PC Upgrade, What parts should i get?
Discussion in 'System Builder's Advice' started by SilverKnight, Nov 26, 2012.
  1. SilverKnight New Member
    Nov 26, 2012
    3 (0.00/day)
    0
    Okay so i am planning a upgrade for my pc. Specs listed on this account are it's spec. It's a fairly good rig however i get some nasty lag-spikes when running basic tasks. I don't use it that often as i have a gaming laptop (i7, Nvidia 555m) I want a rig that can handle the hardware given to it.
    Now i am a Computer Technician for a living but i am not up to date on whats out there in terms of hardware capability. I have a budget of £500 for:
    A new motherboard.
    Processor.
    Ram.
    Possibly a SSD\Hybrid HDD for the OS? (I have two old HDD and a 2tb one already)
    I must admit i have never had a WiFi motherboard before but the room where this PC is at has never had a wired connection so i am stuck with adapters so a motherboard with WiFi capabilities (card or on-board) is a must. The processor i have my eye on is the i7 3770k, although i am sure that would be what most people would suggest. I want to move away from AMD.
    CPU - £259.99
    3rd Generation Intel® Core™ i7 3770K 3.50GHz Socket LGA1155
    http://www.novatech.co.uk/products/...ncorei3,i5andi71155socket/bx80637i73770k.html
    MOBO - £146.99
    ASUS P8Z77-V PRO Intel Z77 (Socket 1155)
    http://www.novatech.co.uk/products/...s/intel1155z77chipset/90-mibhs0-g0eay0dz.html
  2. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,666 (5.08/day)
    4,805
    Youngstown, OH
    10 Year Member at TPU
  3. SilverKnight New Member
    Nov 26, 2012
    3 (0.00/day)
    0
  4. Jimbo900 New Member
    Nov 27, 2012
    3 (0.00/day)
    1
  5. JrRacinFan
    Mar 17, 2007
    19,666 (5.08/day)
    4,805
    Youngstown, OH
    Anything Linksys/Dlink in a USB adapter with a wifi antenna if you're planning a crossfire/sli build. If no cfire/sli, nearly anything in a PCI(-e) will do. WiFi is more dependent on the router/switch configuration used.
  6. jgunning
    jgunning
    Jul 4, 2012
    574 (0.30/day)
    224
    Australia
    Have you considered using EoP..?Very reliable and works like a treat provided your router and pc are on the same circuit.
