Power Supply Cable Question
Discussion in 'General Hardware' started by wolf2009, Jul 28, 2009.
  1. wolf2009 Guest
    I lost my power cable for the Ultra 600W power supply. Talking about the fat cable that plugs into power supply and wall socket shown in bottom the image
    [​IMG]
    I found a cable like that in my mess of cables, but it was connected to a brick type dc adaptor. The plug says 10A 125V. I also found another cable that says 10A 250V and temp as 60C/75C. Will I be able to use these cables for the PSU ?
    I checked the wire connected to my other PSU, it is a lot fatter and also says 10A/125V and has temp mentioned as 105C.
    The PC that connects is Athlon II X2 , HD 4670, 1 HDD, 4GB DDR3.
    If not where can I buy a similar cable ?
  2. KH0UJ
    KH0UJ New Member
    Feb 22, 2009
    363 (0.17/day)
    32
    Cebu City Philippines
    That will do;) you can also use the fat one, bigger wires and insulation, more reliable, less voltage drop:rockout:
Share This Page
