Problem clocking Connect3d x1950pro memory freq
Discussion in 'Graphics Cards' started by Z_Dash, Oct 19, 2007.
  1. Z_Dash New Member
    Dec 20, 2006
    27 (0.01/day)
    0
    I'm getting stucked at this clocking
    Its a Connect3d x1950pro with AC accelero cooler.
    Stock 600core/700mem.
    Tried using both Atitools 2.6 and 2.72 beta.
    Tried pushing core to 685mhz no problem......ran 3dmark05 alright. Pressed set default and gfx lockups. Rebooted PC and tried pushing mem freq.......just +0.5mhz only and apply. The gfx just locks up.
    Using Catalys driver 7.8 now.
    Anyone can help if anything i could do to push my mem freq?
    Btw temperature is 47deg at idle at stock clocks.
    Tried running 3dmark05 with core at 685mhz and temp = 61 at load.
  2. Morgoth
    Morgoth
    Aug 4, 2007
    3,795 (1.37/day)
    250
    Netherlands
    try using overdrive in ccc first then save that sollection in atitool that might help
  3. mitsirfishi
    mitsirfishi New Member
    Jul 31, 2005
    924 (0.26/day)
    32
    Grantham UK, Lincs
    have you tried using rivatuner i know on my asus card if i touch the memory in atitool or overdrive it just locks up but when i used rivatuner for my card i just wacked it up got around my lockup problems
Share This Page
