Power supply problem?
5,400 (0.92/day)
Australia
Have you got a spare GPU? or any spare parts to run in your system to see what happens? Id also run it on the bare min, as in no HDD's, no fans, just the basics first and see if it post's.
On a side note, who is the chick in ya avatar? hehe
  • Like
Reactions: vMG
DaMulta
My stars went supernova
16,168 (2.50/day)
Oklahoma T-Town
System Name Work in progress
Processor AMD 955---4Ghz
Motherboard MSi GD70
Cooling OcZ Phase/water
Memory Crucial2GB kit (1GBx2), Ballistix 240-pin DIMM, DDR3 PC3-16000
Video Card(s) CrossfireX 2 X HD 4890 1GB OCed to 1000Mhz
Storage SSD 64GB
Display(s) Envision 24'' 1920x1200
Case Using the desk ATM
Audio Device(s) Sucky onboard for now :(
Power Supply 1000W TruePower Quattro
Check your memory. Install only one stick at a time, and see what she does.
  • Like
Reactions: vMG
vMG
70 (0.01/day)
Processor Intel Core 2 Duo E8400 @ 4.05Ghz
Motherboard GIGABYTE GA-EP45-UD3L
Cooling Antec, Scythe, Big Shuriken
Memory 2x2GB Mushkin DDR2 900Mhz (5-4-4-12)
Video Card(s) Sapphire HD4870 1GB @ 800/1000
Storage Western Digital 500GB SATA II BLACK
Display(s) HP 2159m 20" 1080p
Case Antec 300 Gaming Case
Power Supply PC Power & Cooling 610 Watt Silencer PSU
Software Windows 7 x64 Ultimate
lol it's the one and only, Kristen Bell! :p
okay, i'll try a different GPU.
OMFG, I can't believe this is happening. Wow, this sucks so much balls.
4,686 (0.80/day)
System Name Obelisc
Processor i7 3770k @ 4.8 GHz
Motherboard Asus P8Z77-V
Cooling H110
Video Card(s) GTX 780 Ti
Case T81
Software Win10 64bit
tried putting the old cpu back in?
  • Like
Reactions: vMG
vMG
70 (0.01/day)
crap, the only other GPU i have is an AGP.. lol.
I have no other CPU. I built this RIG from scratch.
901 (0.18/day)
NYU
System Name Baby Box
Processor i5 4670K @ 4GHz
Motherboard Asus Z97I-PLUS
Cooling Corsair H100i
Memory 16GB Kingston HyperX FURY DDR3 1600MHz @ CL10
Video Card(s) EVGA GTX 780 Dual FTW w/ EVGA ACX Cooler
Storage Crucial M500 240GB SSD (Boot Drive); Seagate 7200.12 1TB 7200RPM (Storage)
Display(s) ASUS VH222H 21.5" 1920x1080
Case Corsair 250D Mini ITX
Audio Device(s) Audioengine D1 DAC/Amp
Power Supply Cooler Master GX RS750 PSU
Mouse Corsair SCIMITAR RGB
Keyboard Corsair Vengeance K70 RGB
Software Windows 10 Pro x64/ Linux Mint 17.3
I had this happen to me, I was playing Fallout 3 (not a particularly stressful game) on my old rig, when the PSU revved up like a muscle car then exploded in sparks. No other components were hurt, but that thing was dead. Have you tried the barebones boot? Only the mobo, CPU, and one RAM stick. If it doesn't stay on for a while it at least narrows your options down.
  • Like
Reactions: vMG
vMG
70 (0.01/day)
holy crap. i just turned on my PC and i smelled something... BURNING!
wow i got scared. okay. something is definitely fried. I couldn't smell where exactly it was coming from.
i can't tell which component it is, but my PC is just randomly fried. like wtf? I was just flippin using it today.
JrRacinFan
Served 5k and counting ...
20,073 (3.21/day)
Youngstown, OH
System Name Dual Build Streamer
Processor Ryzen 7900x3d : Ryzen 4600G
Motherboard AsRock B650E Steel Legend : Giga B450i Aorus
Cooling Custom Water 1x420 : Stock
Memory 32GB T-Force Deltas : 16GB Dominator Platinums
Video Card(s) PowerColor 7900 XTX Liquid Devil: iGPU
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Custom White Painted Phanteks Enthoo Pro 2
Audio Device(s) Onboard : Onboard
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Hyperx Origins 65
I found it. it's two pins. what do i do with it?
nevermind. ill touch it with a screw driver.
nothing changed. manual told me to either put a jumper cap or use a screwdriver.
i touched the two pins with a screwdriver for a few seconds.
Another reason why I mentioned removing the battery and unplugging it.
Pull all ram and see if you get any bios beep codes.
EDIT:
Nevermind, sounds like your motherboard or psu is toast. Here's to hoping it wasnt psu and it taking any other components with it.
  • Like
Reactions: vMG
vMG
70 (0.01/day)
W00t!
Problem solved.
I don't what I did, but it just started working.
On my Gaming PC typing this post.
Greatest feeling of relief right now. Phew!
JrRacinFan
20,073 (3.21/day)
Youngstown, OH
Storage 20+ TB
I suggest testing EVERYTHING before calling it good.
  • Like
Reactions: vMG
Perseid
154 (0.03/day)
Wisconsin, USA
Processor i7-870
Motherboard ASUS P7P55D-E Pro
Cooling Coolermaster Hyper 212
Memory 2x OCZ Special Ops 2GB DDR3 1600 (PC3 12800) 8-8-8-24
Video Card(s) Palit GTX 470
Storage Numerous 1.5 and 2 TB
Display(s) HP w2338h
Case NZXT Lexa S
Power Supply CORSAIR TX Series 950W
Software Windows 7
Yeah. Blinking lights and burning smells are never good. A lot of us suspect the PSU is on it's way out. If it does go it could take your whole system with it.
  • Like
Reactions: vMG
vMG
70 (0.01/day)
Everything seems to be running nicely.
When I booted for the first time, BIOS went completely Default.
Everything was pretty much DEFAULT settings.
I actually overclocked again to 4.05Ghz. Everything is running nicely.
So far no crashes on Windows. No more burning smell either.
Video card is also OC'ed as well.
Fans are working perfect, also the CPU fan is perfect too.
I put the Video card on two separate rails now.
I can tell my system is running perfect because before, my CPU fan didn't work properly.
The fan would literally be like 100 rpm, as if it was struggling to work.
Now it's at 1500+ rpm. :)
Everything seems healthy. I'm going to run a few applications and high-end games right now.
UPDATE:
So I am running Starcraft 2 right now.
CPU temps are just under 40c (about 35-39)
Overall System temps are between 34-36
And GPU temps are just under 60c (about 55-59)
ALL IS GOOD! WOOO!!
Thanks guys for being very helpful and sticking with me on this, lol.
Been on this for hours. Thank you to all who helped me!
Also, no crashes or any signs of defectiveness on Starcraft 2.
DaMulta
16,168 (2.50/day)
Oklahoma T-Town
Storage SSD 64GB
When a psu goes they can be moody. Like work work work, and then bam it does this crap. Then it starts working again just fine for days.
It can get to a point where it's ok as long as you don't turn it off.
Just throwing it out there, but I hope you don't see anymore problems.
I have also seen memory cause this same issue; where the problem comes and goes for quite a while.
vMG
70 (0.01/day)
lol awww man!
all right. I'll have to watch out for it then.
Should I just not overclock then? Run my entire system on default and stock?
4,686 (0.80/day)
System Name Obelisc
Cooling H110
Case T81
For some reason I read new cpu cooler as new cpu. Anyways I'd guess maybe you had something conductive causing a short and it got burned off.
  • Like
Reactions: vMG
DaMulta
16,168 (2.50/day)
Oklahoma T-Town
Storage SSD 64GB
lol awww man!
I would just run it as normal, but be sure to look at the voltages in bios to see if they are stable. If they are not you will see them jumping up and down most of the time.
You will notice problems if something is wrong of course.
Another thing to do would be run windows memtest over night to see if it passes. Sometimes it can take 10 hours before you will see it fail.
  • Like
Reactions: vMG
