Performance difference between Stock and aftermarket cooler
ibhappy
103 (0.02/day)
Processor Intel Pentium E6300 Wolfdale
Motherboard EP45-UD3R v1.1
Memory CORSAIR XMS2 8GB
Video Card(s) HD Radeon 4850
Storage Western Digital Caviar Black WD5001AALS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
Case Antec Nine Hundred
Audio Device(s) xtremegamer
Power Supply 650W Antec
How much of a benefit will I see overclocking my Q9650 with an aftermarket cooler?
With my E6300 Wolfdale, I was able to get to 3.9 GHz with the stock cooler.
3,393 (0.58/day)
BC.CAN
Processor 2700x under H100i progeebee
Motherboard ASUS x470 prime
Cooling Fans
Memory gskill ripjaw 3200
Video Card(s) MSi Vega 64 ref
Storage 120Gb OCZ Vertex 2E SSD - 500Gb Games - 1.5tb Storage and Media
Case CM HAF 932
Power Supply Corsair TX750
Software Win 10
If you're in the 4.0Ghz range you can expect to see a difference in the range of 20-30c or more depending on the cooler you buy.
This is an example.
10,209 (1.71/day)
Austin Texas
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case SLIGER S620
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard RoyalAxe
Alot. What you do by upgrading to a better cooler is make sure that temps are not the ceiling for your oC.
you can always OC on stock cooler, but the OC will fail at a lower Ghz and the chip will begin to throttle sooner. If you're OC isnt huge - like 3.5Ghz on the Q9650, then it wont matter as much. But if youre going for the 4.0+ range ^^ as is said above then you can only get there with an aftermarket.
180 (0.03/day)
Nobody can answer that question if you did not first provide its spec numbers. Heatsinks are measured in degrees C per watt. A first fact that any informed decision would need.
