Please Help. New Card, wierd problem
Discussion in 'General Hardware' started by wildmonkeys77, Jan 13, 2009.
  1. wildmonkeys77 New Member
    Dec 25, 2006
    53 (0.02/day)
    0
    I just replaced my x1900GT (which got me a lot of artifacts) with a 9600 GT. Whenever I play WoW and something graphically demanding occurs, my screen freezes, and I can still hear the appropriate sound in the backround, it might even be that the sound is running as it should be independently of what's on my screen.
    I can alt-tab and run everything else on my computer just fine...but when I alt tab back to the game my screen doesn't change.
    This will happen while playing the game, then when I start up the game it happens as soon as I log in, then it will happen right as I reach the character screen, then at the login screen.
    Restarting my computer seems to place me back to square one, but it will still freeze sometimes when I look at a huge landscape or something.
    Farcry 2 did the same thing right when I finished the first loading screen.
    HELP! and thank you
    System Information
    Time of this report: 1/12/2009, 20:23:51
    Machine name: AWESOME
    Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
    Language: English (Regional Setting: English)
    System Manufacturer: GBT___
    System Model: GBTUACPI
    BIOS: Award Modular BIOS v6.00PG
    Processor: Intel(R) Pentium(R) D CPU 2.66GHz (2 CPUs)
    Memory: 2046MB RAM
    Page File: 477MB used, 3975MB available
    Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
    DX Setup Parameters: Not found
    DxDiag Version: 5.03.2600.2180 32bit Unicode
    DxDiag Notes
    DirectX Files Tab: No problems found.
    Display Tab 1: No problems found.
    Sound Tab 1: No problems found.
    Music Tab: No problems found.
    Input Tab: No problems found.
    Network Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (n/a)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (n/a)
    DirectMusic: 0/5 (n/a)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name: NVIDIA GeForce 9600 GT
    Manufacturer: NVIDIA
    Chip type: GeForce 9600 GT
    DAC type: Integrated RAMDAC
    Device Key: Enum\PCI\VEN_10DE&DEV_0622&SUBSYS_058F10DE&REV_A1
    Display Memory: 1024.0 MB
    Current Mode: 1024 x 768 (32 bit) (85Hz)
    Monitor: Plug and Play Monitor
    Monitor Max Res: 1600,1200
    Driver Name: nv4_disp.dll
    Driver Version: 6.14.0011.8048 (English)
    DDI Version: 9 (or higher)
    Driver Attributes: Final Retail
    Driver Date/Size: 11/12/2008 14:54:00, 6148864 bytes
    WHQL Logo'd: Yes
    WHQL Date Stamp: n/a
    VDD: n/a
    Mini VDD: nv4_mini.sys
    Mini VDD Date: 11/12/2008 14:54:00, 6188320 bytes
    Device Identifier: {D7B71E3E-4562-11CF-1E6C-842500C2CB35}
    Vendor ID: 0x10DE
    Device ID: 0x0622
    SubSys ID: 0x058F10DE
    Revision ID: 0x00A1
    Revision ID: 0x00A1
    Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
    Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    Registry: OK
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Enabled
    DDraw Test Result: Not run
    D3D7 Test Result: Not run
    D3D8 Test Result: Not run
    D3D9 Test Result: Not run
    Sound Devices
    Description: Realtek HD Audio output
    Default Sound Playback: Yes
    Default Voice Playback: Yes
    Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1458E601& REV_1000
    Manufacturer ID: 1
    Product ID: 100
    Type: WDM
    Driver Name: RtkHDAud.sys
    Driver Version: 5.10.0000.5464 (English)
    WHQL Logo'd: Yes
    Date and Size: 8/10/2007 12:52:44, 4603904 bytes
    Other Files:
    Driver Provider: Realtek Semiconductor Corp.
    HW Accel Level: Full
    Cap Flags: 0xF5F
    Min/Max Sample Rate: 8000, 192000
    Static/Strm HW Mix Bufs: 33, 32
    Static/Strm HW 3D Bufs: 33, 32
    HW Memory: 0
    Voice Management: No
    EAX(tm) 2.0 Listen/Src: Yes, Yes
    I3DL2(tm) Listen/Src: Yes, Yes
    Sensaura(tm) ZoomFX(tm): No
    Registry: OK
    Sound Test Result: Not run
    Sound Capture Devices
    Description: Realtek HD Audio Input
    Default Sound Capture: Yes
    Default Voice Capture: Yes
    Cap Flags: 0x41
    Format Flags: 0xFFF
    Description: Realtek HD Digital input
    Default Sound Capture: No
    Default Voice Capture: No
    Cap Flags: 0x41
    Format Flags: 0xFFF
    DirectMusic
    DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
    DLS Version: 1.00.0016.0002
    Acceleration: n/a
    Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
    Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
    Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
    Registry: OK
    DirectInput Devices
    Device Name: Mouse
    Attached: 1
    Controller ID: n/a
    Vendor/Product ID: n/a
    FF Driver: n/a
    Device Name: Keyboard
    Attached: 1
    Controller ID: n/a
    FF Driver: n/a
    Poll w/ Interrupt: No
    Registry: OK
    USB Devices
    + USB Root Hub
    | Vendor/Product ID: 0x8086, 0x2830
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
    | Driver: usbd.sys, 2/28/2006 07:00:00, 4736 bytes
    Gameport Devices
    PS/2 Devices
    + Logitech PS/2 Keyboard
    | Matching Device ID: *pnp0303
    | Upper Filters: L8042Kbd
    | Service: i8042prt
    | Driver: i8042prt.sys, 8/3/2004 23:14:38, 52736 bytes
    | Driver: kbdclass.sys, 8/3/2004 22:58:34, 24576 bytes
    | Driver: L8042Kbd.sys, 12/10/2004 12:47:58, 13056 bytes
    + Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    | Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
    + HID-compliant MX518 Optical Mouse
    | Vendor/Product ID: 0x046D, 0xC01E
    | Matching Device ID: hid\vid_046d&pid_c01e
    | Upper Filters: LMouKE
    | Lower Filters: LHidKE
    | Service: mouhid
    | Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes
    | Driver: mouclass.sys, 8/3/2004 22:58:34, 23040 bytes
    | Driver: LHidKE.Sys, 12/10/2004 12:48:46, 24704 bytes
    | Driver: LMouKE.Sys, 12/10/2004 12:48:40, 68992 bytes
    | Driver: KHALMNPR.Exe, 12/10/2004 12:45:26, 49152 bytes
    + Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    DirectPlay Service Providers
    DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
    IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
    Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
    Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
    DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
    DirectPlay Test Result: Not run
    Registry: OK
    DirectPlay Adapters
    DirectPlay8 Serial Service Provider: COM1
    DirectPlay8 TCP/IP Service Provider: The Wireless - IPv4 -
    DirectPlay Voice Codecs
    Voxware VR12 1.4kbit/s
    Voxware SC06 6.4kbit/s
    Voxware SC03 3.2kbit/s
    MS-PCM 64 kbit/s
    MS-ADPCM 32.8 kbit/s
    Microsoft GSM 6.10 13 kbit/s
    TrueSpeech(TM) 8.6 kbit/s
    DirectPlay Lobbyable Apps
    Heroes of Might and Magic III (DX7) - Registry: OK, ExeFile: Heroes3.icd (<File Missing>)
    Stronghold Crusader (DX7) - Registry: OK, ExeFile: Stronghold Crusader.exe ()
    Disk & DVD/CD-ROM Drives
    Drive: C:
    Free Space: 5.0 GB
    Total Space: 238.5 GB
    File System: NTFS
    Model: WDC WD2500KS-00MJB0
    Drive: E:
    Model: TSSTcorp CD/DVDW SH-S182D SCSI CdRom Device
    Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 2/28/2006 07:00:00, 49536 bytes
    Drive: D:
    Model: KO4162O PAT659A SCSI CdRom Device
    System Devices
    Name: Intel(R) P965/G965 PCI Express Root Port - 29A1
    Device ID: PCI\VEN_8086&DEV_29A1&SUBSYS_00000000&REV_02\3&13C 0B0C5&0&08
    Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 23:07:48, 68224 bytes
    Name: Intel(R) P965/G965 Processor to I/O Controller - 29A0
    Device ID: PCI\VEN_8086&DEV_29A0&SUBSYS_00000000&REV_02\3&13C 0B0C5&0&00
    Driver: n/a
    Name: Microsoft UAA Bus Driver for High Definition Audio
    Device ID: PCI\VEN_8086&DEV_284B&SUBSYS_A0021458&REV_02\3&13C 0B0C5&0&D8
    Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 1/7/2005 17:07:18, 138752 bytes
    Name: Intel(R) ICH8 Family PCI Express Root Port 5 - 2847
    Device ID: PCI\VEN_8086&DEV_2847&SUBSYS_00000000&REV_02\3&13C 0B0C5&0&E4
    Name: Intel(R) ICH8 Family PCI Express Root Port 4 - 2845
    Device ID: PCI\VEN_8086&DEV_2845&SUBSYS_00000000&REV_02\3&13C 0B0C5&0&E3
    Name: Intel(R) ICH8 Family PCI Express Root Port 1 - 283F
    Device ID: PCI\VEN_8086&DEV_283F&SUBSYS_00000000&REV_02\3&13C 0B0C5&0&E0
    Name: Intel(R) ICH8 Family SMBus Controller - 283E
    Device ID: PCI\VEN_8086&DEV_283E&SUBSYS_50011458&REV_02\3&13C 0B0C5&0&FB
    Driver: n/a
    Name: Intel(R) ICH8 Family USB2 Enhanced Host Controller - 283A
    Device ID: PCI\VEN_8086&DEV_283A&SUBSYS_50061458&REV_02\3&13C 0B0C5&0&D7
    Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
    Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
    Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:48, 74240 bytes
    Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
    Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 2/28/2006 07:00:00, 7168 bytes
    Name: Intel(R) ICH8 Family USB2 Enhanced Host Controller - 2836
    Device ID: PCI\VEN_8086&DEV_2836&SUBSYS_50061458&REV_02\3&13C 0B0C5&0&EF
    Name: Intel(R) ICH8 Family USB Universal Host Controller - 2835
    Device ID: PCI\VEN_8086&DEV_2835&SUBSYS_50041458&REV_02\3&13C 0B0C5&0&D1
    Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 20480 bytes
    Name: Intel(R) ICH8 Family USB Universal Host Controller - 2834
    Device ID: PCI\VEN_8086&DEV_2834&SUBSYS_50041458&REV_02\3&13C 0B0C5&0&D0
    Name: Intel(R) ICH8 Family USB Universal Host Controller - 2832
    Device ID: PCI\VEN_8086&DEV_2832&SUBSYS_50041458&REV_02\3&13C 0B0C5&0&EA
    Name: Intel(R) ICH8 Family USB Universal Host Controller - 2831
    Device ID: PCI\VEN_8086&DEV_2831&SUBSYS_50041458&REV_02\3&13C 0B0C5&0&E9
    Name: Intel(R) ICH8 Family USB Universal Host Controller - 2830
    Device ID: PCI\VEN_8086&DEV_2830&SUBSYS_50041458&REV_02\3&13C 0B0C5&0&E8
    Name: Intel(R) ICH8 2 port Serial ATA Storage Controller - 2825
    Device ID: PCI\VEN_8086&DEV_2825&SUBSYS_B0021458&REV_02\3&13C 0B0C5&0&FD
    Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 13:51:52, 3328 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:42, 25088 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
    Name: Intel(R) ICH8 4 port Serial ATA Storage Controller - 2820
    Device ID: PCI\VEN_8086&DEV_2820&SUBSYS_B0021458&REV_02\3&13C 0B0C5&0&FA
    Name: Intel(R) ICH8/ICH8R Family LPC Interface Controller - 2810
    Device ID: PCI\VEN_8086&DEV_2810&SUBSYS_00000000&REV_02\3&13C 0B0C5&0&F8
    Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 35840 bytes
    Name: Intel(R) 82801 PCI Bridge - 244E
    Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_F2\3&13C 0B0C5&0&F0
    Name: GIGABYTE GBB36X Controller
    Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_B0001458&REV_02\4&A67 8335&0&00E3
    Driver: C:\WINDOWS\system32\DRIVERS\jraid.sys, 5.00.0001.0001 (English), 7/20/2006 08:39:24, 41728 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\JGOGO.sys, 5.00.3790.0001 (English), 2/7/2006 06:52:58, 6912 bytes
    Name: Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller
    Device ID: PCI\VEN_11AB&DEV_4364&SUBSYS_E0001458&REV_12\4&19F EE395&0&00E4
    Driver: n/a
    Name: NVIDIA GeForce 9600 GT
    Device ID: PCI\VEN_10DE&DEV_0622&SUBSYS_058F10DE&REV_A1\4&2CC DD017&0&0008
    Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 6188320 bytes
    Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 6148864 bytes
    Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 163908 bytes
    Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 602112 bytes
    Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 1564672 bytes
    Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 9392128 bytes
    Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 13672448 bytes
    Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 86016 bytes
    Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 81920 bytes
    Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 229376 bytes
    Driver: C:\WINDOWS\system32\nvmccsrs.dll, 6.14.0011.8048 (Arabic), 11/12/2008 14:54:00, 45056 bytes
    Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 4706304 bytes
    Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 3485696 bytes
    Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 188416 bytes
    Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 1286144 bytes
    Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 3796992 bytes
    Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.8048 (English), 11/12/2008 14:54:00, 2744320 bytes
    Driver: C:\WINDOWS\help\nvcpl.hlp, 11/12/2008 14:54:00, 177897 bytes
    Driver: C:\WINDOWS\help\nvwcplen.hlp, 11/12/2008 14:54:00, 55444 bytes
    Driver: C:\WINDOWS\system32\nvcod.dll, 1.03.0005.0028 (English), 11/12/2008 14:54:00, 122880 bytes
    Driver: C:\WINDOWS\system32\nvcodins.dll, 1.03.0005.0028 (English), 11/12/2008 14:54:00, 122880 bytes
    DirectX Components
    ddraw.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 266240 bytes
    ddrawex.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 27136 bytes
    dxapi.sys: 5.01.2600.0000 English Final Retail 2/28/2006 07:00:00 10496 bytes
    d3d8.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 1179648 bytes
    d3d8thk.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 8192 bytes
    d3d9.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 1689088 bytes
    d3dim.dll: 5.01.2600.0000 English Final Retail 2/28/2006 07:00:00 436224 bytes
    d3dim700.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 825344 bytes
    d3dramp.dll: 5.01.2600.0000 English Final Retail 2/28/2006 07:00:00 590336 bytes
    d3drm.dll: 5.01.2600.0000 English Final Retail 2/28/2006 07:00:00 350208 bytes
    d3dxof.dll: 5.01.2600.0000 English Final Retail 2/28/2006 07:00:00 47616 bytes
    d3dpmesh.dll: 5.01.2600.0000 English Final Retail 2/28/2006 07:00:00 34816 bytes
    dplay.dll: 5.00.2134.0001 English Final Retail 2/28/2006 07:00:00 33040 bytes
    dplayx.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 229888 bytes
    dpmodemx.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 23552 bytes
    dpwsock.dll: 5.00.2134.0001 English Final Retail 2/28/2006 07:00:00 42768 bytes
    dpwsockx.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 57344 bytes
    dplaysvr.exe: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 30208 bytes
    dpnsvr.exe: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 18432 bytes
    dpnet.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 375296 bytes
    dpnlobby.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 3584 bytes
    dpnaddr.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 3584 bytes
    dpvoice.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 212480 bytes
    dpvsetup.exe: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 83456 bytes
    dpvvox.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 116736 bytes
    dpvacm.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 21504 bytes
    dpnhpast.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 35328 bytes
    dpnhupnp.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 60928 bytes
    dpserial.dll: 5.00.2134.0001 English Final Retail 2/28/2006 07:00:00 53520 bytes
    dinput.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 159232 bytes
    dinput8.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 181760 bytes
    dimap.dll: 5.01.2600.0000 English Final Retail 2/28/2006 07:00:00 44032 bytes
    diactfrm.dll: 5.01.2600.0000 English Final Retail 2/28/2006 07:00:00 394240 bytes
    joy.cpl: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 68608 bytes
    gcdef.dll: 5.01.2600.0000 English Final Retail 2/28/2006 07:00:00 76800 bytes
    pid.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 35328 bytes
    dsound.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 367616 bytes
    dsound3d.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 1294336 bytes
    dswave.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 19456 bytes
    dsdmo.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 181760 bytes
    dsdmoprp.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 71680 bytes
    dmusic.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 104448 bytes
    dmband.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 28672 bytes
    dmcompos.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 61440 bytes
    dmime.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 181248 bytes
    dmloader.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 35840 bytes
    dmstyle.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 105984 bytes
    dmsynth.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 103424 bytes
    dmscript.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 82432 bytes
    system.dll: 1.01.4322.2032 English Final Retail 4/16/2007 18:36:46 1224704 bytes
    Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 1/12/2009 20:08:20 473600 bytes
    Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 1/12/2009 20:08:13 2676224 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 1/12/2009 20:08:15 2846720 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 1/12/2009 20:08:15 563712 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 1/12/2009 20:08:16 567296 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 1/12/2009 20:08:16 576000 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 1/12/2009 20:08:17 577024 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 1/12/2009 20:08:17 577536 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 1/12/2009 20:08:18 577536 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 1/12/2009 20:08:18 578560 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 1/12/2009 20:08:20 578560 bytes
    Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 1/12/2009 20:08:20 145920 bytes
    Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 1/12/2009 20:08:21 159232 bytes
    Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 1/12/2009 20:08:21 364544 bytes
    Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 1/12/2009 20:08:21 178176 bytes
    Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 1/12/2009 20:08:20 53248 bytes
    Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 1/12/2009 20:08:20 12800 bytes
    Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 1/12/2009 20:08:19 223232 bytes
    dx7vb.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 619008 bytes
    dx8vb.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 1227264 bytes
    dxdiagn.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 2113536 bytes
    directx.cpl: 5.04.0000.3900 English Final Retail 9/30/2004 11:17:14 135168 bytes
    mfc40.dll: 4.01.0000.6140 English Final Retail 2/28/2006 07:00:00 924432 bytes
    mfc42.dll: 6.02.4131.0000 English Final Retail 2/28/2006 07:00:00 1028096 bytes
    wsock32.dll: 5.01.2600.2180 English Final Retail 2/28/2006 07:00:00 22528 bytes
    amstream.dll: 6.05.2600.2180 English Final Retail 2/28/2006 07:00:00 70656 bytes
    devenum.dll: 6.05.2600.2180 English Final Retail 2/28/2006 07:00:00 59904 bytes
    dxmasf.dll: 6.04.0009.1133 English Final Retail 8/22/2006 04:05:26 498742 bytes
    mciqtz32.dll: 6.05.2600.2180 English Final Retail 2/28/2006 07:00:00 35328 bytes
    mpg2splt.ax: 6.05.2600.2180 English Final Retail 2/28/2006 07:00:00 148992 bytes
    msdmo.dll: 6.05.2600.2180 English Final Retail 2/28/2006 07:00:00 14336 bytes
    encapi.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 20480 bytes
    qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
    qcap.dll: 6.05.2600.2180 English Final Retail 2/28/2006 07:00:00 192512 bytes
    qdv.dll: 6.05.2600.2180 English Final Retail 2/28/2006 07:00:00 279040 bytes
    qdvd.dll: 6.05.2600.2180 English Final Retail 2/28/2006 07:00:00 385024 bytes
    qedit.dll: 6.05.2600.2180 English Final Retail 2/28/2006 07:00:00 562176 bytes
    qedwipes.dll: 6.05.2600.2180 English Final Retail 2/28/2006 07:00:00 733696 bytes
    quartz.dll: 6.05.2600.2749 English Final Retail 8/29/2005 22:54:26 1287168 bytes
    strmdll.dll: 4.01.0000.3936 English Final Retail 8/21/2006 09:52:08 246814 bytes
    iac25_32.ax: 2.00.0005.0053 English Final Retail 2/28/2006 07:00:00 199680 bytes
    ir41_32.ax: 4.51.0016.0003 English Final Retail 2/28/2006 07:00:00 848384 bytes
    ir41_qc.dll: 4.30.0062.0002 English Final Retail 2/28/2006 07:00:00 120320 bytes
    ir41_qcx.dll: 4.30.0064.0001 English Final Retail 2/28/2006 07:00:00 338432 bytes
    ir50_32.dll: 5.2562.0015.0055 English Final Retail 2/28/2006 07:00:00 755200 bytes
    ir50_qc.dll: 5.00.0063.0048 English Final Retail 2/28/2006 07:00:00 200192 bytes
    ir50_qcx.dll: 5.00.0064.0048 English Final Retail 2/28/2006 07:00:00 183808 bytes
    ivfsrc.ax: 5.10.0002.0051 English Final Retail 2/28/2006 07:00:00 154624 bytes
    mswebdvd.dll: 6.05.2600.2180 English Final Retail 2/28/2006 07:00:00 204288 bytes
    ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:15:22 140928 bytes
    ksproxy.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 130048 bytes
    ksuser.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 4096 bytes
    stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:04 48640 bytes
    mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
    mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
    mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
    swenum.sys: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 4352 bytes
    mstee.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5504 bytes
    bdaplgin.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 18432 bytes
    bdasup.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 11776 bytes
    msdvbnp.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 56832 bytes
    psisdecd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:46 363520 bytes
    psisrndr.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:58 33280 bytes
    ipsink.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 16384 bytes
    mpeg2data.ax: 6.05.2600.2180 English Final Retail 2/28/2006 07:00:00 118272 bytes
    ndisip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 10880 bytes
    mpe.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 15360 bytes
    streamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 15360 bytes
    msvidctl.dll: 6.05.2600.2180 English Final Retail 2/28/2006 07:00:00 1428480 bytes
    slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:18 11136 bytes
    nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:30 85376 bytes
    ccdecode.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:18 17024 bytes
    vbisurf.ax: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 30720 bytes
    msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:46 17408 bytes
    kstvtune.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 61952 bytes
    ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 43008 bytes
    kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 90624 bytes
    vfwwdm32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 00:56:48 53760 bytes
    wstcodec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:22 19328 bytes
    wstdecod.dll: 5.03.2600.2180 English Final Retail 2/28/2006 07:00:00 50688 bytes
    DirectShow Filters
    WDM Streaming VBI Codecs:
    NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.2180
    CC Decoder,0x00200000,2,1,,5.03.2600.2180
    WST Codec,0x00200000,1,1,,5.03.2600.2180
    DirectShow Filters:
    QuickTime Audio Decoder Filter,0x00600800,1,1,,
    WMAudio Decoder DMO,0x00800800,1,1,,
    WMAPro over S/PDIF DMO,0x00600800,1,1,,
    WMA Voice Decoder DMO,0x00600800,1,1,,
    Mpeg4s Decoder DMO,0x00800001,1,1,,
    WMV Screen decoder DMO,0x00800001,1,1,,
    WMVideo Decoder DMO,0x00800001,1,1,,
    QuickTime Video Decoder Filter,0x00600800,1,1,,
    Mpeg43 Decoder DMO,0x00800001,1,1,,
    Mpeg4 Decoder DMO,0x00800001,1,1,,
    Annodex Mux Filter,0x00200000,1,0,dsfAnxMux.dll,
    CMML Decode Filter,0x00800002,1,1,dsfCMMLDecoder.dll,
    CMML Raw Source Filter,0x00600000,0,0,dsfCMMLRawSource.dll,
    FLAC Decode Filter,0x00600000,1,1,dsfFLACDecoder.dll,
    FLAC Encode Filter,0x00200000,1,1,dsfFLACEncoder.dll,
    Native FLAC Source Filter,0x00600000,0,0,dsfNativeFLACSource.dll,
    Ogg Demux Packet Source Filter,0x00600000,0,0,dsfOggDemux2.dll,
    Ogg Mux Filter,0x00200000,1,0,dsfOggMux.dll,
    OGM Decode Filter,0x00600000,1,1,dsfOGMDecoder.dll,
    Speex Decode Filter,0x00600000,1,1,dsfSpeexDecoder.dll,
    Speex Encode Filter,0x00200000,1,1,dsfSpeexEncoder.dll,
    Subtitle VMR9 Filter,0x00800002,1,1,dsfSubtitleVMR9.dll,
    Theora Decode Filter,0x00600000,1,1,dsfTheoraDecoder.dll,
    Theora Encode Filter,0x00200000,1,1,dsfTheoraEncoder.dll,
    Vorbis Decode Filter,0x00600000,1,1,dsfVorbisDecoder.dll,
    Vorbis Encode Filter,0x00200000,1,1,dsfVorbisEncoder.dll,
    WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
    Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
    RealPlayer Video Filter,0x00200000,1,1,rdsf3260.dll,6.00.0013.0045
    Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,3.02.0000.0018
    DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
    Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,3.02.0000.0018
    DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0002.0000
    Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
    WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
    Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
    AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
    WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.402 6.0000
    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
    Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
    Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
    RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0 001.0000
    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
    WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
    StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600. 2180
    WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
    Nero Resize,0x00200000,1,1,NeResize.ax,3.02.0000.0018
    MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 749
    Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
    DivX for Blizzard Decoder Filter,0x00800000,1,1,blizzard.ax,5.00.0002.0000
    WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
    Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000. 4487
    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
    MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
    Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0018
    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
    ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
    Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,3.02.0000.0018
    Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0018
    Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0018
    Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,3.02.0000.0018
    Nero Digital AVC Video Enc,0x00200000,1,2,,
    Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0018
    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
    File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
    Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,3.02.00 00.0018
    WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
    DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
    Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.000 0
    Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
    Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
    Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,3.02.0000.0 018
    WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,3.02.00 00.0018
    Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Nero ES Video Reader,0x00600000,0,1,NDParser.ax,3.02.0000.0018
    DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0002.0000
    Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,3.02.0000.0018
    Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5 145
    ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
    ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
    NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
    ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
    Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
    Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
    Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Nero DVD Navigator,0x00600000,0,4,NeDVD.ax,3.02.0000.0018
    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
    Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
    Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
    WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
    Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
    RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.00 01.0000
    Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0018
    Nero Vcd Navigator,0x00600000,0,2,NeVcd.ax,3.02.0000.0018
    DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.03.0000.0063
    Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,3.02.0000. 0018
    WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
    WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,3.02.0000.0018
    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
    Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000. 4487
    Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0018
    DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
    File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
    Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,3.02.0000.0018
    WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.000 0
    DirectVobSub,0x00200000,2,1,DVobSub.ax,2.00.0023.0 000
    RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0 001.0000
    DirectVobSub (auto-loading version),0x00800002,2,1,DVobSub.ax,2.00.0023.0000
    DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
    Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
    Subtitle Source,0x00200000,0,1,DVobSub.ax,2.00.0023.0000
    Nero Splitter,0x00600000,1,3,NeSplitter.ax,3.02.0000.00 18
    AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
    .RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
    Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,3.02.0000.001 8
    WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600 .2180
    DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
    RealPlayer Transcode Filter,0x00600000,0,0,rdsf3260.dll,6.00.0013.0045
    Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
    Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
    ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
    ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
    ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
    ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
    ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
    ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
    ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
    DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
    9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
    WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
    Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,3.02.000 0.0018
    Nero Video Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0018
    Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2 180
    Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
    WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
    MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.05.2600.2180
    WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
    StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.260 0.2180
    Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
    Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
    Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,3.02.00 00.0018
    RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0013.0045
    AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 749
    Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
    QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
    Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
    MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
    Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
    File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
    XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
    Nero File Source,0x00200000,0,1,NeFileSrc.ax,3.02.0000.0018
    Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0018
    Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,3.02. 0000.0018
    Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0018
    Nero Digital Parser,0x00600000,0,3,NDParser.ax,3.02.0000.0018
    RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00. 0001.0000
    AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
    File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
    File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
    WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Nero Frame Capture,0x00200000,1,1,NeCapture.ax,3.02.0000.0018
    WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0018
    Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,3.02.0000. 0018
    BDA MPEG2 Transport Information Filter,0x00200000,1,0,PsisRndr.ax,6.05.2600.2180
    QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 749
    MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
    Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
    Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
    WDM Streaming Tee/Splitter Devices:
    Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.2180
    WDM Streaming Data Transforms:
    Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
    Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
    Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
    Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
    Video Compressors:
    WMVideo8 Encoder DMO,0x00600800,1,1,,
    MSScreen encoder DMO,0x00600800,1,1,,
    WMVideo9 Encoder DMO,0x00600800,1,1,,
    MSScreen 9 encoder DMO,0x00600800,1,1,,
    DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
    Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
    MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.274 9
    Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,3.02.0000.0018
    Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
    DivX® 6.8 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.05.2600.2180
    Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.05.2600.218 0
    Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
    VP60® Simple Profile ,0x00200000,1,1,qcap.dll,6.05.2600.2180
    VP61® Advanced Profile,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft Windows Media Video 9,0x00200000,1,1,qcap.dll,6.05.2600.2180
    DivX® 6.8 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Audio Compressors:
    WMA Voice Encoder DMO,0x00600800,1,1,,
    WM Speech Encoder DMO,0x00600800,1,1,,
    WMAudio Encoder DMO,0x00600800,1,1,,
    IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
    IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
    Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
    ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
    DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600 .2749
    Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
    Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
    GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
    Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2749
    Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
    CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
    CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
    MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
    Audio Capture Sources:
    Realtek HD Audio Input,0x00200000,0,0,qcap.dll,6.05.2600.2180
    Realtek HD Digital input,0x00200000,0,0,qcap.dll,6.05.2600.2180
    Midi Renderers:
    Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
    Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
    WDM Streaming Capture Devices:
    Realtek HD Digital input,0x00200000,1,1,,5.03.2600.2180
    ,0x00000000,0,0,,
    WDM Streaming Rendering Devices:
    Realtek HD Audio output,0x00200000,2,1,,5.03.2600.2180
    BDA Rendering Filters:
    BDA IP Sink,0x00200000,1,1,,5.03.2600.2180
    BDA Network Providers:
    Microsoft ATSC Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
    Microsoft DVBC Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
    Microsoft DVBS Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
    Microsoft DVBT Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
    BDA Transport Information Renderers:
    BDA MPEG2 Transport Information Filter,0x00600000,1,0,PsisRndr.ax,6.05.2600.2180
    MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.05.2600.2180
    WDM Streaming Mixer Devices:
    Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
    BDA CP/CA Filters:
    Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
    Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
    XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
    WDM Streaming Communication Transforms:
    Audio Renderers:
    Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.2749
    Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
    Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
    DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.2749
    WDM Streaming System Devices:
    Realtek HD Audio Input,0x00200000,4,1,,5.03.2600.2180
    Realtek HD Audio output,0x00200000,18,1,,5.03.2600.2180
    BDA Receiver Component:
    BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.2180
    BDA MPE Filter,0x00600000,1,1,,5.03.2600.2180
  2. lucasweir
    lucasweir
    Aug 28, 2008
    1,257 (0.46/day)
    70
    USA
    did you try reinstalling the video drivers? that usually works
  3. Darren
    Darren New Member
    Feb 27, 2005
    1,936 (0.48/day)
    345
    You've got the first generation of 9600 GT, they suffered a hardware related problem which cause conflicts with the motherboards chipset. Unless you're prepared to change motherboards the only way to solve it is to RMA the card. Dont waste your time trying to solve it, its a common problem I've experienced it before too and was forced to change motherboards. There are forums with hundreds of people with the same issues with the 9600 GT. It isn't driver related and it isn't your fault, just replace the card.
    If it isn't too late to return the card pick up a a different card which doesn't have issues. (happens to be faster too)
    Nvidia 9800 GTX+ for about $150
    ATI 4830 for about $99
    ATI 4850 for about $150
    Edit:
    Its working fine but for how long? Hopefully it is only driver related but I doubt it!
    Dont wait too long to RMA it!
    10 Year Member at TPU
  4. wildmonkeys77 New Member
    Dec 25, 2006
    53 (0.02/day)
    0
    ok I reinstalled my graphics driver (for the second time) and everythings working good so far. Does my card 100% have this problem?
  5. trickson
    trickson OH, I have such a headache
    Dec 5, 2004
    6,494 (1.59/day)
    956
    Planet Earth.
    I would RMA it now .
    Darren says thanks.
  6. lucasweir
    lucasweir
    Aug 28, 2008
    1,257 (0.46/day)
    70
    USA
    if it starts working fine then i wouldnt woryy but if it continues i would rma
