Power Supply Rails
OrbitzXT
1,969 (0.32/day)
New York City
System Name AX-01
Processor Intel Core i5-2500K @3.7 GHz
Motherboard ASRock Z68 Extreme3 Gen3
Cooling Zalman 9700
Memory Kingston HyperX T1 Series 8GB DDR3 1600 MHZ
Video Card(s) GTX 590
Storage Intel X25-M
Display(s) 42" Samsung LED HDTV
Case Antec Twelve Hundred
Audio Device(s) HT | OMEGA STRIKER 7.1
Power Supply Kingwin 1000W
Software Windows 7 64-Bit
I'm kind of confused about how Power Supplies work and what is considered desirable. When I was purchasing a PSU months ago, I remember reading on NewEgg all the Pros about the number of rails a certain PSU had. Now I picked out this Silverstone PSU, and all the pros talk about it have 80A on a single rail. So what is good? What are some things to look out for beside a brands reputation for reliability?
7,662 (1.24/day)
c:\programs\kitteh.exe
Processor C2Q6600 @ 1.6 GHz
Motherboard Anus PQ5
Cooling ACFPro
Memory GEiL2 x 1 GB PC2 6400
Video Card(s) MSi 4830 (RIP)
Storage Seagate Barracuda 7200.10 320 GB Perpendicular Recording
Display(s) Dell 17'
Case El Cheepo
Audio Device(s) 7.1 Onboard
Power Supply Corsair TX750
Software MCE2K5
efficiency for one.
there are PSU threads here .. just do a lil search.
panchoman
Sold my stars!
9,595 (1.57/day)
Processor Amd Athlon X2 4600+ Windsor(90nm) EE(65W) @2.9-3.0 @1.45
Motherboard Biostar Tforce [Nvidia] 550
Cooling Thermaltake Blue Orb-- bunch of other fans here and there....
Memory 2 gigs (2x1gb) of patriot ddr2 800 @ 4-4-4-12-2t
Video Card(s) Sapphire X1950pro Pci-E x16 @stock@stock on stock
Storage Seagate 7200.11 250gb Drive, WD raptors (30/40) in Raid 0
Display(s) ANCIENT 15" sony lcd, bought it when it was like 500 bucks
Case Apevia X-plorer blue/black
Audio Device(s) Onboard- Why get an sound card when you can hum??
Power Supply Antec NeoHe 550-manufactured by seasonic -replacement to the discontinued smart power series
Software Windows XP pro SP2 -- vista is still crap
rails are basically a safety feature. rails are there to prevent overloading wires and rails allow psu manufacturers to use lower quality wires, which carry less amps. the power is divided up into different rails.. which is almost synonomous with wires. as the power is divided up, the wires have to carry less charge and are capped off to prevent over a certain amount of power going through the wires, this is the safety feature, as the wires are capped off, this also allows psu manufactureres to naturally use inferior wires as the wires will be carrying less current. single rail psu's have higher quality wires to carry the extra wires and are generally uncapped, and you'll get similiar performance from both types of psus, except for high power devices (excluding video cards) such as thermoelectric elements, compressors, and the like. video cards really like to draw power over either one rail, or in a multi rail configuration, they draw from multiple rails. one rail is the one that supplies the pci e 6/8 pin wire.. and the card also obtained a good amount of its power from the pci bus(motherboard) , which recieves power from the 20/24 pin atx connector. cards such as the 2900xt use 2 connectors so that they can access a third rail of the psu as sometimes 2 rails comes short in a small psu. however with pci 2, the pci bus can carry more power so hopefully we'll be sticking with 1 6/8 connector. um yeah.. so dont worry about the rails unless if you're running a tec,compressor, etc., then you'd need a single rail config.
edit: it can also be argued that psu's with single rail are better because power because power cannot be rerouted on the rails, as they are capped off.. so if you have a rail that is for the cpu and cpu only( as many psus are configed, to make sure the cpu recieves clean seperate power), lets say the cpu is only using 10 of the 20 amps on the rail, well the other 10 amps cant be rerouted to the say the video card rail as the video card rail is capped so that it can only take a certain amount of power, as its capped off to prevent the wire from being overloaded. so those 10 amps would be technically lost, as they have become rendered useless..
664 (0.10/day)
QLD, Australia
Processor Ryzen 9 7950X3D
Motherboard Asus ROG X670E GENE MATX
Cooling Phanteks Glacier One 280MPH AIO
Memory G.Skill 48GB (2x24GB) F5-8000J4048F24GX2-TZ5RK Trident Z5 RGB 8000MHz DDR5
Video Card(s) ASUS TUF Gaming Radeon RX 7900 XTX OC Edition 24GB GDDR6
Storage Crucial T700 Gen5 2TB NVMe | Crucial P5 Plus Gen4 2TB NVMe | Crucial P5 Plus Gen4 1TB NVMe
Display(s) AOC U3277PWQU 32in 4K
Case Phanteks Enthoo Evolv mATX TG
Audio Device(s) Onboard SPDIF --> Logitech Z-5500
Power Supply Seasonic ATX 3.0 VERTEX-GX-1000
Mouse Razer Mamba Chroma
Keyboard Razer Cynosa V2 Chroma
Software W11 Pro 64 bit
Quality of components used is important ie: filtering quality, component protection ect. The average amperage supply is another important factor as some brands boast maximum amperage supply and of course efficiency. Does this help at all?
8,253 (1.23/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
pancho puts it well.. a safetly feature
the rails have a max of 19 amps normally its an itel standard..
cpu and one high end grafix card two rails.. two 15 amp ones would do..
cpu and two high end grafix cards three rails at 15 amp would do..
cpu and three high end grafix cards.. 4 rails at 15 amp would do..
cpu and 4 high end grafix cards 5 rails at 15 amps would do..
one rail for the cpu and one rail for each high end grafix card..
the average 1200 watt psu would have 6 rails at 19 amp.. somewhat overkill unless u wanna run 5 2900xt cards and two cpus.. he he
rails u dont use are wasted..
for comparisons sake the 3870 draws about 8 amps.. the old 2900xt double that..
trog
OrbitzXT
1,969 (0.32/day)
New York City
System Name AX-01
Cooling Zalman 9700
Storage Intel X25-M
So...this one I picked a single rail. While everyone on NewEgg reviews is praising it, should I get a different one with more rails? Also how many watts do I need to run two 3870 X2's in Crossfire? I realize its not possible yet, but in the future when it is I will seriously consider adding a second one since I game at high resolution.
8,253 (1.23/day)
treat the 3870 x 2 the same as the old 2900xt.. 15 or 16 amps per card or per rail.. 19 amp rails would be best..
two 3870 cards would run off one 19 amps rail with some to spare..
do your maths is easy to work out..
trog
ps.. think three 19 amp rails or a 750 watt psu for a pair of x2 cards.. the cpu rail dont need 19 amps but they tend to come that way..
OrbitzXT
1,969 (0.32/day)
New York City
System Name AX-01
Cooling Zalman 9700
Storage Intel X25-M
All of this is a little confusing to me, will I be alright with the PSU I picked out? It has good reviews, a good brand, and a single 80A rail...and a great price for the amount of power.
7,335 (1.19/day)
C:\Program Files (x86)\Aphexdreamer\
System Name Unknown
Processor AMD Bulldozer FX8320 @ 4.4Ghz
Motherboard Asus Crosshair V
Cooling XSPC Raystorm 750 EX240 for CPU
Memory 8 GB CORSAIR Vengeance Red DDR3 RAM 1922mhz (10-11-9-27)
Video Card(s) XFX R9 290
Storage Samsung SSD 254GB and Western Digital Caviar Black 1TB 64MB Cache SATA 6.0Gb/s
Display(s) AOC 23" @ 1920x1080 + Asus 27" 1440p
Case HAF X
Audio Device(s) X Fi Titanium 5.1 Surround Sound
Power Supply 750 Watt PP&C Silencer Black
Software Windows 8.1 Pro 64-bit
I rember reading that a single powerful rail is better than multple weak ones, so I went out and bought a PSU with a sinlge large rail, I think that will do you just fine.
2,753 (0.44/day)
louisiana
Processor Intel Core i7-4790 Haswell Quad-Core 3.6GHz LGA 1150 84W
Motherboard GIGABYTE GA-H87-D3H LGA 1150 Intel H87 HDMI
Cooling CPU - Cooler Master Hyper T4 / Case - cooler master 120mm rear case fan (Air cooling)
Memory 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Video Card(s) GTX1060 6GB
Storage Samsung 512 GB 840 PRO SSD Main Drive and Samsung 512 GB 840 EVO SSD Backup Drive
Display(s) ASUS 23" LED Monitor
Case COOLER MASTER Centurion 5 (silver & black)
Audio Device(s) (onboard audio) Realtek ALC892
Power Supply CORSAIR SU-750TX 750W ATX12V / EPS12V
Software Windows 10 Home Premium 64bit Edition
single rails deliver higher amps to single devices but if you hook many items to it you may find you need more connectors.
to put it simple, a psu is a transformer, it takes 120v power in and supply 12v amps to your system
a single rail means all leads come directly from the power supply output and share one connection.
multi rails are split on seperate connections for each rail and each rail is running through a limiting regulator so for safety reasons it cant carry too many amps (usually somewhere from 14-20 amps) the single rail is likewise protected but because it feeds everything this is set rather high and can cause melted wires, smoke, and even possably a small flame in the event of a direct short.
multi rail psu are safer for computers without devices needing over 20 amps and are safer in the event of direct shorting, which is rare but running wires in unintended places for hiding them can result in chaffed wires and cause direct shorts. they are safer because they trip faster in the event of overload or short.
single rail psu are better for higher amp devices that draw over 20 amps but because of this are just a tad slower in tripping in case of shorts. a single rail because it has a slightly higher trip threshold, does not protect your system as good as a multi rail would if the psu blew.
Namslas90
4,846 (0.75/day)
Earth
The Manual for that cards recomends;
A PCIe 750 watt or higher power supply with two 2×3 PCIe power connectors.
Refference; http://support.ati.com/ics/support/default.asp?deptID=894
Load page, click "Radeon Support for PC" on left menu, then select card, Download Manual, read manual, enjoy your new ATI product with no problems.
bujeezus
1 (0.00/day)
deep south
trog
so you guys are talkin amps an rails an all that other crap. what is the wattage rating on a psu used for? an what am i lookin at here under the output specs for a psu with 2 rails? - "+3.3V@28A,+5V@34A,+12V1@20A,+12V2@17A,-12V@0.8A,+5VSB@2.5A" thanks!
