power colour x800 gt pci-e modding
Discussion in 'Graphics Cards' started by gt_maxer, Nov 29, 2006.
  1. gt_maxer New Member
    Nov 28, 2006
    13 (0.00/day)
    0
    Hi all, :) i thought i would just post it here as its not exactly the same as others i think, im wanting to mod my graphics card, to have more pipelines or something to better it,here is the details...thanks:toast:
    -- RaBiT v.2.1.0 build 645 started --
    > RaBiT driver v.2.0.2 is ready
    -- Your ATi video adapter low level info --
    Vendor: 0x1002, SubVendor: 0x148C (C.P. Technology Co. Ltd)
    Device: 0x554B (R423), SubSystem: 0x2151
    CONFIG_XSTRAP.8P_DISABLE = 0x02
    On Board EEPROM: ST M25P05/c (64 Kb)
    Active pipelines: 8, GB_TILE_CONFIG = 0x00010017
    GB_PIPE_SELECT = 0x00019940
    CONFIG_DIE_FUSES = 0xFFFF9FFF, 8 died pipeline(s)
    CONFIG_SUBSTRATE_FUSES = 0xFFFFFF9D, 8 disabled pipeline(s)
    CONFIG_ROM_FUSES = 0x00000862
    CONFIG_REGISTER_FUSES = 0x00000000
    -- Memory bus and clocking info --
    Memory: 256 bits, 256 Mb
    Core clock = 498.00 MHz
    Memory clock = 537.00 MHz
    -- Active memory timings --
    im handy with a solder iron if i need to join 2 parts up on the board itself..please help..:eek: neeeeeeddddd mooorreeeee pooooowwweeeerrrrr:respect:
  2. dolf New Member
    Mar 16, 2005
    2,058 (0.59/day)
    30
    Doesn't matter how many posts you start NO more pipes for your core. More performance you could gain if you answer to my questions and if you give me what I asked for ;) .
  3. gt_maxer New Member
    Nov 28, 2006
    13 (0.00/day)
    0
    hi i gave you the code bit you needed for the bios?is that not what you needed?
Share This Page
