Problem, please help
6,862 (1.17/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Benchmark Scores https://www.3dmark.com/spy/34962882
Ok, I ordered the XFX power supply. I'm going to hold off on buying the motherboard and hope it's a PSU issue.
6,862 (1.17/day)
S.E. Virginia
well just a quick follow up. Turns out, there is nothing wrong with my older PC Power and Cooling PSU and the problem was in my motherboard. Bought this MSI board from Kantastic and everything is working again.
qubit
Overclocked quantum bit
17,866 (3.00/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Thanks for letting us know. :) It's always nice to know how things turn out in the end.
2,972 (0.61/day)
System Name Old Fart / Young Dude
Processor 2500K / 6600K
Motherboard ASRock P67Extreme4 / Gigabyte GA-Z170-HD3 DDR3
Cooling CM Hyper TX3 / CM Hyper 212 EVO
Memory 16 GB Kingston HyperX / 16 GB G.Skill Ripjaws X
Video Card(s) Gigabyte GTX 1050 Ti / INNO3D RTX 2060
Storage SSD, some WD and lots of Samsungs
Display(s) BenQ GW2470 / LG UHD 43" TV
Case Cooler Master CM690 II Advanced / Thermaltake Core v31
Audio Device(s) Asus Xonar D1/Denon PMA500AE/Wharfedale D 10.1/ FiiO D03K/ JBL LSR 305
Power Supply Corsair TX650 / Corsair TX650M
Mouse Steelseries Rival 100 / Rival 110
Keyboard Sidewinder/ Steelseries Apex 150
Software Windows 10 / Windows 10 Pro
Yes it's nice to have a follow-up. What was that dead mobo?
6,862 (1.17/day)
S.E. Virginia
1,962 (0.44/day)
Sydney NSW, Australia
System Name Shoebox Sandwich | Razer Blade 14 | Synology DS418 w/ 4X8TB WD Red | iPhone 15 Pro
Processor AMD Ryzen 7 7800X3D | AMD Ryzen 9 5900HX
Motherboard ASRock B650E PG-ITX WiFi | Razer thing
Cooling NZXT Kraken 240 RGB w/ Lian Li P28 + Corsair AF120 Slim | Double fan vapour chamber
Memory G.Skill Flare X5 2x16GB 6000MHz CL32 DDR5 | 16GB 3200MHz DDR4
Video Card(s) Sapphire Radeon RX 7900 XTX | NVIDIA GeForce RTX 3070 8GB
Storage Seagate FireCuda 520 2TB + Lexar NM790 4TB | 1TB NVMe SSD + 2TB NVMe external SSD
Display(s) Alienware AW3423DW & Sony A90K 42" | 14" QHD IPS 165Hz & Sony X90J 65" 4K TV
Case FormD T1 - v2.1 - Titanium colourway w Aluminium mesh | Razer Blade 14
Audio Device(s) Schiit Hel 2E (Focal Clear & HiFiMAN HE-4XX & DROP PC38X) | Samsung Q950A
Power Supply Corsair SF750 Platinum | Razer 230W brick
Mouse Razer Viper Ultimate Mercury | Roccat Kain 202
Keyboard DIY Geek 64 PCB (Kailh Box Deep Sea - Matcha XDA Keycaps) | Corsair K63
VR HMD Oculus Quest
Software Windows 11 Home | Windows 11 Home
Benchmark Scores 2022 MINI Countryman SE PHEV Hybrid ALL4 | British Racing Green| Malt Brown Interior| YOURS Trim
a Gigabyte GA-Z68AP-D3
good to hear you have your computer up and running again! Just out of curiousity, did you find out what was wrong with the mobo at all? (any damage in the socket area or bad plugs?)
FreedomEclipse
~Technological Technocrat~
23,309 (3.77/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
Probably not.... RMA it if its still under warranty - wait for a replacement, then sell it on here or Ebay, thats what id do.
Aquinus
Resident Wat-man
13,147 (2.96/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
You said you're computer has been crunching practically 24/7. At temperatures as high as 70*C, it is very possible that components in your CPU started to fail. When memory fails, a lot of motherboards will beep at you. My motherboard came with header pins for LED diagnostics, maybe that will tell you where the system is failing to start. If it doesn't come up with anything your motherboard could be fried.
How big is your power supply, because stressing a computer 100% for a long time can cause your PSU to over heat and if you didn't give yourself at least 25% headroom on the PSU's wattage rating it is very possible that your PSU was struggling to keep your system running and all it takes is a little over-voltage because of lack of current to fry components on your motherboard.
I know someone who had a PSU that was just large enough and it fried his motherboard and video card. I would also get a Kill-a-watt to see how much power your system is drawing once you get it repaired. Keep in mind that if you have a 650-watt PSU, it would be very unwise to let your computer draw any more than 500-watts under full load with at least an 80 PLUS Gold rating.
A little bit of information about what you're running will help us gauge how much power draw your system had (at least at stock,) and we can take some guesses about what components could have failed.
Edit: I just read that you got it working, but here is my 6-sense: Personally when I overclock my rig, I draw about 450-watts and I have a 800-watt PSU to power it. Keep in mind that your PSU powers your entire system and if your PSU is cheap, it will take other things down with it. I have an upgrade on the way for my system, and I'm looking at running crossfire 6870s and I'm investing in a bigger 1000-watt PSU with an 80 PLUS Platinum rating. When you're over-clocking you never want to take chances that it could struggle to provide enough power. Too much is always better than too little.
Edit 2: Also keep in mind that the hotter your PSU runs the less efficient it becomes and without adequate air flow the issue can "run away," until it can't handle it anymore.
6,862 (1.17/day)
S.E. Virginia
the Gigabyte boards shows no damage on it.
2600k appears to be working just fine. Crunched with it all night last night with no BSODs or crashes.
My old PSU is a PC Power and Cooling Turbo Cool 860 watt. In it's day, it was one of the best PSUs you could get.
To be perfectly honest, I thought it was a MB problem from the very start. But the 860 does have a few years on it, so I went with the suggestions posted here and got a new PSU. I should have just went with my initial thoughts when the problem started. Oh well, atleast now I'm not worried about my PSU being old and possibly failing.
Aquinus
Resident Wat-man
13,147 (2.96/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
If your systems specs in your profile is what you're running, the hardware you're running with an overclock at full load could be over-stressing your PSU. Be very careful, you don't want to go frying hardware.
