Power cooling front fan hookup?
Discussion in 'Overclocking & Cooling' started by NONYA, Jan 10, 2008.
  1. NONYA
    NONYA New Member
    Dec 26, 2007
    634 (0.23/day)
    9
    Power cooling front fan hookup?Bought one of the little 80 mm blue led fans,it has a small plug that connects to a larger adapter,can i plug this directly to my power source?
  2. TUngsten
    TUngsten
    Nov 24, 2006
    1,044 (0.33/day)
    64
    CT, USA
    yep
    some of the molex connectors will say "fan only" on them, look for those
  3. Kreij
    Kreij Senior Monkey Moderator Staff Member
    Feb 6, 2007
    13,881 (4.49/day)
    5,624
    Cheeseland (Wisconsin, USA)
    If the adapter that came with it is converts to the type that comes off your power supply it should work fine.
    If it goes a million miles an hour and explodes, send it back. :D
  4. Namslas90 New Member
    Aug 27, 2006
    4,851 (1.49/day)
    555
    Earth
    You can plug it directly into a motherboard System Fan Header as long as the pins match up(4 pin on fan to 3pin on mobo will have to line up properly in order to work) other than that use the Molex adapter.
    :toast:
  5. NONYA
    NONYA New Member
    Dec 26, 2007
    634 (0.23/day)
    9
    thanx guys,it didnt blow!
Share This Page
