Power problem!!!
Discussion in 'General Hardware' started by dee_dee19, Jan 30, 2007.
  1. dee_dee19 New Member
    Jan 30, 2007
    5 (0.00/day)
    0
    Hi, wondered if anyone could help, I've built up a pc, and when i turn it on to boot it up, power is coming on cpu fan etc starts up but after about 30 secs it stops again, any ideas? ive checked all connections etc
  2. ktr
    ktr
    Apr 7, 2006
    7,407 (2.28/day)
    687
    unplug the power cord and take out the cmos battery and wait 10mins, then place the cmos battery back and plug the power cord back.
  3. dee_dee19 New Member
    Jan 30, 2007
    5 (0.00/day)
    0
    i removed cmos battery as you said and waited for ten mins before putting it back in but getting same problem, any other suggestions?
  4. WarEagleAU
    WarEagleAU Bird of Prey
    Jul 9, 2006
    10,809 (3.42/day)
    547
    Gurley, AL
    Could be the PSU is underpowered for your system, something is loose, dust or debris is in a connection, or your PSU is faulty.
  5. dee_dee19 New Member
    Jan 30, 2007
    5 (0.00/day)
    0
    one difference after removing cmos battery is that as soon as i connect the power cord the pc starts up??
  6. ktr
    ktr
    Apr 7, 2006
    7,407 (2.28/day)
    687
    thats just a default power feature in the bios...
  7. dee_dee19 New Member
    Jan 30, 2007
    5 (0.00/day)
    0
    I've changed over PSU and still having same problems.
  8. Namslas90 New Member
    Aug 27, 2006
    4,851 (1.56/day)
    555
    Earth
    Check the mobo manuel to insure that the mobo jumpers are in the correct configuration for that setup and that all jumpers are present.(theve been known to fall off during shipping and handeling!)
  9. freaksavior
    freaksavior To infinity ... and beyond!
    Dec 11, 2006
    8,084 (2.69/day)
    909
    to be honest, i don't get what you mean. Does it boot past post or does it just boot no post and then shuts off? if it boot past post were does it get to before shutting off?
  10. dee_dee19 New Member
    Jan 30, 2007
    5 (0.00/day)
    0
    When i connect the power it will start up cpu fan will start up but after 30 seconds everything stops, ive changed psu but im still getting same problem
  11. freaksavior
    Dec 11, 2006
    8,084 (2.69/day)
    909
    What’s your system specs? And do you hear any bios beeps?
    by the way welcome to, tpu sry it couldn't be under different circumstances
Share This Page
