,482 (5.98/day)
    4,522
    Youngstown, OH
    Just letting you know by my personal experience. I can crunch all night and day but as soon as I choose OCCT/Small data and run it I get random restarts.
    [​IMG]
    I know every proc is different.
    Run through a single linX run at maximum ram available. If you can get through that without BSOD/freeze then you should be ok for 24.7.
  11. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,862 (1.15/day)
    244
    what's linX? :D
    -google searches-
  12. TheShad0W New Member
    Nov 18, 2009
    148 (0.06/day)
    17
    I would personally advise trying to get it a little more stable than this (ie, it should be able to run linpack tests like linX on maximum for a decent number of runs and get no errors...)
    Otherwise you're not really stable.
  13. pantherx12
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    Do what I do, prime 95 on max heat + using the computer as normal at the same time for four hours.
    ( using msn, firefox, watching videos etc all while prime does its stuff)
    Best stability test in my opinion :p
    El_Mayo says thanks.
  14. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,862 (1.15/day)
    244
    just ran linpack max stress level 5 times on autonumber of threads
    42* max temp
    MOAR OVERCLOCK :D
  15. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,862 (1.15/day)
    244
    how far do you think i can go on this stock cooling? 3.6ghz? :D
  16. pantherx12
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    Keep it under 55c for best results : ]
    bare in mind your ambients will be up 10c soon so that will take you to 65 in the summer!
    Don't really want hotter then that : ]
  17. TheShad0W New Member
    Nov 18, 2009
    148 (0.06/day)
    17
    Also, check with more than one temperature monitoring program. I was getting weird readings out of speedfan (still do, about 18 degrees lower than realtemp/coretemp/hwmonitor show).
  18. pantherx12
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    Doesn't speed fan only read the cpu temp and not core temps though?
  19. TheShad0W New Member
    Nov 18, 2009
    148 (0.06/day)
    17
    Nope, was showing Core 0-Core 3, all at 15 degrees idle and 54 degrees load, whereas in actual fact they were at 35-37 degrees idle and 75-78 load.
    pantherx12 says thanks.
  20. pantherx12
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    Daaamn
    Seems speedfan is useless then, when I used it, It didn't even bother to tell me inaccurate temperatures even : [
  21. JrRacinFan
    Mar 17, 2007
    19,482 (5.98/day)
    4,522
    Youngstown, OH
    What would you claim as "really stable"? I claim rock solid stable as 1hr of OCCT small data set and stable as 1 linx maximum run. As you can see, "stable" becomes more personal preference than anything. Oh and a little tip ...
    Don't trust speedfan. ;)
  22. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,862 (1.15/day)
    244
    Hmm, I'll run 1hr of OCCT small data and TEN linx max runs :D
    and i'll watch it using real temp
    i'm go for 3.6ghz stock volts... when that fails i'll bump the voltage up :D
  23. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,862 (1.15/day)
    244
    My heatsink FELL OFF in the heat of things xD
    gonna need a new CPU cooler tbh
