Possible fix for waiting to load webpages & downloads
Discussion in 'Linux / BSD / Mac OS X' started by 95Viper, Oct 14, 2010.
  1. 95Viper
    95Viper
    Oct 12, 2008
    4,300 (2.03/day)
    1,540
    στο άλφα έως ωμέγα
    Just installed Ubuntu 10.10 the other day and have been battling this problem, since. Setting the network manager IPv6 to Ignore, or any other option did nothing, but it is now fixed.
    This worked for me and my downloads and page loads are snappy(quick), as they should be.
    If you are not using IPv6, then it may be causing your waits\stutter\delay of downloads and web page access\loading.
    I used method 3 at this site > How to Disable IPV6 in Ubuntu; and, it worked. Cured my sometimes delays and hesitations.
    Method 3
    Edit /etc/default/grub file
    gksudo gedit /etc/default/grub
    Change
    GRUB_CMDLINE_LINUX_DEFAULT=”quiet splash”
    to
    GRUB_CMDLINE_LINUX_DEFAULT=”ipv6.disable=1 quiet splash”
    Save and exit the file
    Update the grub from the command line
    sudo update-grub
    Hope it helps some of you with the same symptoms.:)
    Kreij says thanks.
Share This Page
