Problem installing XP Pro SP3
Darth_Pewee
87 (0.01/day)
Bismarck, North Dakota
System Name 1st Phenom...
Processor AMD Phenom X3 8450 oc'd to 2.4
Motherboard Gigabyte GA-MA78GM-S2H
Cooling Stock +1 80mm in rear
Memory 2x Corsair CM2X2048-6400C5
Video Card(s) Sapphire Radeon 2900HD Pro
Storage 250GB
Display(s) Samsung 32" TV
Case Meh...
Audio Device(s) Integrated
Power Supply Thermaltake 600w
Software Win7 Ultimate
Hey all,
Have a question that i can not seem to figure out...
I have a Gateway laptop sitting in front of me, and am trying to install XP on it... it had Vista..
and it starts just fine, but when it gets to the point where at the bottom it has "Setup is Starting Windows" it freezes there and does nothing.
i have also had another laptop have this happen too. it was an Acer..
neither one have any problems other than the one listed above..
is there a way around this problem? or is this thing stuck with vista.
also nothing wrong with disk, tried it on different machine.
43,587 (6.71/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Put the Vista disc in and format/erase the HDD with it. Restart the computer and put the XP disc in for install.
Darth_Pewee
87 (0.01/day)
Storage 250GB
Case Meh...
there is nothing on the drive currently... i wrote zeros with GWScan... unless that is messing it up... which i guess i could see..
40,435 (6.58/day)
http://www.killdisk.com/
use this program to do a thorough wipe of your HD and also Make sure your CD Drive and CD are Clean, if possible Try to burn a copy of your XP Disk and also learn how to slipstream SP3 into XP Pro via theeldergeek.com or paulthurott's Windows Super Site. Figure out who the Manufacturer of your Drive is and Download the Partitioning Tools which will setup the file system with the Proper Cluster Sizes
536 (0.09/day)
USA
You may have to install the storage controller for your hard drive by pressing F6 during the setup. I have had this problem in the past. It all depends if the storage controller is included in the preinstalled storage drivers on your install disc.
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.63/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
Yup, the hard drive is probably connected via SATA so you'll have to give it a SATA/RAID driver on a floppy in order for it to proceed with the installation.
Darth_Pewee
87 (0.01/day)
Storage 250GB
Case Meh...
there was nothing wrong with the drive at all, in fact it was a IDE drive. what it seemed like had happened with the laptop. was one of the SSE extensions or similar had died on it,
i had tried to boot up different versions of Windows including 7 Vista and even went so far as to try Ubuntu.. all of these failed to start
and running any amount of Disk and Stress test tools led to no solution....
so the laptop has been confirmed dead, we are scheduled for bashing of said laptop at a later date pics with the update
