problem hard drive
Discussion in 'Storage' started by cookiemonster, Apr 7, 2013.
  1. cookiemonster
    Apr 2, 2007
    701 (0.23/day)
    72
    United Kingdom
    Hi I have a WD 640 sata 11 black hard drive that I used as my main hard drive a few years ago I want to wipe it to use it for storage but when I formatted it through window it shows as if it is split in to two parts one is approx. 5xxgb and the other is about 80-90gb and when I tried to use it for storage it a lot of my games on my main drive wont work. how can I erase it completely.
  2. digibucc
    digibucc
    May 21, 2009
    4,966 (2.17/day)
    1,517
    WARNING: this is dangerous. if you do this wrong you could break your windows installation. be careful.
    with the computer running off of your current, new hard drive, and the old one attached. go to the start menu and type "disk management" in the search box.
    select "create and format hard disk partitions"
    find your disk in the list, right click on each partition and click "delete volume"
    then you can right click and create a new empty volume spanning the entire drive.
    cookiemonster says thanks.
  3. cookiemonster
    Apr 2, 2007
    701 (0.23/day)
    72
    United Kingdom
    thanks will give it a go.
    regards.
  4. ste2425
    ste2425
    May 27, 2008
    3,504 (1.32/day)
    417
    Huddersfield, uk
    You could burn a ubuntu live disc, then unplug your hardrive with the working os installation.
    Boot up from the disc and use its built in format options. That way you don't have to worry about killing your current os installation.
    Format in ubunu
    Download
    You can download and use it for free, or donate money if you want too
Share This Page
