PC won't turn on, power supply making a faint ticking noise
Discussion in 'System Builder's Advice' started by El_Mayo, Jan 16, 2011.
  1. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,795 (1.27/day)
    217
    I don't think my power supply is broken because all I did was unplug power from my cd drive and then it wouldn't turn on. I wouldn't think a corsair psu would break that easily (?)
    I switched it out with my old power supply with the same cable without reseating or anything and it's working now ;o
  2. Bo$$
    Bo$$ Lab Extraordinaire
    May 7, 2009
    5,392 (2.47/day)
    883
    London, UK
    may have shorted something i doubt it would kill anything, check the corsair PSU is still working by using the green-black pin trick
  3. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,795 (1.27/day)
    217
    how do you do that man? :]
  4. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.43/day)
    573
    New York
  5. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,795 (1.27/day)
    217
    gahhh i don't have any paperclips
    is there anything else I can try? D;
  6. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.43/day)
    573
    New York
    Any wire...a bread tie will work..peal back enough plastic to expose enough wire to create the connection.Or speaker wire. Pen that has a spring >>you can strecth the spring and use as a wire.
  7. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,795 (1.27/day)
    217
    i used the pen spring hahha
    it's spinning right now so it still works :D
  8. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.43/day)
    573
    New York
    Nice! At least its still turning on.
  9. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,795 (1.27/day)
    217
    just not when it was plugged into all my hardware, and I don't know why :eek:
  10. El_Mayo
    El_Mayo
    Apr 15, 2009
    2,795 (1.27/day)
    217
    So yeah... any idea how so solve this? :D
  11. qubit
    qubit Overclocked quantum bit
    Dec 6, 2007
    10,540 (3.91/day)
    3,990
    Quantum well (UK)
    I think your Corsair is toast, I'm afraid - that ticking noise is a dead giveaway.* A faulty PSU may well come on without a load or lightly loaded and then fall over when the full load is applied.
    Try it on another PC to double verify.
    *My old Antec 550W PSU started making squirley noises that get louder with a bigger load. I replaced it with a brand new Corsair before it failed. That Antec is now sitting in an old PC that I don't use very much.
  12. AsRock
    AsRock TPU addict
    Jun 23, 2007
    11,667 (4.08/day)
    2,013
    US
    Yeah sounds like it's switching it's self off to protect your system\ it's self.. Time for a RMA by the sound of it.
  13. razaron
    razaron
    Apr 26, 2008
    1,107 (0.43/day)
    177
    london
    If i am correct the ticking sound is coming from a dead/burst capacitor trying to charge up but failing. So it would probably be in your best interests to get an RMA.
  14. AsRock
    AsRock TPU addict
    Jun 23, 2007
    11,667 (4.08/day)
    2,013
    US
    Really ?, would the chance of it being a type relay switch turning it on \ off when there is a issue which should be resetting it self when there is no power( no you do not hear then going back on just off ).
Share This Page
