FordGT90Concept
"I go fast!1!11!1!"
- Oct 13, 2008
- 26,263 (4.34/day)
- IA, USA
System Name | BY-2021 |
Processor | AMD Ryzen 7 5800X (65w eco profile) |
Motherboard | MSI B550 Gaming Plus |
Cooling | Scythe Mugen (rev 5) |
Memory | 2 x Kingston HyperX DDR4-3200 32 GiB |
Video Card(s) | AMD Radeon RX 7900 XT |
Storage | Samsung 980 Pro, Seagate Exos X20 TB 7200 RPM |
Display(s) | Nixeus NX-EDG274K (3840x2160@144 DP) + Samsung SyncMaster 906BW (1440x900@60 HDMI-DVI) |
Case | Coolermaster HAF 932 w/ USB 3.0 5.25" bay + USB 3.2 (A+C) 3.5" bay |
Audio Device(s) | Realtek ALC1150, Micca OriGen+ |
Power Supply | Enermax Platimax 850w |
Mouse | Nixeus REVEL-X |
Keyboard | Tesoro Excalibur |
Software | Windows 10 Home 64-bit |
Benchmark Scores | Faster than the tortoise; slower than the hare. |
If you've used Steam a lot you've probably noticed a few games where Steam tries to install something every time an application is started. This application is intended to tell Steam it is installed so it can quit trying.
If you know of an application that should be added to the list, post it or private message me. Please provide the title, app ID, and information about the bugged prerequisite in the message.
1) Select the VDF for the application you're trying to install. Not all applications have prerequisites so not all applications have a VDF file to select. The VDF usually resides in the application's install directory as either install_APPID.vdf or installscript.vdf. Either should work but I would recommend using installscript.vdf when both are available.
2) Input the application ID number for the product. It should show up in the drop down list acquired from Steam but it might not. The easiest way to get it is to find the Steam store page for the program. For example, here is the full URL to the Dishonored store page and I have bolded the application ID number in it. Input that into the "app ID" field of the program: http://store.steampowered.com/agecheck/app/205100/
Without agecheck: http://store.steampowered.com/app/205100/
3) Click refresh to try to parse the installscript and search the application ID registry. If it was successful, it will show a list of prerequisite applications in the list box below.
4) Check all the unchecked boxes and start the application. Steam should no longer prompt to install anything. Note: If the prerequisite is, in fact, not installed, right-click on it and select Install to start the installer.
Title | AppID | Prerequisite (process if not obvious) | VDF |
Assassin's Creed III | 208480 | VCRedist, UplayLauncher, kb971512x86, kb971512x64 | |
Command & Conquer 4: Tiberium Twilight | 47700 | .NET 3.5 SP1 | |
Darksiders II | 50650 | DirectX | |
Dishonored | 205100 | PhysXRedist (msiexec) | |
Dungeons | 57650 | VC2010 | 57650_install.vdf |
Dungeons: The Dark Lord | 200550 | VC2010 | 200550_install.vdf |
Endless Space | 208140 | ||
Far Cry Primal | 371660 | Microsoft .Net4, Vcredist2010 | WW |
Hard Reset | 98400 | DirectX | |
Mafia II | 50130 | PhysX2 | |
Space Engineers | 244850 | Coldstart | |
Warhammer 40,000: Dawn of War - Soulstorm | 9450 | DirectX (not installable because directory missing), VCRedistMFC, x86 SP1 (VC++ 2005), x64 SP1 (VC++ 2005) | |
Wasteland Angel | 46520 | MS VC++ 2010 Redist |
