Problem with 6950 PCS++ "Flashing"
Halk
105 (0.02/day)
System Name Desktop PC
Processor 1090T
Motherboard Crosshair IV Forumula
Cooling Arctic Freezer 7 pro
Memory 4x2GB OCZ Reaper
Video Card(s) DirectCU 580
Storage Vertex 2 120GB
Display(s) Dell 24 inch
Case Fractal Design R3
Audio Device(s) Asus Xonar Essence STX
Power Supply Seasonic X 650
Software Win 7 Home Premium x64
Both of mine (one went back with a broken fan) came with the unlocked BIOS. They worked fine - as Powercolor said they've been picked so that they do work.
That's what the second + in PCS++ is, as far as I understand.
In any case I did upload the BIOS from mine to here a few days ago but it hasn't made it onto the site. If you want it Omergurlek, then PM me your email address and I'll send it to you.
omergurlek
28 (0.01/day)
The thing is, Ive tried one a few days ago, and it didn't work. However, trying again doesn't hurt :D If you could upload to any file hoster that would be great.
Raistlin
10 (0.00/day)
When you say worked fine, I assume you mean you verified the shader/core count via the current version of GPU-Z?
If so, can you recollect the exact steps involved in installing and configuring the card? It would be a shame for a whole bunch of good cards to get RMA'd if it's simply some setup steps that are falling through the cracks.
Halk
105 (0.02/day)
Processor 1090T
Sadly it was as simple as making sure the BIOS switch was in the right position, and plugging them in... then on GPU-Z they show the correct counts. They do detect elsewhere as 6950 sill, not a 6970. The memory on mine doesn't do 6970 speeds - or at least if they do then more tinkering is needed than simply ramping up the memory clockspeed. The only difficulty is in finding the BIOS switch, which is very small indeed. It lives near the Crossfire connectors.
I've put the BIOS up on my own server - http://halk.lyrebird.feralhosting.com/powercolor_pcs++_6950_standard.rar
Kai Hohiro
18 (0.00/day)
Thanks for sharing, but this is the exact same bios I had on my card. I tried flashing anyways, but no dice. Could you maybe post your GPU-Z readout? I'd like to know if there are any other differences.
Hi guys, I ask for your patience, we are still looking all our production logs and we should have a final conclusion this Monday.
But dont worry, if you'r PCS++ is faulty you will get a new part.
I will give more details on monday.
Thank you, the support is much appreciated. I've been a long time user of powercolor cards, but I was almost convinced this was done on purpose. Glad I was completely wrong.
To specify all the steps I've tried.
1. I compared the two bios and aside from the increased clock speeds there was no difference in GPU-Z, 1408 Shaders in both cases. RBE does say the 2nd Bios is a 6970 card.
2. Tried flashing with a Powercolor 6970 Bios, which ended up with the same results as the stock 2nd Bios.
3. Tried flashing with a Sapphire 6970 Bios, again the same.
4. Tried the Bios Halk posted, but it's completely identical to my original Bios, so still no change.
So I guess a RMA it is. On a sidenote, I've been trying to get in touch with Powercolor's Support, however none of my queries that I submitted via the contact form on the webportal have been answered. I would like to RMA with powercolor directly, since the fault is pretty definitive, and I'm almost certain the retailer won't understand what the problem is and think the card is fine.
iamtheone
32 (0.01/day)
@Kai Hohiro
Welcome to the real life. This practice is always a good bait for customers. In the shop, that I am working, sometimes we get Engineering Sample of some products. They are always a bit better than final product. Reviewers got bait, wrote a good review and a final product appear to be failure. That's how the business goes!
lol at your cynicism.
If what you're saying is true, then the engineering sample isn't "just a little bit better", like a golden 5.2ghz sandybridge, but it actually has an extra feature missing in the final product version, aka the shader unlock. It's not a performance increase on a continous scale, it's an extra discrete feature of the product.
Which if left out, would be blatant false advertising.
Raistlin
10 (0.00/day)
Thanks for the update! It definitely puts me at ease that your team is on top of this. Great customer service.
Halk
105 (0.02/day)
Processor 1090T
There you go...
Raistlin
10 (0.00/day)
Oh son of a bitch. If mine's fine, I want a second for crossfire.
Does anyone else carry them? :(
3,456 (0.71/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
I'm a bit perplexed though. Every card that is rev1 has unlocked more on stats in a moment. Whether it's stable at 6970 clocks or not is beside the point, cuz they all unlock. Unlock or not unlock wasn't a matter of quality of silicon. That is with the rev1 boards. If we go by the tpu article, there were hundreds of unlocks with only 1 unlock failure.
The above doesn't make sense with PC's explanation that it was a bad batch.
Pflaumenwunder
21 (0.00/day)
Processor AMD Phenom II X6 1090T (4GHz)
Motherboard Gigabyte Ga-890FXA-UD5
Cooling Scyth Muggen 2
Memory 4x2GB Corsair CMX8GX3M4A1333C9
Video Card(s) PowerColor HD6950PCS++
Storage Seagate 250GB ST3250410AS, 1500GB ST31500341AS
Display(s) Samsung P2770FH (27")
Case Xigmantek Midgard
Audio Device(s) Creative X-Fi Titanium
Power Supply Cougar GX1050
Software Windows 7 x64 Home Premium
Where can you see that the Card is Rev 1? After unpacking the Card, i looked on the PCB and the Pictures of the Techpowerup test. Both card seems to be the self. ( in dont have looked the GPU) but, why are the cards unlocked on anybody with the same BIOS and why dont works not to all?
Powercolor says, the GPUs are hand picked and i say, the CPUs are cuttet.
I waiting for an answer of Powercolor but i hope that i dont have to send the card to RMA. I cant wait some weeks (5-6) to get my Card back.
Halk
105 (0.02/day)
Processor 1090T
I got mine in the UK from M2M - they have a few left of the original batch both of mine came from (both were unlocked).
I've no idea if they can ship to the US, without charging you UK VAT. I don't expect it's a realistic option.
bill213
18 (0.00/day)
just wait a bit im sure they will be available. I think the faulty bios batch has been pulled from newegg
Pflaumenwunder
21 (0.00/day)
PowerColor:
Is this service only avaiable for the US/UK Country or other Countrys to? (Example: Germany)
PowerColor
PowerColor Rep
15 (0.00/day)
Based on your location you'r RMA will be done either from NL office or US.
So in your case: NL (Holand)
Pflaumenwunder
21 (0.00/day)
Who paid all the shipping costs? (From Germany to NL and back)
and, how long does the replacement takes? (days, weeks)
Oh, no. In the Mail i have written a wrong subject. (Shit Happens)
16 Euro costs to shipping the Card to NL. (from Germany, via DHL)
Sorry, we were unable to deliver your message to the following address.
Kai Hohiro
18 (0.00/day)
Thanks for the response, this is great customer service, big kudos.
Shit happens, but as long as people own up to it, no harm done.
Pflaumenwunder
21 (0.00/day)
Youre right. Now i have contacted the Shop where i had bought the card.
its the shops choice to send the card to RMA or give me the money back.
Powercolor get a Thanks from me because they want to help the other customers.
bill213
18 (0.00/day)
Love the way powercolor is handling this. Gonna call them when i get home for RMA
