Potential Hard Drive Problem???
Discussion in 'General Hardware' started by MTL, Aug 8, 2006.
  1. MTL New Member
    May 27, 2006
    132 (0.04/day)
    0
    I need your help guys. I ran Sandra 2005 and I came up with some odd results.
    I find that my system is running nice and fast compared to all the ones in the program BUT both the chipset benchmark (lower right) and the hard drive benchmark (far right) have me a bit worried. Any thoughts???
    I have a Samsung Spinpoint P-Series SATAII 250GB drive hooked up to a DFI Lanparty SLI DR Expert mobo.
    [​IMG]
  2. i_am_mustang_man New Member
    Feb 7, 2006
    1,854 (0.51/day)
    11
    Boston
    i can't tell about the second example for the hdd test, but the other ones are in raid0, which would make their performance make sense in comparison to your single drive
    try some other drive examples
    *edit, looked up gigabyte iram, and it's a solid state disk, so it's read times are going to be better than a platter type hdd. check your performance against other single drives
    10 Year Member at TPU
  3. MTL New Member
    May 27, 2006
    132 (0.04/day)
    0
    I did....but Sandra doesn't seem to have any SATAII non-RAID configurations. I just need to know how my dirve compares in terms of performance to others of the same caliber.....I thought I should be getting closer to 90MB/s.
  4. i_am_mustang_man New Member
    Feb 7, 2006
    1,854 (0.51/day)
    11
    Boston
    hrmmmm... hopefully someone with a single setup can run the test too
    quick ?: is the program free? czu i can run it in about an hour when i get home
    also, is the 1st example 36gb 10,000rpm hdd's in raid0? if so, and they get 95mb/s i would be surprised if a single, parallel drive get's 90. but i have no idea, cuz i have never ran the program! i was just trying to help by observation, but i'll have data of my own soon enough to compare.
  5. MTL New Member
    May 27, 2006
    132 (0.04/day)
    0
  6. i_am_mustang_man New Member
    Feb 7, 2006
    1,854 (0.51/day)
    11
    Boston
    will do. be back in half an hour plus time to run it
  7. i_am_mustang_man New Member
    Feb 7, 2006
    1,854 (0.51/day)
    11
    Boston
    dl'ing it now
  8. randomperson21
    randomperson21 New Member
    Dec 28, 2005
    1,534 (0.41/day)
    0
    San Luis Obispo, CA
    i hear the spinpoint series is a pretty damn fast drive, and those numbers seem about right. they jive with the numbers of my seagate 7200.9 when it was still a single drive.
    my rig is about the same as yours, and these numbers jive pretty nicely for what i'm getting. so i wouldn't be too worried.
  9. i_am_mustang_man New Member
    Feb 7, 2006
    1,854 (0.51/day)
    11
    Boston
    [​IMG]
    damn, you beat me
    that's a 250gb sataII drive
    it's a samsung spinpoint, actually
    so there you have it
    you pwn me
    great. now i have something else i want to speed up.
    thanks AA LOT!
    haha
  10. randomperson21
    Dec 28, 2005
    1,534 (0.41/day)
    0
    San Luis Obispo, CA
    hehe i hate it when that happens.
  11. i_am_mustang_man New Member
    Feb 7, 2006
    1,854 (0.51/day)
    11
    Boston
    my ide drive got a score of 35mb/s, just for reference. it's an 80gb WD 7200rpm one
  12. mikelopez New Member
    May 12, 2006
    170 (0.05/day)
    0
    Tampa, FL
  13. MTL New Member
    May 27, 2006
    132 (0.04/day)
    0
    You guys have put me a rest....phew. I'm sure these drives would fly in RAID.
    I'm not a fan of '07.....
    Another odd think that I have noticed is that the rest of my scores are quite a bit above the benchmark scores. Don't get me wrong...I'm loving the scores but are the Sandra saved scores lowballed???
    This is because if you look, my X2 3800+ blows the X2 4000+ out of the water.
  14. randomperson21
    Dec 28, 2005
    1,534 (0.41/day)
    0
    San Luis Obispo, CA
    well, the 4000+ is only 200mhz faster, so i don't think its impossible...
  15. MTL New Member
    May 27, 2006
    132 (0.04/day)
    0
    Ah, I see you have almost the same specs as I do!!!
    You should bench your system using Sandra and see how our systems compare to each other.
  16. mikelopez New Member
    May 12, 2006
    170 (0.05/day)
    0
    Tampa, FL
    Oops...Just noticed that you already mentioned 2007.
