Problem With 4850's PLEASE HELP =(
froglegs114
7 (0.00/day)
I am running
4x2gb Kingston 800 ddr2
GA-EP45-D54P Mainboard
Thermaltake Toughpower 750W
2x ASUS EAH4850 W/Crossfire
I can access windows until i install the graphics drivers. Then i get BSOD.
Go to Safe mode, uninstall the drivers and i can get in to windows again.
Tried flashing mainboard bios to no avail.
Tried disconnecting Crossfire to no avail.
Tried taking one graphics card out to no avail.
Tried Installing the drivers without the CCC software to no avail.
The cards come with Glaciator fan sinks which work fine, keep the cards down to about 40C(102F)
Am starting to think that the Mainboard just isn't compatible with these cards, although it does say that it is crossfirex enabled.
I'm thinking it's not a Power supply problem as it has dedicated rails for the PCI-E connectors
On the BSOD it says Attempt to reset the display driver and recover from timeout failed and in particular mentions ATIKMDAG.SYS
Visited ATI website and this is what they say
Symptoms:
After installing the Catalyst display drivers and rebooting, the system will give a blue screen (BSoD) error referencing ATIKMDAG.SYS
Cause:
This issue is caused by using a motherboard with a chipset that is unsupported in Windows Vista
Surely motherboards that are released now should be compatible with the graphics cards that are released now.
I'm really running out of things to try, anyone care to help??
kylew
604 (0.10/day)
Liverpool
Processor Main: Intel Core 2 Quad Q6700 @ 3.7Ghz / Server: Q6600@ Stock
Motherboard Main: Asus P5E @ Rampage Forumla / Server: P5K Deluxe
Cooling Main: Thermalright 120 Ultra Extreme (8 x 120mm fans inc. PSU + 2 x 92mm fans.) / Server: Stock
Memory Main: 4x2GB Gskill DDR2 1000Mhz / Server: 4x1GB Gskill DDR2 800Mhz
Video Card(s) Main: 2GB 5870 Eyefinity 6 / Server: HD 4850
Storage 8 Internal (SATA) 2 External (USB). Total storage 5.4TB
Display(s) Triple Dell 24" 2408WFP
Case Main: Silverstone TJ07 / Server: Coolermaster Stacker 810
Audio Device(s) Main: Auzentech Xmystique / Server: NI Rig Kontrol
Power Supply Main: Coolermaster Realpower 850w Modular / Server Tagan 600W Modular
Software Main: Windows 7 Ultimate 64bit / Server: Windows 7 Ultimate 64bit
Benchmark Scores 3D Mark 06 19.5k 3D Mark Vantage 12.5k Super PI 13.4s
Have you flashed the bios of your 4850s by any chance? There's no way the P45 chipset isn't supported by vista. I've got a P35 and X38 that both work perfectly fine in windows vista 64 and 32bit. With my X38 board having 2 4850s crossfired in it.
If you haven't flashed the 4850 bioses, I'm guessing it's a non-reference overclocked one? It could have a b0rked bios on it or something maybe?
froglegs114
7 (0.00/day)
good thought
No i haven't tried flashing the bios on them. i wouldnt have the slightest clue on how to do it. Would you be able to point me in the right direction ? and they're straight from the box. i don't think it's overclocked or anything. pretty sure they're just stock standard. They're ASUS EAH4850..
Thanks.
12,453 (1.99/day)
Yankee lost in the Mountains of East TN
Processor 5800x(2)/5700g/5600x/5600g/2700x/1700x/1700
Motherboard MSI B550 Carbon (2)/ MSI z490 Unify/Asus Strix B550-F/MSI B450 Tomahawk (3)
Cooling EK AIO 360 (2)/EK AIO 240, Arctic Cooling Freezer II 280/EVGA CLC 280/Noctua D15/Cryorig M9(2)
Memory 32 GB Ballistix Elite/32 GB TridentZ/16GB Mushkin Redline Black/16 GB Dominator
Video Card(s) Asus Strix RTX3060/EVGA 970(2)/Asus 750 ti/Old Quadros
Storage Samsung 970 EVO M.2 NVMe 500GB/WD Black M.2 NVMe 500GB/Adata 500gb NVMe
Display(s) Acer 1080p 22"/ (3) Samsung 22" 1080p
Case (2) Lian Li Lancool II Mesh/Corsair 4000D /Phanteks Eclipse 500a/Be Quiet Pure Base 500/Bones of HAF
Power Supply EVGA Supernova 850G(2)/EVGA Supernova GT 650w/Phantek Amps 750w/Seasonic Focus 750w
Mouse Generic Black wireless (5)
Keyboard Generic Black wireless (5)
Software Win 10/Ubuntu
Did you just install the drivers that came with the card? If so, uninstall those, then download and install the latest ATI drivers.
12,453 (1.99/day)
Have you tried the cards one at a time?
iStink
648 (0.11/day)
System Name The beast
Processor E6600@ 3.4
Motherboard P5W DH Deluxe
Cooling Tuniq Tower 120
Memory 3GB G.Sill DDR2-800
Video Card(s) 8800GT @ 700/975
Storage (1)80GB With XP, (1) 320GB storage
Display(s) 205BW & 710N
Case XClio Windtunnel (I love it)
Audio Device(s) X-Fi Platinum
Power Supply OCZ gamerXStream 700W
Are these the first cards on the system? Possible some remaining nvidia drivers remain?
froglegs114
7 (0.00/day)
First cards. Installed vista, installed mainboard drivers, installed graphics card drivers, reboot, BSOD, BSOD, BSOD.....
2,648 (0.42/day)
UK
System Name Ma Biatch
Processor i7 860
Motherboard Gigabyte GA-P55-UD3A
Cooling Noctua
Memory 8gb (4x2gb) G-Skill
Video Card(s) GTX 470
Storage WD5000aaks raid0
Display(s) Sony Bravia 37" 1080p
Case CM 690
Power Supply Corsair HX520
Software Windows 7 Ultimate
did you install the motherboard drivers off the disc. have you tried updating them ?
froglegs114
7 (0.00/day)
tried updating the motherboard drivers, tried flashing the motherboard bios. both didn't work.
2,648 (0.42/day)
UK
Processor i7 860
Cooling Noctua
Case CM 690
i cant see both cards being faulty, tbh i would probably try a reinstall of windows at this point and see how that goes, to be getting bsod of both cards seprately is weird, maybe a driver conflict ?
11,655 (1.73/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Storage Samsung 990 2TB, 2 SP 2TB SSDs and over 10TB spinning
Display(s) 56" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
Possibly a defective board.
Deleted member 24505
could you try the cards in another pc? if they fail in that,however weird it is two of them been dead,theres your problem.
43,585 (6.74/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
If you are able to get back into Windows, go to Control Panel-->Administrative Tools-->Event Viewer and check there for errors and or warnings.
Sonido
356 (0.06/day)
USA
System Name Sonido
Processor E6600 @ 3.20 GHz (1600 FSB)
Motherboard abit IX38 QuadGT
Cooling Tt SpinQ (load @ 29c)
Memory TopRam SpeedRAM A.K.A "El Cheapo" @ 800 MHz
Video Card(s) Diamond HD 4870 (@ Stock)
Storage Primary: 500 GB WD
Display(s) 32" Samsung 1080p HDTV
Case Antec Twelve hundred (Modded Tri-cool fans)
Audio Device(s) On-board HD Audio
Power Supply 700W Rocketfish
Software Vista\7\Linux\Hackintosh
Uninstall all traces of ATi related material. Once you have done the uninstall, use driver cleaner. It will remove all dead reg keys associated with ATi. Once that is complete, download only the Driver package from ATi.
32-bit Vista Drivers
64-bit Vista drivers
Reinstall from those. I hope it helps you. If you need more help, we're here.
summersend
37 (0.01/day)
First thing i notice is that board doesnt suppoort two cards at 2.0. 16XWhen u reinstalled did u try vista drivers first or just go straight to amd/ati sight?
