Power issue.
Discussion in 'System Builder's Advice' started by Toothless, Mar 26, 2014.
  1. Toothless
    Toothless
    Mar 26, 2014
    1,247 (4.08/day)
    543
    The oven!
    So I'm looking for a new CPU and the one I picked (FX-8350) would probably nuke my PSU. So I was wondering if a FX-6300 would do the same.
    I'm running a 530w PSU from Raidmax and I've had no issues.
    I'm also carrying over a MSI GTX 660 OC in the upgrade.
    16GB DDR3 1600mhz RAM.
    And... Dunno of the mobo is a big issue.
    PRETTY MUCH will my PSU take a FX-6300?
  2. silkstone
    silkstone
    Nov 1, 2008
    2,914 (1.28/day)
    514
    From customer reviews and the amount of failed units in there, I doubt it would actually be able to push 530 W.
    It seems to have a tenancy of blowing up rather than just failing too. I wouldn't put one of those things in any rig.
  3. RCoon
    Apr 19, 2012
    8,228 (8.13/day)
    4,367
    Gypsyland, UK
    A good quality 550w PSU would run that system no problem and allow OC room. That PSU though, is not highly regarded on the few forums I've googled. Might wanna pick up a Sea Sonic 550w or something.
    Toothless says thanks.
  4. Devon68
    Devon68
    Jan 25, 2014
    805 (2.20/day)
    329
    For the fx-6300+GTX 660 that psu in enough. A friend of mine has a FX-6100+GTX660 - he ran the pc on a cooler master 460W psu at first and later changed it to a 500W model.
  5. Toothless
    Toothless
    Mar 26, 2014
    1,247 (4.08/day)
    543
    The oven!
    Okay awesome, so some OC room is in there. I just got this PSU so I wasn't looking into buying another one. Thanks guys, you helped more than the last forum I used~
Share This Page
