Problem, please help
Discussion in 'General Hardware' started by BarbaricSoul, Feb 15, 2012.
  1. BarbaricSoul
    BarbaricSoul
    Feb 21, 2008
    5,592 (2.06/day)
    2,555
    S.E. Virginia
    <---comp specs in system specs
    Yesterday, I was playing alittle COD while my computer was crunching, when my computer just locked up. It was pretty simular to a gfx driver crash like what happens when my video cards overheat because I forget to turn up the fans. I figured no problem. Reboot and turn the fans up and continue what I was doing. The computer would not boot back up. All it would do is lights would come on, fans would spin up, and then it would just shut down. I've tried clearing/resetting my bios. I've tried removing the video cards and running on my CPU's graphics, I've tried using just a single stick of RAM(I tried using both sticks seperatly). I've tried using the RAM in different slots. Nothing worked. Computer won't even boot to bios. So I'm thinking my motherboard went out. Thoughts?
    Crunching for Team TPU
  2. Tatty_One
    Tatty_One Senior Moderator Staff Member
    Jan 18, 2006
    17,587 (5.05/day)
    3,346
    Worcestershire, UK
    I'm thinking your thinking along the right track, to me it could be one of 3 things as you have tried both ram sticks individually.......
    1. Motherboard Failure
    2. PSU rail failure (forget if you have a single rail) but fairly unlikely
    3. CPU failure
    It's difficult to determine which between 1 and 3 as symptoms could be the same, you could argue that if lights come on and fans spin it may be less likely that it's a board problem than a CPU problem. The only thing I can suggest at this stage is to unplug and disconnect everything, re-seat CPU and cooler, re-connect and if it still does not work, start calling on friends to borrow a PSU and a CPU through a process of elimination.
    BarbaricSoul says thanks.
  3. BarbaricSoul
    BarbaricSoul
    Feb 21, 2008
    5,592 (2.06/day)
    2,555
    S.E. Virginia
    Thank you for your reply tatty
    my PSU does have a single rail, but it is old.
    my CPU has been running pretty much at full load crunching since I got it. MAX temps for it have been right around the 70'c mark.
    I could use some more opinions people.
  4. FreedomEclipse
    FreedomEclipse ~Technological Technocrat~
    Apr 20, 2007
    14,689 (4.85/day)
    2,815
    ^This
    Theres nothing else to say.
    If it just suddenly died like that. However on the other hand if you just rebuilt and put you hardware in the case and nothing happened when you pushed the power button then that would most likely be an earthing issue if all the cables are plugged in correctly.
    The only time ive experience something similar is working with a really old machine that seemed to like earthing itself with the case a lot and a bad PSU eating one of my 4870s that i was running in crossfire.
    really cant give you any better advice then tatty already has
  5. Daimus
    Daimus
    Sep 20, 2011
    527 (0.37/day)
    474
    somewhere in Eastern Europe
    4 months ago I happened exact same issue. Suddenly the system went to reboot. My Corsair TX-950 PSU was burned. Fans worked the diodes on the motherboard glow, but the BIOS will not start. When turned on again was the smell of burnt electronics.
  6. BarbaricSoul
    BarbaricSoul
    Feb 21, 2008
    5,592 (2.06/day)
    2,555
    S.E. Virginia
    when I put my nose to the PSU, I don't smell anything burnt
    Computer has been assembled and working for the past 4 or so months.
  7. n-ster
    Jan 11, 2009
    8,898 (3.72/day)
    1,412
    Did you take out the CMOS battery? Try using 1 stick of RAM, unplugging unnecessary stuff like the DVD burner, taking out both GPUs (using your iGPU in your 2600K)
  8. BarbaricSoul
    BarbaricSoul
    Feb 21, 2008
    5,592 (2.06/day)
    2,555
    S.E. Virginia
    I did everything you listed except unplugging the DVD drive
    I'll be leaving for work here shortly, but I'll definenetly be checking back on this when I get home. Please people, keep the suggestions coming.
  9. BarbaricSoul
    BarbaricSoul
    Feb 21, 2008
    5,592 (2.06/day)
    2,555
    S.E. Virginia
    leaving foir work now, I'll be back in about 6 hours or so
  10. Daimus
    Daimus
    Sep 20, 2011
    527 (0.37/day)
    474
    Unfortunately, the smell is not always present. This is me as the "lucky" and I was able to quickly determine the problem. Previously, the PSU is also burned, but the smell was not. I have not asserted that this is a PSU is to blame, but the symptoms are very similar.
  11. qubit
    qubit Overclocked quantum bit
    Dec 6, 2007
    10,989 (3.93/day)
    4,304
    Quantum well (UK)
    While it could be one of several things, I'd say that the PSU is the hot favourite.
  12. Outback Bronze
    Outback Bronze
    Aug 3, 2011
    548 (0.38/day)
    151
    At the Pub
    Yer mate id say your right. Its gotta b the motherboard.
  13. Crap Daddy
    Crap Daddy
    Oct 29, 2010
    2,792 (1.61/day)
    1,084
    There an easy way to test your PSU. Here:
    http://www.youtube.com/watch?v=5FWXgQSokF4
    You could try and test that PSU on another machine or get another PSU to this machine
    But, as it was pointed here, it might be first a mobo failure and second a CPU failure.
    Were you running your RAM at higher voltage than 1.5v?
    If you determine that the PSU is fine you might want to take everything apart and reassemble with bare minimum to see if you have POST. If that fails send the mobo back and then see with the CPU.
    BarbaricSoul and Daimus say thanks.
  14. n-ster
    Jan 11, 2009
    8,898 (3.72/day)
    1,412
    Do you have any other rigs? friends nearby with rigs?
  15. THE_EGG
    THE_EGG
    Dec 15, 2011
    1,741 (1.31/day)
    632
    Brisbane QLD, Australia
    as silly as this sounds, a similar thing happened to me a while back. And it turned out that some thermal paste had found its way between the CPU and mobo. No idea how it happened especially as it had not been upgraded or anything like that for about a year. So i would check the socket area and make sure nothing is between the cpu and mobo.
    PS No i did not over use thermal paste as the problem would have arised earlier. And I use the same process in all the computers i have built before and after that particular PC with no problems.
  16. FreedomEclipse
    Apr 20, 2007
    14,689 (4.85/day)
    2,815
    Oh heres another thing.....Check if your H60 sprung a leak :p maybe is coughed its guts all over your hardware and caused some sort of short.
  17. Mussels
    Mussels Moderprator Staff Member
    Oct 6, 2004
    43,404 (10.98/day)
    10,620
    Australalalalalaia.
    24/7 crunching will do this, the others are on the right track. you've got a hardware failure, now its time to test with spares and find out what failed.
    BarbaricSoul and AlienIsGOD say thanks.
  18. BarbaricSoul
    BarbaricSoul
    Feb 21, 2008
    5,592 (2.06/day)
    2,555
    S.E. Virginia
    I have no spares or friends with a 1155 computer:cry:
  19. n-ster
    Jan 11, 2009
    8,898 (3.72/day)
    1,412
    test your RAM in a friends rig, if you have a good friend, maybe test their PSU in your rig or your PSU in theirs?
  20. BarbaricSoul
    BarbaricSoul
    Feb 21, 2008
    5,592 (2.06/day)
    2,555
    S.E. Virginia
    all my friends either have prebuilt's with DDR or DDR2 or laptops
  21. BarbaricSoul
    BarbaricSoul
    Feb 21, 2008
    5,592 (2.06/day)
    2,555
    S.E. Virginia
    Ok, so I'm going to go ahead and order a new PSU and motherboard. I had already been thinking of getting an ASRock Z68 Extreme4 Gen3, so that's what I'll get for the board. For the PSU, I've picked out a few that meet my criteria. My criteria is single rail, modular, high quality, and atleast a +80 effincency. Which one would you pick? I'm also open to other suggestions for a PSU.
    CORSAIR Enthusiast Series TX850M 850W ATX12V v2.31...
    CORSAIR Enthusiast Series TX750M 750W ATX12V v2.31...
    SeaSonic M12II 750 SS-750AM 750W ATX12V / EPS12V S...
    XFX PRO750W XXX Edition Semi-Modular 80Plus Silver...
    SILVERSTONE ST85F-P 850W ATX 12V v2.3 / EPS 12V 80...
    SILVERSTONE ST75F-P 750W ATX 12V v2.3 / EPS 12V 80...
  22. n-ster
    Jan 11, 2009
    8,898 (3.72/day)
    1,412
    I personally like the XFX, but note that it is pretty similar to the HX750 from Corsair
  23. Crap Daddy
    Crap Daddy
    Oct 29, 2010
    2,792 (1.61/day)
    1,084
    Out of what you picked I'd go with the Corsair TX850M but beware it's semi-modular.
  24. Daimus
    Daimus
    Sep 20, 2011
    527 (0.37/day)
    474
    I agree with the n-ster. My vote for XFX PRO750W. This semi-modular PSU is certified 80 + Silver.
  25. n-ster
    Jan 11, 2009
    8,898 (3.72/day)
    1,412
Share This Page
